Part Number: TIDA-020031
Could you please provide complete calculation for the below equation. The picture below is from the design guide and it does not tell what Ip_off is.
Hi Aneesh,
Ip_off is the primary side current when lag bridge is switching off. You should define the load percentage Coef to achieve ZVS.
Then Ip_off can be approximately calculated by Ip_off = (Coef*Iout+ΔIL/2)/(2*nps).
nps is the turn ratio, Iout is the rated output current, and ΔIL is the ripple on output choke.
Best Regards
