Hi Team,
Our customer has some clarifications about the PLECS file in the TIDA-010054 reference design. According to our customer,
I don't fully understand the control blocks in the plecs simulation There are two control method Single phase shift and dual phase shift. My question is how they use the voltage signal difference to change the duty cycle of the switches?
This is the control block of the DPS(Dual Phase Shift) I wonder how to generate alphaP and alphaS
To elaborate:
1. How to generate alphaP and alphaS. What is the meaning of alphaP and alphaS? What is the internal phase shift angle and what is the external phase shift angle in this simulation as it is a DPS control implementation? And how to use the voltage reference signal to control the duty cycle of the switches.
2. In this project. There's another file called SPS(single phase shift modulation). I also have a question about this PLECS simulation file. How to use the Discrete PID controller signal to generate the switch control signal? How to build the phase shift PWM?(This block is masked)
Danilo
