Dear TI Representative,
I hope you’re doing great.
I am a Components Engineer at Raytheon Technologies supporting the El Segundo California site and I wonder if you could you please help us identifying if the parts enclosed below are still active (in production) and available for procurement. This is for our obsolescence records, hence a timely response would be greatly appreciated.
Any obsolescence issues?
Please advise.
Any question or concern do not hesitate to contact me.
Thanks a lot for your support.
Have a wonderful day.
Marcelo Suarez
Components Engineer
C: 787-486-9609
Raytheon | An RTX Business
Electrical Components and ECAD (ECE)
PR401 - Pratt & Whitney Puerto Rico
San Antonio Industrial Park
Road 110 North Km 28.8
Aguadilla, PR 00604
Part Number (P/N) | Part Description | Part Status (Active, Obsolete, Pending Obsolescence, NRND, etc.) | Alternate/Drop-in Replacement part (if applicable) | Is the Part number correct? If not, What is the correct P/N? | TI Comments | Raytheon Comments |
5962-1222402VHA | Adjustable Positive LDO Regulator, 1.21V Min, 20V Max, 0.33V Dropout, CDFP10 | |||||
5962-8670404PX | IC, PWM, CURRENT MODE, 1845J TYPE | |||||
5962-8752501MCX | MICROCIRCUITS, DIGITAL, ADVANCED CMOS, DUAL, D-TYPE FLIP FLOP, MONOLITHIC SILICON | |||||
5962-8752501MDX | DUAL D-TYPE FLIP FLOP | |||||
5962-8773901CX | MICROCIRCUITS, LINEAR, QUAD VOLTAGE COMPARATOR, MONOLITHIC SILICON | |||||
5962-8874402FX | MICROCIRCUIT, BIPOLAR, LINE DRIVER, 2 DRIVER(S) | |||||
5962-9218301MDX | MICROCIRCUIT, DIGITAL, ADVANCED CMOS, HEX INVERTER WITH SCHMITT TRIGGERING INPUT, TTL COMPATABLE | |||||
5962L1821001VXC | MICROCIRCUIT, LINEAR, VOLTAGE OUTPUT, UNIDIRECTIONAL MEASUREMENT CURRENT SHUNT MONITOR, MONOLITHIC SILICON | |||||
5962R1723601VXC | MICROCIRCUIT, BICMOS, RADIATION HARDENED, HIGH PERFORMANCE WIDEBAND SYNTHESIZER WITH PHASE SYNCHRONIZATION | |||||
5962R1723701VXC | Microcircuit, Dual Loop Clock, solder dip, lead form | |||||
5962R1820501VXC | Microcircuit, Converter, solder dip and lead form | |||||
5962R1920601VXC | Microcircuit, Precesion, solder dip and lead form | |||||
6385-MBT2907A | TRANSISTOR, PNP, TO-18 | |||||
74ACT16652DL | LOGIC CIRCUIT | |||||
74ALVC125BQ | IC | |||||
74AVC8T245RHLRG4 | 8-Bit Dual-Supply Bus Transceiver with Configurable Voltage-Level Shifting and 3-State Outputs | |||||
74LVC1G3157DCKRG4 | MICROCIRCUIT, SWITCH, ANALOG, DOUBLE-THROW, HIGH-SPEED | |||||
74LVTH18502APM | MICROCIRCUIT | |||||
7600401DX | QD 2-IN SCHMITT TRIG NAND | |||||
ADS1148IRHBT | MICROCIRCUIT, ADC, 16-BIT, 8-CHANNEL, 2KSPS, PGA, REF | |||||
ADS7952SBRHBT | MICROCIRCUIT, CONVERTER, ADC, 4-CH, 12-BIT, 1 MSPS | |||||
ADS7953SRHBR | MICROCIRCUIT, ANALOG TO DIGITAL CONVERTER, 12 BIT,16 CHANNEL | |||||
ADS7953SRHBT | MICROCIRCUIT, ANALOG TO DIGITAL CONVERTER, 12 BIT,16 CHANNEL | |||||
ADS8328IBRSAT | MICROCIRCUIT, ADC, 16 BIT, 500KHZ | |||||
AFE10004RGER | Analog Circuit, 1 Func, 4 Channel | |||||
AM26C31IDR | MICROCIRCUIT, QUAD DIFFERENTIAL LINE DRIVER | |||||
AM26C32IDR | QUAD DIFFERENTIAL LINE RECEIVER | |||||
AMC1301DWV | SP AMP ISOL AMP SINGLE 5.5V 8-PIN SOIC TUBE | |||||
CD74AC151M96 | MICROCIRCUIT, DIGITAL, CMOS | |||||
CDCLVC1102PWR | MICROCIRCUIT, CLOCK BUFFER, HIGH-PERFORMANCE, LVCMOS | |||||
CDCLVP1102RGTT | DIGITAL 1C | |||||
CDCVF857DGG | 2.5-V PHASE-LOCKED-LOOP CLOCK DRIVER | |||||
CDCVF857RHAT | IC, DDR ZERO-DELAY CLOCK BUFFER | |||||
CSD88599Q5DC | MICROCIRCUIT, POWER BLOCK, 60V, HALF-BRIDGE NEXFET | |||||
DAC7802LU | MICROCIRCUIT, ANALOG, CONVERTER | |||||
DAC9881SRGET | MICROCIRCUIT, CONVERTER, DAC, VOLTAGE-OUTPUT, SINGLE-CHANNEL | |||||
DCP010512BP-U | MICROCIRCUIT, MINIATURE, 1W ISOLATED | |||||
DP83867IRRGZR | Industrial temperature, robust gigabit Ethernet PHY transceiver | |||||
DRV592VFP | MICROCIRCUIT, DIGITAL, DRIVER | |||||
DRV593VFPR | IC PWM PWR DRVR HI-EFF 32-HLQFP | |||||
DRV594VFPR | INTEGRATED CIRCUIT | |||||
DRV595DAP | MICROCIRCUIT, PWM POWER DRIVER, HIGH EFFICIENCY | |||||
DRV8704DCPR | MICROCIRCUIT, DRIVER, MOTOR, AUTOMOTIVE, DUAL H-BRIDGE, 52V | |||||
DRV8873HPWPRQ1 | MICROCIRCUIT, DRIVER, MOTOR, AUTOMOTIVE, H-BRIDGE | |||||
DS100BR410SQE/NOPB | MICROCIRCUIT, LOW POWER REPEATER, QUAD-CHANNEL, PB-FREE | |||||
DS25BR120TSD/NOPB | MICROCIRCUIT, 3.125 GBPS LVDS BUFFER, LEAD-FREE | |||||
DS26C31TM/NOPB | IC, LINE TRANSMITTER | |||||
DS26C32A-MD8 | IC CHIP,DIFF LINE RECEIVER,QUAD | |||||
DS26LS31MJ/883 | MICROCIRCUITS,LINEAR-LINE-DRIVER,DIFF | |||||
DS26LS32MJ/883 | QUAD DIFFERENTIAL LINE RECEIVER | |||||
DS32EV100SD/NOPB | IC, PROGRAMMABLE SINGLE EQUALIZER | |||||
DS90C031BTM | LINE DRIVERS, QUAD DIFFERENTIAL, LVDS | |||||
DS90LV019TM | MICROCIRCUIT, ANALOG, RECEIVER | |||||
DS90LV028ATM | LVDS LINE RECEIVERS, DUAL, 3.3V | |||||
DS90LV031ATM/NOPB | MICROCIRCUIT, LINE RECEIVER, DIFFERENTIAL, CMOS, LVDS, QUAD | |||||
DS90LV032ATM | LINE RECEIVER, QUAD DIFFERENTIAL, 3V | |||||
DS90LV032ATM/NOPB | MICROCIRCUIT, LINE RECEIVER, DIFFERENTIAL, CMOS, LVDS, QUAD | |||||
DS90LV110TMTC | BUFFER, CLOCK, 1 TO 10 LVDS | |||||
F28388DPTPS | MICROCIRCUIT, MICROCONTROLLER, 2X C28X+CLA CPU, 176HLQFP | |||||
INA185A1IDRLT | MICROCIRCUIT, AMPLIFIER, CURRENT-SENSE, ULTRA-SMALL | |||||
INA185A2IDRLT | MICROCIRCUIT, AMPLIFIER, CURRENT-SENSE, VOLTAGE OUTPUT | |||||
INA190A1IRSWT | MICROCIRCUIT, AMPLIFIER, PRECISION CURRENT-SENSE | |||||
INA190A3IDCKT | Operational Amplifier, 1 Func, 15uV Offset-Max, PDSO6 | |||||
INA194AIDBVT | IC,CURRENT SHUNT MONITOR,COMMON MODE |
INA225AIDGKR | POWER SUPPLY SUPPORT CKT | |||||
INA225AIDGKT | POWER SUPPLY SUPPORT CKT | |||||
INA240A1PW | MICROCIRCUIT, OP AMP, SINGLE GP 5.5V |
INA293A2QDBVRQ1 | INTEGRATED CIRCUIT | |||||
INA3221AQRGVRQ1 | MICROCIRCUIT, MONITOR, HIGH-SIDE CURRENT/VOLTAGE, VQFN, 26V | |||||
INA4290A1IRGVT | Operational Amplifier, 4 Func, 32uV Offset-Max, PQCC16 | |||||
INA826AID | INSTRUMENTATION AMPLIFIER, RAIL-TO-RAIL OUTPUT, 2.7V TO 36V | |||||
ISO1540D | MICROCIRCUIT, MS LEVEL 2, I2C ISOLATOR, 2 CHANNEL BI-DIRECTIONAL |
ISO1540QDQ1 | BIDIRECTIONAL ISOLATOR, DIGITAL, LOW-POWER, SOIC-8 |
ISO7220CDR | IC,ISOLATOR,CAPACITIVE,2CH,25MBPS,SOIC8 | |||||
ISO7220MDRG4 | DUAL-CHANNEL (2 FORWARD) DIGITAL ISOLATOR, 150 MBPS DATA RATE | |||||
ISO7741FDBQ | SPECIALTY ANALOG CIRCUIT, PDSO16 | |||||
ISO7742DBQ | MICROCIRCUIT, ISOLATOR, DIGITAL, QUAD-CHANNEL, HIGH-SPEED | |||||
JM38510/10901BPA | IC, TIMING CIRCUIT, THR | |||||
LF147 DIE | IC, DIE | |||||
LF156 MD8 | MICROCIRCUITS, LINEAR - CHIPS, OPERATIONAL AMPLIFIER, JFET I | |||||
LM111 MD8 | COMPARATOR, VOLTAGE | |||||
LM111WG/883 | COMPARATOR | |||||
LM119 DIE | COMPARATOR, DUAL DIFFERENTIAL | |||||
LM120H-12 | 3-TERMINAL NEGATIVE REGULATOR | |||||
LM124AW/883 | OPERATIONAL AMPLIFIER | |||||
LM124AWG/883 | LOW POWER QUAD OPERATIONAL AMPLIFIER | |||||
LM124D | MICROCIRCUIT, ANALOG, OPNL AMP: AR1 | |||||
LM137H/883 | MICROCIRCUIT, VOLTAGE REGULATOR (U8) | |||||
LM139 | IC, QUAD VOLTAGE | |||||
LM139 MD8 | IC CHIP,QUAD COMPARATOR,LM139 | |||||
LM139AWG/883 | MICROCIRCUIT, ANALOG, COMPARATOR | |||||
LM139J | I.C.COMPARATOR | |||||
LM139MD8 | IC CHIP,QUAD COMPARATOR,LM139 | |||||
LM20133MH/NOPB | MICROCIRCUIT, SYNCHRONOUS BUCK REGULATOR, 3A, LEAD FREE | |||||
LM20145MH/NOPB | MICROCIRCUIT, SYNCHRONOUS BUCK REGULATOR, 5A, LEAD FREE | |||||
LM2901M/NOPB | IC, COMPARATOR | |||||
LM2902M/NOPB | MICROCIRCUIT, LINEAR - OPERATIONAL AMPLIFIER, QUAD LOW POWER | |||||
LM2903M/NOPB | MICROCIRCUIT, COMPARATOR, LOW POWER, LOW OFFSET VOLTAGE QUAD | |||||
LM2903N/NOPB | MICROCIRCUIT, COMPARATOR, DUAL, LOW-POWER,LOW-OFFSET VOLTAGE | |||||
LM2904MX/NOPB | MICROCIRCUIT,DUAL OP AMP | |||||
LM2940LD-5.0/NOPB | VOLTAGE REGULATOR | |||||
LM2990S-5.0/NOPB | MICROCIRCUIT, ANALOG, REGULATOR | |||||
LM2991GW-QML | POWER CONTROL, (LM2991) NEGATIVE VOLTAGE REG | |||||
LM2991-MD8 | MICROCIRCUIT, NEGATIVE VOLTAGE REG (DIE) | |||||
LM2991T/NOPB | MICROCIRCUIT, ADJ, LDO REGULATOR, 1V | |||||
LM335M | DIODE, (LM335) TEMPERATURE SENSOR | |||||
LM39401S-3.3 | 1A LOW DROPOUT REGULATOR FOR 5V TO 3.3V CONVERSION | |||||
LM4041BIM7-1.2/NOPB | MICROCIRCUIT, VOLTAGE REFERENCE | |||||
LM4050AEM3-10/NOPB | 0-ppm/°C precision micropower shunt voltage reference | |||||
LM50CIM3 | MICROCIRCUIT, SINGLE-SUPPLY CENTIGRADE TEMPERATURE SENSOR | |||||
LM56BIMX/NOPB | MICROCIRCUIT, THERMOSTAT, DUAL OUTPUT, PRECISION LOW POWER | |||||
LM60CIM3X/NOPB | MICROCIRCUIT, TEMPERATURE SENSOR, 2.7V, 3 PINS SOT-23 | |||||
LM6144AIM | MICROCIRCUIT,ANALOG,OPNL,AMP | |||||
LM7332MA/NOPB | DUAL OP-AMP, 5000UV OFFSET-MAX, 19.9MHZ BAND WIDTH, PDSO8 | |||||
LM75BIM-5/NOPB | IC, SIMULTANEOUS A/D CONVERTER | |||||
LM75BIMM-3/NOPB | IC, TEMP SENSOR, I2C, LM75B, 10 BIT, +- 2 DEGREE C | |||||
LM8261M5 | OP-AMP, 7000 UV OFFSET-MAX, 24 MHZ BAND WIDTH, PDSO5 | |||||
LMC6482MMD8 | AMPLIFIER | |||||
LMG1210RVRT | MICROCIRCUIT, DRIVER, GAN FET, 3-A HALF-BRIDGE | |||||
LMH0341SQE/NOPB | IC, SDI SERIALIZE RECEIVER | |||||
LMH0344SQE/NOPB | IC, SDI CABLE EQUALIZER | |||||
LMH1219RTWR | MICROCIRCUIT, ADAPTIVE CABLE EQUALIZER, LOW POWER, ULTRA HD | |||||
LMH1219RTWT | MICROCIRCUIT, ADAPTIVE CABLE EQUALIZER, LOW POWER, ULTRA HD | |||||
LMH5401IRMST | MICROCIRCUIT, OPERATIONAL AMPLIFIER, 8-GHZ, LOW-NOISE, LOW-P | |||||
LMH6639MF/NOPB | RAIL-TO-RAIL OUTPUT AMPLIFIER W/ DISABLE | |||||
LMK1D1204RGTT | Low Skew Clock Driver, 8 True Output(s), 0 Inverted Output(s), PQCC16 | |||||
LMV431BIMF/NOPB | Two Terminal Voltage Reference, 1 Output, 1.24V, Trim/Adjustable, BIPolar, PDSO3 | |||||
LMV842QMA/NOPB | INTEGRATED CIRCUIT | |||||
LMV844QMA/NOPB | INTEGRATED CIRCUIT | |||||
LMX2595RHAT | MICROCIRCUIT - 19-GHZ RF SYNTHESIZER WITH PHASE SYNCHRONIZA | |||||
LMX2615W-MPR | MICROCIRCUIT,WIDEBAND SYNTHESIZER WITH PHASE SYNCHRONIZATION | |||||
LMZ12003TZ-ADJ/NOPB | IC, REGULATOR MODULE, 3A, SMT | |||||
LMZ14202EXTTZ/NOPB | MICROCIRCUIT, POWER MODULE, STEP-DOWN, 42 V MAXIMUM INPUT,2A | |||||
LP2998MR/NOPB | IC CONV DDR DDR2 DDR3 8S0PWRPAPD | |||||
LP3852EMP-5.0/NOPB | LDO REGULATOR_ | |||||
LP3856ES-1.8/NOPB | LDO REGULATOR (1.8, 3A) | |||||
LP3856ES-2.5/NOPB | LDO POS REGULATOR | |||||
LP3856ES-3.3/NOPB | LDO REGULATOR (3.3V, 3A) | |||||
LP38690SD-3.3/NOPB | 3.3V FIXED POSITIVE LDO REGULATOR, 1V DROPOUT, PDSO6 | |||||
LP38691DT-3.3/NOPB | MICROCIRCUIT, LINEAR REGULATOR, LOW DROPOUT CMOS, 3.3VDC | |||||
LP38691QSDX-3.3/NOPB | INTEGRATED CIRCUIT | |||||
LP38691SD-3.3/NOPB | MICROCIRCUIT, LINEAR REGULATOR, LOW DROPOUT CMOS, 3.3VDC | |||||
LP38691SD-5.0/NOPB | MICROCIRCUIT, LINEAR REGULATOR, LOW D | |||||
LP38692SD-2.5/NOPB | IC REG | |||||
LP3872EMP-2.5/NOPB | LDO REGULATOR (2.5V, 1500MA) | |||||
LP3874EMP-3.3/NOPB | I.C. LINEAR REGULATOR, 3.3V. 8A | |||||
LP3874EMP-5.0/NOPB | I.C. LINEAR REGULATOR, 5.0V. 8A | |||||
LP3879MR-1.0/NOPB | IC, VOLT REG, FIXED, 800MA, SMT | |||||
LP3962EMP-1.8/NOPB | MICROCIRCUIT, LDO REGULATOR, 1.8V, 0.7V VOLTAGE DROP | |||||
LP3965ES-2.5/NOPB | INACTIVE - VOLT REG, SMT, 3.0A, LDO | |||||
LP3990SD-1.5/NOPB | REGULATOR. 4.5V, SM | |||||
OPA2211AIDRGT | MICROCIRCUIT, AMPLIFIER, PRECISION OPERATIONAL | |||||
OPA2277U | MICROCIRCUIT, ANALOG, OPERATIONA | |||||
OPA2328DGKT | MICROCIRCUIT, OPERATIONAL AMPLIFIER, PRECISION, 40-MHZ | |||||
OPA2356AID | MICROCIRCUIT, ANALOG, OPERATIONA | |||||
OPA2541BM | DUAL HIGH POWER OPERATIONAL AMPLIFIER | |||||
OPA320AIDBVT | OP-AMP, 150UV OFFSET-MAX, 20MHZ BAND WIDTH, PDSO5 | |||||
OPA3875IDBQ | IC VIDEO MUX TRIPLE 2:1 16SS0P | |||||
OPA4140AID | AMPLIFIER, OPERATIONAL, JFET, QUAD, RAIL-TO-RAIL OUTPUT | |||||
OPA4171AQPWRQ1 | MICROCIRCUIT, OP AMP, QUAD, +/- 18V/36V, AUTOMOTIVE, 14 TSSP | |||||
OPA4830IPWRG4 | MICROCIRCUIT, QUAD OPAMP | |||||
OPA4990IPWR | MICROCIRCUIT,OPERATIONAL AMPLIFIER,RAIL-TO-RAIL INPUT/OUTPUT | |||||
OPA548FKTWT | MICROCIRCUIT, ANALOG, OPERATIONA | |||||
OPA627AU | MICROCIRCUIT, ANALOG, OPNL AMP | |||||
PTH04T240WAD | MICROCIRCUIT, ANALOG, REGULATOR | |||||
PTH05T210WAS | INACTIVE - DC TO DC CONVERTER | |||||
PTH08T220WAD | IC, 1V 16A SWITCHING REGULATOR | |||||
PTH08T220WAS | INACTIVE - DC TO DC CONVERTER | |||||
REF2025AIDDCT | MICROCIRCUIT | |||||
REF2030AIDDCT | VOLTAGE REFERENCE 3.0V | |||||
REF3233AIDBV | MICROCIRCUIT, LOW-DROPOUT PRECISION SERIES VOLTAGE REFERENCE | |||||
REF3233AIDBVR | MICROCIRCUIT, VOLTAGE REFERENCE | |||||
REF3233AIDBVRG4 | MICROCIRCUIT, VOLTAGE REFERENCE | |||||
REF3233AIDBVT | MICROCIRCUIT, VOLTAGE REFERENCE | |||||
REF3430MDBVTEP | REGULATOR,VOLTAGE - VOLTAGE REFERENCE, 3V, CMOS, PDSO6 | |||||
REF5025IDGKT | MICROCIRCUIT, PRECISION VOLTAGE REFERENCE, LOW-NOISE | |||||
REG1117FA/500 | VOLTAGE REGULATOR | |||||
SN54ALS645AJ | BUS TRANSCEIVER | |||||
SN54S140J | DUAL 4-INPUT POSITIVE-NAND 50-OHM LINE DRIVER | |||||
SN65HVD01DRCT | MICROCIRCUIT | |||||
SN65HVD10DR | MICROCIRCUIT, TRANSCEIVER/BUFFER/DRIVER/FLIP FLOP | |||||
SN65HVD10DRG4 | LINE TRANSCEIVER, PDSO8 | |||||
SN65HVD78DR | MICROCIRCUIT, TRANSCEIVER, RS-485, ESD PROTECTION, 3.3V | |||||
SN65LVDM050PW | MICROCIRCUIT, ANALOG, RECEIVER | |||||
SN65LVDM1676DGG | MICROCIRCUIT, ANALOG, RECEIVER | |||||
SN65LVDM1677DGG | MICROCIRCUIT, TRANSCEIVERS, DIFFERENTIAL LINE, HIGH-SPEED | |||||
SN65LVDM1677DGGR | MICROCIRCUIT, TRANSCEIVERS, DIFFERENTIAL LINE, HIGH-SPEED | |||||
SN65LVDM176D | MICROCIRCUIT, ANALOG, TRANSCEIVER, LINE, DIFFERENTIAL | |||||
SN65LVDM176DGK | MICROCIRCUIT, ANALOG, INTERFACE | |||||
SN65LVDM179DGK | MICROCIRCUIT, ANALOG, RECEIVER | |||||
SN65LVDS048APWR | IC, LVDS QUAD DIFFERENTIAL LINE RECEIVER | |||||
SN65LVDS048APWRG4 | MICROCIRCUIT, LVDS QUAD DIFFERENTIAL LINE RECEIVER, PB FREE | |||||
SN65LVDS050PWR | MICROCIRCUIT | |||||
SN65LVDS100DGK | MICROCIRCUIT, ANALOG, INTERFACE | |||||
SN65LVDS104D | MICROCIRCUIT,CMOS,4-PORT LOW VOLTAGE | |||||
SN65LVDS117DGG | MICROCIRCUIT, LINEAR, DUAL 8-PORT, LVDS REPEATER |
SN65LVDS179DGKG4 | MICROCIRCUIT | |||||
SN65LVDS179DGKRG4 | Single full-duplex LVDS transceiver | |||||
SN65LVDS1DBVR | IC, DIFFERENTIAL LINE DRIVER | |||||
SN65LVDS2DBVR | IC,LVDS RECEIVER,HIGH SPEED | |||||
SN65LVDS31DG4 | 400-Mbps LVDS quad high speed differential driver | |||||
SN65LVDS31PWRG4 | MICROCIRCUIT, LINE DRIVERS, HIGH-SPEE | |||||
SN65LVDS32D | HIGH SPEED DIFFERENTIAL LINE RECEIVER | |||||
SN65LVDS3487D | MICROCIRCUIT, ANALOG, INTERFACE | |||||
SN65LVDS348PW | QUAD LINE RECEIVER, PDSO16 | |||||
SN65LVDS387DGG | 16 BIT LINE DRIVER | |||||
SN65LVDS389DBT | OCTAL LINE DRIVER, PDSO38 | |||||
SN65LVDS390PW | MICROCIRCUIT, ANALOG, RECEIVER | |||||
SN65LVDS391D | MICROCIRCUIT, ANALOG, DRIVER | |||||
SN65LVDS391PW | LVDS LINE DRIVERS, QUAD, 3.3V | |||||
SN65LVDS4RSET | 296-29257-1-ND TI SN65LVDS4RSET | |||||
SN65LVDT2DBV | MICROCIRCUIT, ANALOG, RECEIVER | |||||
SN65LVDT33D | MICROCIRCUIT, ANALOG, RECEIVER: U6,U8-U10,U12-U13 | |||||
SN65LVDT33PW | MICROCIRCUIT, DIFFERENTIAL LINE RECEIVER, HIGH-SPEED | |||||
SN65LVELT23DGK | MICROCIRCUIT, CLOCK DRIVER | |||||
SN74ABT125PWR | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74ABT126D | QUADRUPLE BUS BUFFER GATES WITH 3-STATE OUTPUTS | |||||
SN74ABT16245ADGVR | MICROCIRCUIT, 16-BIT BUS TRANSCEIVERS WITH 3- | |||||
SN74AC00PWR | AC SERIES, QUAD 2-INPUT NAND GATE, PDSO14 | |||||
SN74AHC1G125DCK | Bus Driver, AHC Series, 1-Func, 1-Bit, True Output, CMOS, PDSO5 | |||||
SN74AHCT04RGYR | HEX INVERTER | |||||
SN74AHCT1G08DCKR | AHCT/VHCT/VT SERIES, 2-INPUT AND GATE, PDSO5 | |||||
SN74AHCT1G125DBVR | BVR IC BUFFER | |||||
SN74AHCT1G125DCKR | IC, SINGLE BUFFER GATE | |||||
SN74AHCT1G125DCKT | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74ALVC00PWR | QUAD 2-INPUT POSITIVE NAND GATE | |||||
SN74ALVC125PW | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74ALVCH162827VR | INACTIVE - LVTTL BUFFER | |||||
SN74ALVCH162841GR | ALVC/VCX/A SERIES, DUAL 10-BIT DRIVER, TRUE OUTPUT | |||||
SN74ALVCH244PW | MICROCIRCUIT, OCTAL BUFFER/DRIVER WITH 3-STATE OUTPUTS | |||||
SN74ALVCH244PWR | BUFFER/DRIVER, OCTAL, WITH 3-STATE OUTPUTS | |||||
SN74AUC17RGYR | DIGITAL STD | |||||
SN74AUP1G08DCKR | IC, SINGLE 2 INPUT POS AND GATE | |||||
SN74AUP2G17DCKR | MICROCIRCUIT, BUFFER,INVERTER,SCHMITT-TRIGGER,DUAL,LOW-POWER | |||||
SN74AVC4T245PWR | IC, 4-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLT | |||||
SN74AVCH2T45DCTT | TRANSCEIVER, BUS, 2-SUPPLY, CONFIGURABLE, LEVEL-SHIFTING, | |||||
SN74AXC8T245RHLR | 8-BIT DUAL-SUPPLY BUS TRANSCEIVER, VQFN (24) | |||||
SN74CB3Q3253DBQR | MICROCIRCUIT, BUS SWITCH, DUAL 1 OF 4 FET MUX DEMUX | |||||
SN74CB3T16211DGGR | MICROCIRCUIT, 24-BIT FET BUS SWITCH, 3.3V | |||||
SN74CB3T3245PW | MICROCIRCUIT, 8 BIT, LOW VOLTAGE FET BUS SWITCH WITH 5V TOLE | |||||
SN74CBT16245CDL | MICROCIRCUIT, DIGITAL, TRANSCEIV | |||||
SN74CBTD3384CDBQR | MCKT, FET BUS SWITCH, LEVEL SHIFTING | |||||
SN74CBTLV1G125DCKR | LOW VOLTAGE SINGLE FET BUS SWITCH | |||||
SN74LV1T34DCKR | MICROCIRCUIT, LOGIC LEVEL SHIFTER, CMOS, SINGLE BUFFER GATE | |||||
SN74LV541APWR | DRIVER, OCTAL BUFFERS WITH 3-STATE OU | |||||
SN74LV541ARGYR | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74LVC06APW | HEX INVERTER BUFFER/DRIVER WITH OPEN-DRAIN OUTPUTS | |||||
SN74LVC07AD | LVC/LCX/Z SERIES, HEX 1-INPUT NON-INVERT GATE, PDSO14 | |||||
SN74LVC07APWR | MICROCIRCUIT, DIGITAL, LOGIC GATE | |||||
SN74LVC07APWTG4 | MICROCIRCUIT, HEX BUFFER/DRIVER | |||||
SN74LVC08AMPWREP | LVC/LCX/Z SERIES, QUAD 2-INPUT AND GATE, PDSO14 | |||||
SN74LVC16244ADGGR | I C , BUFFER/DRIVER 16 BIT | |||||
SN74LVC16373ADGGR | 16-BIT TRANSPARENT D-TYPE LATCH | |||||
SN74LVC1G02DCKRG4 | IC GATE NOR 1CH 2-INP SC70-5 | |||||
SN74LVC1G04DCKRG4 | MICROCIRCUIT, GATE, SINGLE INVERTER | |||||
SN74LVC1G04DCKT | MICROCIRCUIT, DIGITAL, LOGIC GAT | |||||
SN74LVC1G04DCKTG4 | MICROCIRCUIT, GATE, SINGLE INVERTER | |||||
SN74LVC1G07DCK | MICROCIRCUIT, SINGLE BUFFER/DRIVER WITH OPEN-DRAIN OUTPUT | |||||
SN74LVC1G08DCK | MICROCIRCUIT, SINGLE 2-INPUT POSITIVE | |||||
SN74LVC1G08DRLR | IC,SINGLE 2-INPUT AND GATE | |||||
SN74LVC1G125 | MICROCIRCUIT | |||||
SN74LVC1G125DBVR | MICROCIRCUIT, LVC/LCX/Z SERIES, 1-BIT DRIVER, TRUE OUTPUT, PDSO5 | |||||
SN74LVC1G125DBVT | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74LVC1G17DCKR | MICROCIRCUIT, DIGITAL, LOGIC GAT | |||||
SN74LVC1G34DCKR | IC | |||||
SN74LVC1G373DCKR | MICROCIRCUIT DIGITAL - LATCH D TYPE, TRI -STATE OUTPUT, SING | |||||
SN74LVC1GX04DBVR | CRYSTAL OSCILLATOR DRIVER | |||||
SN74LVC1GX04DBVT | CRYSTAL OSCILLATOR DRIVER | |||||
SN74LVC244APWR | OCTAL BUFFER/DRIVER WITH TRI-STATE; PB FREE | |||||
SN74LVC244APWT | MICROCIRCUIT, DIGITAL, DRIVER | |||||
SN74LVC2G04DBV | MICROCIRCUIT, DUAL INVERTER GATE | |||||
SN74LVC2G04DBVR | MICROCIRCUIT, DUAL INVERTER GATE | |||||
SN74LVC2G04DCKR | MICROCIRCUIT,DIGITAL,LOGIC GATE | |||||
SN74LVC2G04DCKT | DUAL INVERTER GATE | |||||
SN74LVC2G07DCKT | MICROCIRCUIT, DUAL BUFFER/DRIVER WITH OPEN-DRAIN OUTPUTS | |||||
SN74LVC2G08DCURG4 | IC, AND GATE | |||||
SN74LVC2G14DBVTG4 | Inverter, LVC/LCX/Z Series, 2-Func, 1-Input, CMOS, PDSO6 | |||||
SN74LVC2G17DCKRG4 | 2-ch, 1.65-V to 5.5-V buffers with Schmitt-Trigger inputs | |||||
SN74LVC2G34DBV | MICROCIRCUIT, DUAL BUFFER GATE | |||||
SN74LVC2G34DBVR | MICROCIRCUIT, DIGITAL, LOGIC GATE | |||||
SN74LVC2G34DCK | MICROCIRCUIT, DUAL BUFFER GATE | |||||
SN74LVC2G34DCKRG4 | INTEGRATED CIRCUIT | |||||
SN74LVC2T45DCUR | DUAL-BIT DUAL-SUPPLY BUS TRANSCEIVER W/ CONFIGURABLE VOLT TRANSL AND 3-STATE O/P | |||||
SN74LVC3G14DCUR | MICROCIRCUIT, GATE, INVERTER, TRIPLE SCHMITT TRIGER | |||||
SN74LVC3G17DCUR | MICROCIRCUIT | |||||
SN74LVC3G34DCURG4 | MICROCIRCUIT, TRIPLE BUFFER GATE | |||||
SN74LVC3G34DCUT | MICROCIRCUIT, DIGITAL, LOGIC GAT | |||||
SN74LVC4245ADBR | MCKT, LINE DRIVER | |||||
SN74LVC541AQPWRQ1 | DIGITAL_STD | |||||
SN74LVCR16245ADLR | MICROCIRCUIT, DIGITAL, 16-BIT BUS TRANSCEIVER | |||||
SN74LVTH16245ADGG | MICROCIRCUIT, DIGITAL, TRANSCEIVER | |||||
SN74LVTH16245ADGGR | MICROCIRCUIT, DIGITAL, TRANSCEIVER | |||||
SN74LVTH16245ADL | MICROCIRCUIT, 3.3V ABT, 16 BIT BUFFER/DRIVER W/ 3ST | |||||
SN74LVTH240DBR | IC, OCTAL INVERTING BUFFER | |||||
SN74LVTH244APWR | IC, 3.3-V ABT OCTAL BUFFERS/DRIVERS WITH 3-ST | |||||
SN75471D | DUAL PERIPHERAL DRIVER | |||||
SNJ5402W | MICROCIRCUITS, DIGITAL -- LOGIC GATE, QUAD 2-INPUTK NOR | |||||
SNJ5404W | IC, TTL, HEX INVERT | |||||
SNJ5407J | INTEGRATED CIRCUIT | |||||
SNJ54166W | MICROCIRCUITS, DIGITAL -- SHIFT REGISTER, PARALLEL-IN, SERIA | |||||
SNJ5425W | MICROCCIRCUITS, DIGITAL -- DUAL 4 INPUT WITH STROBE, GATE | |||||
SNJ5430W | IC, TTL, GATE, NAND | |||||
SNJ5451W | MICROCIRCUITS, DIGITAL -- TTL, LOGIC GATE, DUAL INPUT AND/OR | |||||
SNJ54AC11FK | GATE, (SN54AC11) TRIPLE 3-INPUT AND GATE | |||||
SNJ54AC11W | AND GATE | |||||
SNJ54ALS244CW | ALS SERIES, OCTAL 1-BIT DRIVER, TRUE OUTPUT, CDFP20 | |||||
SNJ54LS166AW | MICROCIRCUIT, DIGITAL -- 8 BIT SHIFT | |||||
SNJ54LS174W | MICROCIRCUITS, DIGITAL -- FLIP-FLOP, HEX D-TYPE, EDGE TRIGGER | |||||
SNJ54LS85J | MICROCIRCUIT, ANALOG, ARITHMETIC CIRCUIT | |||||
SNJ54LS85W | MICROCIRCUITS, DIGITAL -- 4 BIT MAGNITUDE COMPARATOR | |||||
SNJ54S140W | MICROCIRCUIT, LINEAR -- LINE DRIVER, | |||||
SNJ54S157J | MICROCIRCUIT, DIGITAL, MULTIPLEXER | |||||
SNJ54S157W | INTEGRATED CIRCUITS, MULTIPLEXER | |||||
SNJ54S174W | MICROCIRCUITS, DIGITAL -- FLIP-FLOP, SCHOTTKY, TTL | |||||
SNJ54S20W | MICROCIRCUITS DIGITAL--SCHOTTKY TTL | |||||
SNJ54S260W | MICROCIRCUITS, DIGITAL -- DUAL 5-INPUT NOR, SCHOTTKY | |||||
SNJ55114W | MICROCIRCUITS, DIGITAL--DRIVER,LINE, DIFFERENTIAL, DUAL | |||||
SNJ55115W | MICROCIRCUIT, DIGITAL -- LINE RECEIVER, DIFFERENTIAL, DUAL | |||||
TB5R2D | MICROCIRCUIT, RECEIVER, PECL, QUAD, DIFFERENTIAL | |||||
TCA6416APWR | MICROCIRCUIT, SMBUS I/O EXPANDER, LOW-VOLTAGE, 16 BIT |
TCA9406DCTR | MICROCIRCUIT, BI-DIRECTIONAL VOLTAGE LEVEL TRANSLATOR | |||||
TCA9803DGKR | MICROCIRCUIT, I2C BUS BUFFER | |||||
TL1431MJG | PRECISION PROGRAMMABLE REFERENCE | |||||
TL331IDBVR | MICROCIRCUIT | |||||
TL331IDBVT | MICROCIRCUIT, ANALOG, STANDARD |
TLC555MJGB | MICROCIRCUIT, TIMER | |||||
TLC7701IPWR | SUPPLY VOLTAGE SUPERVISORS, 1.1V THRESHOLD: U1,U3,U5,U7,U9,U11,U13,U15,U17 | |||||
TLE2062MD | C J-FET INPUT HIGH OUT DRIVE | |||||
TLE2141AID | OP-AMP, 1000UV OFFSET-MAX, 6MHZ BAND WIDTH, PDSO8 | |||||
TLE2142AID | DUAL OP-AMP, 1400UV OFFSET-MAX, 6MHZ BAND WIDTH, PDSO8 | |||||
TLK1211RCP | MICROCIRCUIT, ETHERNET TRANSCEIVERS, 1.25GBPS, CMOS, PQFP64 | |||||
TLV1701AIDBVT | MICROCIRCUIT, COMPARATOR, MICROPOWER | |||||
TLV2264AMWB | IC, OP AMP | |||||
TLV2354MWB | QUADRUPLE LOW VOLTAGE DIFFERENTIAL CO | |||||
TLV2548QDW | MICROCIRCUIT, 8-CH 12-BIT, ADC, SERIAL ACCESS | |||||
TLV3011AIDBVR | IC,COMPARATOR,1.8V | |||||
TLV3011AIDBVT | MICROCIRCUIT, ANALOG, COMPARATOR | |||||
TLV376IDBVR | MICROCIRCUIT, AMPLIFIER, OPERATIONAL, PRECISION, LOW-NOISE | |||||
TLV376IDBVT | MICROCIRCUIT, AMPLIFIER, OPERATIONAL, PRECISION, LOW-NOISE | |||||
TLV5616IDGK | MICROCIRCUIT, ANALOG, CONVERTER | |||||
TLV5616IDGKR | MICROCIRCUIT, ANALOG, CONVERTER | |||||
TLV6710DDCT | Comparator, 2 Func, 2000uV Offset-Max, 28100ns Response Time, PDSO6 | |||||
TMCS1108A2BQDRQ1 | MICROCIRCUIT, CURRENT SENSOR, HALL-EFFECT | |||||
TMCS1108A3BQDRQ1 | MICROCIRCUIT, CURRENT SENSOR, HALL-EFFECT | |||||
TMP112AIDRLT | DIGITAL TEMP SENSOR-SERIAL, 12BIT(S), 1CEL, RECTANGULAR, SURFACE MOUNT | |||||
TMP116NAIDRVT | INTEGRATED CIRCUIT | |||||
TMP421AIDCNR | MICROCIRCUIT, TEMPERATURE SENSOR | |||||
TMS320F28379DZWTS | MICROCIRCUIT, MICROCONTROLLER, DUAL CORE, 32BIT, -40 TO 125 | |||||
TMS32C6415EGLZA5E0 | MICROCIRCUIT, DIGITAL SIGNAL PROCESSOR, FIXED POINT | |||||
TMUX4157NDCKR | INTEGRATED CIRCUIT | |||||
TPS22810DRVT | MICROCIRCUIT, LOAD SWITCH, SINGLE CHANNEL, 2.7V TO 18V, 2A | |||||
TPS22965DSGR | 5.7-V, 6-A, 16-mΩ load switch with adj. rise time and optional output discharge | |||||
TPS22965DSGT | 1-CHANNEL, SGL POLE SGL THROW SWITCH, PDSO8 | |||||
TPS3307-25DR | MICROCIRCUIT, POWER MANAGEMENT | |||||
TPS3307-33DGN | MICROCIRCUIT, SUPERVISOR, PROCESSOR, 4.55V, 2.93V, ADJ | |||||
TPS3700QDDCRQ1 | MICROCIRCUIT, VOLTAGE WINDOW COMPARATOR | |||||
TPS3702CX33DDCT | MICROCIRCUIT, MONITOR, VOLTAGE, HIGH-ACCURACY, 3.3V | |||||
TPS3801K33DCK | MICROCIRCUIT, ANALOG, POWER MANA | |||||
TPS3808G01DRVR | SUPERVISORY CIRCUIT, PROGRAMMABLE-DELAY, ADJUSTABLE VOLTAGE | |||||
TPS3808G01QDRVRQ1 | MICROPROCESSOR, SUPERVISORY CIRCUIT | |||||
TPS3808G12DBVT | MICROCIRCUIT, ANALOG, POWER MANA | |||||
TPS3808G18DBVT | MICROCIRCUIT, LOW QUIESCENT CURRENT, PROGRAMMABLE DELAY SUPE | |||||
TPS3808G30DBVR | INACTIVE - IC, POWER-ON-RESET | |||||
TPS3808G33DBV | POWER SUPPLY SUPPORT CKT, 1-CHANNEL, PDSO6 | |||||
TPS3808G33MDBVREP | MICROCIRCUIT, SUPERVISORY CIRCUIT, PROGRAMMABLE DELAY | |||||
TPS3836K33DBVTG4 | IC,VOLT DETECTOR,FIXED,+2.93V,TSOP,5PIN,PLASTIC | |||||
TPS3839G33DBZR | MICROCIRCUIT, SUPPLY VOLTAGE SUPERVISOR. ULTRALOW POWER, SOT | |||||
TPS3840PL48DBVR | MICROCIRCUIT, SUPERVISOR, HIGH INPUT VOLTAGE, 1-CH, RESET | |||||
TPS386000RGPT | MICROCIRCUIT, ANALOG, VOLTAGE SUPERVISOR, QUAD | |||||
TPS40077PWP | 2 A SWITCHING CONTROLLER, 1000 KHZ SWITCHING FREQ-MAX, PDSO16 | |||||
TPS51116PWP | 6 A SWITCHING CONTROLLER, PDSO20 | |||||
TPS51116RGER | MCKT, CONTROLLER, SYNCHRONOUS, DDR | |||||
TPS51206DSQT | MICROCIRCUIT, REGULATOR, DDR TERMINATION | |||||
TPS54313 | IC POWER CONTROLLER | |||||
TPS54612QPWPRQ1 | 12 A SWITCHING REGULATOR, 762 KHZ SWITCHING FREQ-MAX, PDSO28 | |||||
TPS54615QPWPRQ1 | 12 A SWITCHING REGULATOR, 762 KHZ SWITCHING FREQ-MAX, PDSO28 | |||||
TPS54616QPWPRQ1 | 2 A SWITCHING REGULATOR, 762 KHZ SWITCHING FREQ-MAX, PDSO28 | |||||
TPS54620RGYR | CONVERTER, 4.5V TO 17V INPUT, 6A SYNCHRONOUS STEP-DOWN | |||||
TPS54620RGYT | CONVERTER, DC-DC SINGLE STEP DOWN 1.6V TO 17V | |||||
TPS54672PWP | 6-A OUTPUT, ACTIVZ BUS TERM SYNCH PWM | |||||
TPS62080ADSGT | MICROCIRCUIT, DC/DC CONVERTER, STEP-DOWN, SYNCHRONOUS, 1.2A | |||||
TPS62133AQRGTRQ1 | Buck Switching Regulator IC Positive Fixed 5V 1 Output 3A 16-VFQFN Exposed Pad | |||||
TPS62133RGTR | Buck Switching Regulator IC Positive Fixed 5V 1 Output 3A 16-VFQFN Exposed Pad | |||||
TPS628512DRLR | MICROCIRCUIT, REGULATOR, SWITCHING, STEP-DOWN, CURRENT-MODE | |||||
TPS70458PWP | VOLTAGE REGULATOR | |||||
TPS72301DBVR | Adjustable Negative LDO Regulator, -9.75V Min, -1.2V Max, 0.5V Dropout, CMOS, PDSO5 | |||||
TPS72301DBVRG4 | MICROCIRCUIT, REGULATOR, LINEAR, LDO, ADJUSTABLE NEGATIVE | |||||
TPS73118MDBVREP | MICROCIRCUIT, 1.8 V FIXED POSITIVE LDO REGULATOR, 0.1 V DROPOUT, PDSO5 | |||||
TPS73218DBVR | 250MA LOW DROPOUT REGULATOR | |||||
TPS73233DBVT | INACTIVE - 3.3V, 250MA LOW DROPOUT REGULATOR | |||||
TPS73601MDRBREP | ANALOG IC | |||||
TPS73625DBV | MICROCIRCUIT, REG | |||||
TPS74401KTWR | MICROCIRCUIT, REGULATOR, LINEAR, LDO | |||||
TPS74401RGRT | 0.796V-3.6V ADJUSTABLE POSITIVE LDO REGULATOR, 0.195V DROPOUT, PQCC20 | |||||
TPS74401RGWT | IC, LDO REGULATOR, 3 AMP | |||||
TPS74901RGWT | MICROCIRCUIT, LINEAR REGULATOR, 3.0A LOW-DROPOUT | |||||
TPS75215QPWP | REGULATOR, | |||||
TPS76318DBVR | MICROCIRCUIT, REGULATOR, LINEAR, LOW-DROPOUT, 150-MA, 1.8V | |||||
TPS76318DBVT | MICROCIRCUIT, REGULATOR, LINEAR, LOW-DROPOUT, 150-MA, 1.8V |
TPS76333DBVT | REGULATOR, LDO, POSITIVE, FIXED, 3.3V, 0.5V DROPOUT, PDS05 | |||||
TPS7A3001DGNR | 200MA, ULTRALOW-NOISE, NEGATIVE VOLTAGE REGULATOR, ADJUSTABLE | |||||
TPS7A4700RGWT | MICROCIRCUIT, FIXED POSITIVE LDO REGULATOR, 0.45 V DROPOUT, PQCC20 | |||||
TPS7A4701RGWR | IC,VOLT REGULATOR,LDO,POSITIVE,ADJ,LO=1A | |||||
TPS7A5201WQRTKRQ1 | MICROCIRCUIT, ADJUSTABLE, VOLTAGE REGULATOR | |||||
TPS7A5301WQRTKRQ1 | MICROCIRCUIT, REGULATOR, LDO, POSITIVE, 0.8V-5.15V, 3A: VR3,VR6,VR9-VR12 | |||||
TPS7A7100RGTT | VOLTAGE REGULATOR, LOW-DROPOUT, 1-A, ADJUSTABLE OUTPUT | |||||
TPS7A7200RGTR | MICROCIRCUIT, REGULATOR, VOLTAGE, LOW-DROPOUT,FAST-TRANSIENT | |||||
TPS7A7200RGTT | MICROCIRCUIT, REGULATOR, VOLTAGE, LOW-DROPOUT,FAST-TRANSIENT | |||||
TPS7A8300RGRR | 0.8V-5V ADJUSTABLE POSITIVE LDO REGULATOR, 0.2V DROPOUT, PQCC20 | |||||
TPS7A8300RGRT | 0.8V-5V ADJUSTABLE POSITIVE LDO REGULATOR, 0.2V DROPOUT, PQCC20 | |||||
TPS7A9001DSKT | MICROCIRCUIT, REGULATOR, 500MA | |||||
TPS7A9201DSKT | MICROCIRCUIT, REGULATOR, LDO VOLTAGE,LOW-NOISE,HIGH-ACCURACY | |||||
TPS7A9601DSCR | Adjustable Positive LDO Regulator, 0.4V Min, 5.5V Max, 0.35V Dropout, PDSO10 | |||||
TPSM53603RDAR | MICROCIRCUIT, POWER MODULE, 36-V INPUT, 3-A, STEP DOWN | |||||
TPSM5601R5HRDAR | MICROCIRCUIT, POWER MODULE, 60-V INPUT, 1.5-A, STEP DOWN | |||||
TPSM84209RKHT | MICROCIRCUIT, POWER MODULE, 4.5-V TO 28-V INPUT,1.2-V TO 6-V | |||||
TRS3232EQPWRQ1 | LINE DRIVER/RECEIVER, RS-232, DUAL, MULTI-CHANNEL, 3-V TO 5. | |||||
TS3A4751PWR | MULTIPLEXER | |||||
TS5A3153DCUR | IC, ANALOG SWITCH | |||||
TS5A3159MDBVREP | IC,SPDT ANALOG SWITCH | |||||
TS5A3167DCKR | MICROCIRCUIT, ANALOG, SWITCH | |||||
TS5A9411DCKR | MICROCIRCUIT | |||||
TS5A9411DCKTG4 | MICROCIRCUIT | |||||
TSB12LV32PZ | MICROCIRCUIT, CONTROLLER, LINK-LAYER | |||||
TSB41AB3IPFPEP | MICROCIRCUIT, ANALOG, RECEIVER | |||||
TSB41AB3PFP | MICROCIRCUIT, THREE-PORT CABLE TRANSCEIVER/ARBITER | |||||
TXB0102DCUT | MICROCIRCUIT, TRANSLATOR, 2-BIT,BIDIRECTIONAL, VOLTAGE LEVEL | |||||
TXB0108RGYR | MICROCIRCUIT, TRANSLATOR, 8-BIT, BIDI | |||||
TXS0101DRLR | MICROCIRCUIT, 1-BIT BIDIRECTIONAL LEVEL-SHIFTING, VOLTAGE | |||||
TXS0108ERGY | MICROCIRCUIT, TRANSLATOR, 8-BIT, BIDIRECTIOANL VOLTAGE-LEVEL | |||||
TXS0108ERGYR | IC,VOLTAGE LEVEL TRANSLATOR,BIDIRECTIONAL,8-BIT | |||||
TXU0104DTRR | MICROCIRCUIT | |||||
TXU0204PWR | MICROCIRCUIT | |||||
UC1845AMDREP | IC, PWM, CURR MODE, -55/+125C SOIC-8 | |||||
UC1846L883B | CURRENT MODE PWM CONTROLLER, 0.5A,500 KHZ SWITCHING FREQ | |||||
UC2845AN | **INACTIVE** - IC, CONTROLLER | |||||
UCC27424MDGNREP | IC, DUAL 4A LO-SIDE FET DRIVER, W/ENABLE | |||||
UCC27525DSDT | MICROCIRCUIT, BUF OR INV BASED MOSFET DRIVER | |||||
UCC2801MDREP | MICROCIRCUIT, CONTROLLER, CURRENT MODE PWM, 1 A, 1000 KHZ | |||||
UCD3138128PFC | MICROCIRCUIT, ISOLATED POWER CONTROLLER | |||||
ULN2003AID | SEMICONDUCTOR DEVICE, TRANSISTOR |
