TIDA-010010: Altium Design Files
Part Number: TIDA-010010
The Design Guide for the TIDA-010010 says that the Altium Designer project files can be downloaded from the website, but they are not linked on the page.  How can I get the Altium files?
  • Hi Justin,
    Thanks for reaching out.
    The PDF versions of the Altium files are available on the product page (as shown in the below image), but I don't think the actual Altium file extensions are available there.
    Let me check with my colleague if we can share it with you.
    Product page: TIDA-010010 reference design | TI.com
    Thanks and regards,
    Preeti
  • Hi Preeti,
    Thank you for the reply. If you look in the Design Guide (first link on the page) on Page 17, Section 4.4 it says the Altium Designer project files can be downloaded from that same web page. However, the files are not in any of the links on that page.
  • Hi Justin,
    Thanks for your reply.
    Yes! I understand your concern.
    When you click on the link, you see the webpage of the reference design. Please click on the Design files and products as highlighted in the image below. Kindly check and let me know if this works for you.
    As mentioned in the previous message, the PDF versions of Altium files are available here.
    Thanks and regards,
    Preeti
    Yes, the PDF files are on that page and I had already found them. These are referenced in 4.1 and 4.3.1 in the document. As mentioned in my original post, the document says that the Altium Designer project files should be there, not just PDF files. Are these available?
  • Hi Justin,
    TheTIDA-010100 design is only available in Allegro, but does not exists for Altium Designer. The documentation is wrong in this point (we will fix the it). Please use Allegro in case you want to work an layout or schematic.
    What is your intention for using the design files? We may be able to extract the information for you.
     Thomas
