Part Number: PSPICE-FOR-TI
I am trying to install PSPICE-FOR-TI and the installer stops shortly after downloading some files. What should I do? Here is the end of my cdsPspiceTIlog.txt:
9:50:24 AM Tuesday, June 27, 2023 : Checking for memory space
9:50:24 AM Tuesday, June 27, 2023 : Memory space available
9:50:24 AM Tuesday, June 27, 2023 : Target Dir: C:\Cadence\PSpiceTI
9:50:24 AM Tuesday, June 27, 2023 : Working Dir: C:\cds_spb_home
9:50:24 AM Tuesday, June 27, 2023 : Silent ini file created
9:50:28 AM Tuesday, June 27, 2023 : downloads.ti.com/.../data1.cab Status is OK
9:50:28 AM Tuesday, June 27, 2023 : Starting download of data1.cab Attempt no 1 DataSize is 31794546
9:50:28 AM Tuesday, June 27, 2023 : downloads.ti.com/.../0x0409.ini Status is OK
9:50:28 AM Tuesday, June 27, 2023 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
9:50:28 AM Tuesday, June 27, 2023 : File download completed without any errors. Url = software-dl.ti.com/.../0x0409.ini
9:50:28 AM Tuesday, June 27, 2023 : An exception occured which is causing the program to close.
9:50:28 AM Tuesday, June 27, 2023 : Details of exception are : Exception has been thrown by the target of an invocation.
9:50:28 AM Tuesday, June 27, 2023 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args)
at System.Security.Cryptography.MD5.Create()
at TIPSpice.Utilities.GetFileChecksum(String filePath)
at TIPSpice.FileDownloader.StartDownload()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
9:50:28 AM Tuesday, June 27, 2023 : Message: An error occurred and PSpice for TI needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\user\AppData\Roaming\Cadence\PspiceTIInstall for error details.
9:50:33 AM Tuesday, June 27, 2023 : File download completed without any errors. Url = software-dl.ti.com/.../data1.cab
9:50:33 AM Tuesday, June 27, 2023 : An exception occured which is causing the program to close.
9:50:33 AM Tuesday, June 27, 2023 : Details of exception are : Exception has been thrown by the target of an invocation.
9:50:33 AM Tuesday, June 27, 2023 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
9:50:33 AM Tuesday, June 27, 2023 : Message: An error occurred and PSpice for TI needs to close.
Thanks!
