TIDA-020047: CSIRX configuration for 2* AWR2243 cascading
Part Number: TIDA-020047
Other Parts Discussed in Thread: AWR2243,
I am working on TIDA-020047 reference design for 2 AWR2243 cascading.
I updated the MMWDemo to support cascading, the radar configuration steps is OK and we are facing issue when starting data sampling and processing.
I found that the application get an error when sending frame trigger from DSS to MSS.
Please find enclosed logs from MSS and DSS.
Tell me if you need any further information.
INFO: MmwDemo_dssInitTask:795: Debug: Start DSS
ObjDet DPC: objDetObj address = 8616960
INFO: MmwDemo_dssInitTask:902: Debug: DPM Module Sync is done
ObjDet DPC: Pre-start Common Config IOCTL processed
DSSApp: DPM Report IOCTL, command = 101
ObjDet DPC: Pre-start Config IOCTL processed (subFrameIndx = 0)
DSSApp: DPM Report IOCTL, command = 100
rangeProcHWA_ConfigHWACommon [192]
ObjDet DPC: Start done
DSSApp: DPM Report start
Send  DPMTrigFrameSemHandle
ObjDet DPC: Frame Start, frameIndx = 0, subFrameIndx = 0
DSSApp: DPM Report IOCTL, command = 115
ObjDet DPC: Processing sub-frame 0
INFO: MmwDemo_DPC_ObjectDetection_processFrameBeginCallBackFxn:380:  processFrameBeginCallBackFxn
Start RangeProcHWA_process
DPU RangeProcHWA_process
INFO: MmwDemo_DPC_ObjectDetection_FrameTrigTask:743: Error: Unable to send DPC_OBJDET_IOCTL__TRIGGER_FRAME [Error:-1]
ASSERT: 2.431355s: ../src/dss_main.c:MmwDemo_DPC_ObjectDetection_FrameTrigTask:744: 0 failed !!
INFO: MmwDemo_openSensor:3385: mmWave Open Done
INFO: MmwDemo_populateChirpControlCfg:3640:  Profile [0]
INFO: MmwDemo_populateChirpControlCfg:3644:  Radar [0]
INFO: MmwDemo_populateChirpControlCfg:3653:  Added Profile [1026F800]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [0]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [1]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [2]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [3]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [4]
INFO: MmwDemo_populateChirpControlCfg:3660:  Chirp [5]
INFO: MmwDemo_populateChirpControlCfg:3685: Chirp Addition
INFO: MmwDemo_populateChirpControlCfg:3644:  Radar [1]
INFO: MmwDemo_populateChirpControlCfg:3653:  Added Profile [1026FC00]
INFO: MMWave_configureProfileChirp:1037: MMWave_configureProfileChirp [0]
INFO: MMWave_configureProfileChirp:1079:  startFreqConst  1435384035
INFO: MMWave_configureProfileChirp:1080:  idleTimeConst  500
INFO: MMWave_configureProfileChirp:1081:  adcStartTimeConst  600
INFO: MMWave_configureProfileChirp:1082:  rampEndTime  2600
INFO: MMWave_configureProfileChirp:1083:  freqSlopeConst  1645
INFO: MMWave_configureProfileChirp:1084:  txStartTime  0
INFO: MMWave_configureProfileChirp:1085:  numAdcSamples  128
INFO: MMWave_configureProfileChirp:1086:  digOutSampleRate  8000
INFO: MMWave_configureProfileChirp:1087:  hpfCornerFreq1  0
INFO: MMWave_configureProfileChirp:1088:  hpfCornerFreq2  0
INFO: MMWave_configureProfileChirp:1089:  rxGain  42
INFO: rlDriverCmdInvoke:2759: ************** Sending SPI Command for device [0] ************
INFO: MMWave_waitIRQStatus:684: MMWave_waitIRQStatus want level 0 got value 1
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  0
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  0
INFO: MMWave_configureProfileChirp:1130:  profileId  0
INFO: MMWave_configureProfileChirp:1131:  startFreqVar  0
INFO: MMWave_configureProfileChirp:1132:  freqSlopeVar  0
INFO: MMWave_configureProfileChirp:1133:  idleTimeVar  0
INFO: MMWave_configureProfileChirp:1134:  adcStartTimeVar  0
INFO: MMWave_configureProfileChirp:1135:  txEnable  1
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  1
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  1
INFO: MMWave_configureProfileChirp:1135:  txEnable  2
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  2
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  2
INFO: MMWave_configureProfileChirp:1135:  txEnable  4
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  3
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  3
INFO: MMWave_configureProfileChirp:1135:  txEnable  0
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  4
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  4
INFO: MMWave_configureProfileChirp:1128:  chirpStartIdx  5
INFO: MMWave_configureProfileChirp:1129:  chirpEndIdx  5
INFO: MMWave_configureProfileChirp:1065: MMWave_configureProfileChirp [0] Profile skip
INFO: MMWave_configureProfileChirp:1037: MMWave_configureProfileChirp [1]
INFO: rlDriverCmdInvoke:2759: ************** Sending SPI Command for device [1] ************
INFO: MMWave_configureProfileChirp:1065: MMWave_configureProfileChirp [1] Profile skip
INFO: MMWave_configBPM:731: MMWave_configBPM [3]
INFO: MMWave_configPhaseShift:877: MMWave_configPhaseShift [0]
INFO: MMWave_configPhaseShift:877: MMWave_configPhaseShift [1]
INFO: MMWave_configureFrame:1593: MMWave_configureFrame [0]
INFO: MMWave_configureFrame:1620:  chirpStartIdx  0
INFO: MMWave_configureFrame:1621:  chirpEndIdx  5
INFO: MMWave_configureFrame:1622:  numLoops  64
INFO: MMWave_configureFrame:1623:  numFrames  0
INFO: MMWave_configureFrame:1624:  numAdcSamples  256
INFO: MMWave_configureFrame:1625:  framePeriodicity  30000000
INFO: MMWave_configureFrame:1626:  triggerSelect  1
INFO: MMWave_configureFrame:1627:  frameTriggerDelay  0
INFO: MMWave_configureFrame:1593: MMWave_configureFrame [1]
INFO: MMWave_configureFrame:1626:  triggerSelect  2
INFO: MmwDemo_dataPathConfig:1982: App: Issuing Pre-start Common Config IOCTL
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2516: App: DPM Report IOCTL, command = 101
INFO: MmwDemo_dataPathConfig:2018: MmwDemo_dataPathConfig index
INFO: MmwDemo_RFParser_parseCtrlConfig:650: mmWaveNumChirps: 6
INFO: MmwDemo_RFParser_setAoAParams:418: start value validProfileTxEn: 63
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 5 , 63
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 4 , 31
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 3 , 15
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 2 , 7
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 1 , 3
INFO: MmwDemo_RFParser_setAoAParams:423: log2TxEn: 0 , 1
INFO: MmwDemo_RFParser_setAoAParams:446: Azimuth Tx: 5 (MIMO:1), Elev Tx:1
INFO: MmwDemo_RFParser_setAoAParams:488: Ant setting virtualAzim: 40 , virtual Elev :8
INFO: MmwDemo_RFParser_parseCtrlConfig:767: Ant setting virtualAzim: 40 , virtual Elev :8
INFO: MmwDemo_RFParser_parseCtrlConfig:768: startFreqConst: 1435384035
INFO: MmwDemo_RFParser_parseCtrlConfig:769: rfFreqScaleFactor: 3.600000
INFO: MmwDemo_RFParser_parseCtrlConfig:770: bandwidth : 1.270723 GHz
INFO: MmwDemo_RFParser_parseCtrlConfig:771: adcStartTimeConst: 600
INFO: MmwDemo_RFParser_parseCtrlConfig:772: freqSlopeConst: 1645
INFO: MmwDemo_RFParser_parseCtrlConfig:773: centerFreq: 78.111883 GHz
INFO: MmwDemo_RFParser_parseCtrlConfig:774: dopplerStep: 0.161317
INFO: MmwDemo_RFParser_parseCtrlConfig:775: adcStart: 6.000000 us
INFO: MmwDemo_RFParser_parseCtrlConfig:776: slope: 79420.203205 GHz
INFO: MmwDemo_RFParser_parseCtrlConfig:777: startFreq: 76.999999 GHz
INFO: MmwDemo_RFParser_parseCtrlConfig:778: numRangeBins: 76.999939
INFO: MmwDemo_RFParser_parseCtrlConfig:779: rangeStep: 0.118043
INFO: MmwDemo_RFParser_parseCtrlConfig:780: rangeResolution: 0.118043
INFO: MmwDemo_RFParser_parseCtrlConfig:781: ChirpInterval: 0.000031
INFO: MmwDemo_RFParser_parseCtrlConfig:782: RX Antenna 8
INFO: MmwDemo_RFParser_parseCtrlConfig:783: TX Antenna 6
INFO: MmwDemo_RFParser_parseADCBufCfg:1221:  chirpThreshold 1 max = 8,
INFO: MmwDemo_dataPathConfig:2207: App: Issuing Pre-start Config IOCTL (subFrameIndx = 0)
INFO: MmwDemo_dataPathConfig:2230: Prestart Config: ADC bufff size [4096]
INFO: MmwDemo_dataPathConfig:2231: Prestart Config: numChirpsPerFrame [384]
INFO: MmwDemo_dataPathConfig:2232: Prestart Config: numDopplerBins [64]
INFO: MmwDemo_dataPathConfig:2233: Prestart Config: numDopplerChirps [64]
INFO: MmwDemo_dataPathConfig:2234: Prestart Config: numRangeBins [128]
INFO: MmwDemo_dataPathConfig:2235: Prestart Config: numRangeFFTBins [128]
INFO: MmwDemo_dataPathConfig:2236: Prestart Config: numTxAntennas [6]
INFO: MmwDemo_dataPathConfig:2237: Prestart Config: numVirtualAntAzim [40]
INFO: MmwDemo_dataPathConfig:2238: Prestart Config: numVirtualAntElev [8]
INFO: MmwDemo_dataPathConfig:2239: Prestart Config: numVirtualAntennas [48]
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2516: App: DPM Report IOCTL, command = 100
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2527: ============ Heap Memory Stats ============
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2528:                              Size         Used         Free      DPCUsed
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2532:      System Heap(L2)        34864        18224        16640        12352
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2537:                   L3      2654208      1589248      1064960
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2542:         localRam(L2)        50176        18164        32012
INFO: MmwDemo_dataPathStart:2275: App: Issuing DPM_start
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2567: App: DPM Report DPC Started
INFO: MmwDemo_dataPathStart:2288: App: DPM_start Done (post Semaphore_pend on reportFxn reporting start)
INFO: MmwDemo_startSensor:3809: App: MMWave_start Issued
INFO: MmwDemo_startSensor:3817: Debug: Sending rlRfSetLdoBypassConfig with 3 1 0
INFO: MmwDemo_startSensor:3826: Starting Sensor (issuing MMWave_start)
INFO: MMWave_execute:231: MMWave_execute: Semaphore posted. Will execute MMWave_executeLink
INFO: MMWave_executeLink:2420: MMWave_executeLink: will get  node from active list
INFO: MMWave_executeLink:2436: MMWave_executeLink: Execute the spawn function 0x10238071
INFO: MMWave_asyncEventHandler:380: mmwavelink async event handler: BSS Event MsgId: 128 [Device Index: 0x0 Sub Block Id: 0x1012 Sub Block Length: 20]
INFO: MMWave_executeLink:2438: MMWave_executeLink: Finished executing the spawn function 0x10238071
INFO: MMWave_waitIRQStatus:684: MMWave_waitIRQStatus want level 0 got value 0
INFO: MMWave_asyncEventHandler:380: mmwavelink async event handler: BSS Event MsgId: 128 [Device Index: 0x1 Sub Block Id: 0x1012 Sub Block Length: 20]
INFO: MMWave_executeLink:2430: MMWave_executeLink:No other spawn nodes to be processed
INFO: MMWave_startLink:2178:  Start Slave device [2]
INFO: MMWave_startLink:2197:  Start Master device [1]
INFO: MMWave_asyncEventHandler:380: mmwavelink async event handler: BSS Event MsgId: 128 [Device Index: 0x1 Sub Block Id: 0x100b Sub Block Length: 0]
INFO: MMWave_asyncEventHandler:380: mmwavelink async event handler: BSS Event MsgId: 128 [Device Index: 0x0 Sub Block Id: 0x100b Sub Block Length: 0]
INFO: MmwDemo_DPC_ObjectDetection_reportFxn:2516: App: DPM Report IOCTL, command = 115
