Other Parts Discussed in Thread: SYSCONFIG, MSPM0G3507
Hi Team,
Please see my enquiry below:
- About SysConfig
I understand that early experimental CPU are not supported when using the latest SysConfig.
The following occurrences is one of them, and I would like to confirm in advance that the problem does not occur when using the latest CPUs.
The combination of SysConfig version is 1.6.1 and early experimental EVK board (Rev.1.0).
I am using TIMG8 with PWM, but a Hard Fault occurs during the initialization process of TIMG8.
Am I correct in understanding that this is because the EVK board does not support TIMG8, which will be resolved in the latest CPUs?
Below is the SysConfig screen for version 1.6.1, but I believe TIMG8 did not exist as of version 1.5.x
- About CCS Theia (Development Environment)
2-1. Power Supply from the Emulator
When supplying power externally to the target board, I cannot find the function to turn on/off the power supply from the emulator.
Am I missing something?
Or does the emulator have a function to monitor the power supply of the target board?
2-2. Build Configurations
I would like to add more build configurations, but I can't find a way to do so.
I may have missed something, but could you please let me know.
Below is the build configuration selection screen.
Please kindly advise.
Thank you.
Ernest
