Part Number: TIDA-01606
Hi Expert
I just have project to design Active Front End (AFE) based on TIDA-01606, i just want to eliminate T-type architecture and replaced with standart 2 level 3phase bride inverter, i have done detailed simulation on PSIM shown below
with promising result, I believe with view modification firing angle provide by Ti on TIDA-01606 we could modified the T-type version to standar 2 level 3ph Bridge for the sake hardware simplicity due to availability power module available on the market
I have simulated also T-Type PFC on PSIM. I knew excactly how to firing T-Type Bridge and 2 Level Bridge
my problem was i relative new to C2000 ecosystem, i believe just modified this line code would solve the problem due to this code contain PWM update or Firing scheme for T-Type version
Probably asking to Ti expert would solve my confusion, please explain how to modify PWM update for 2 level bridge inverter, i wouldnt touch the control algorithm because i believe only just modifty firing scheme would solve the problem
Thank you
BR
Abdin
