Part Number: LMG3522R030
Cannot start PSPICE for TI.
At login screen I get an internal error, code: 2008.
Hi Jeff,
Is this a new install?
Did it work before?
Based on your response, I'll ask for some files to dig in further.
David
Please go to the following lcoation %appdata%\Cadence\PSpiceTIInstall and upload the file cdsPspiceTIlog.txt
Can you check if there is a file called license.txt at %appdata%\Cadence\VBL\TI_PSice_231\license?
David
It never even installs.
I have Windows10 and there's no "appdata" directory.
No Cadence directory in "program data".
Hi Jeff,
Well, there's a first time for everything. Let me bump this to Cadence.
David
I posted the file here but TI says it's SPAM and I will be permanently kicked out if I don't file an appeal!
WTH?
Hey Jeff,
What were you trying to post? There shoudl be no problem with using Insert - Image/Video/File.
Did folders get created on your computer?
e.g. C:\cds_spb_home
David
Hi Jeff,
Just re-read your message.
%appdata% is a shortcut when you open the search panel.
It will go to C:\Users\<yourpcaccount>\AppData\Roaming
e.g. for me: C:\Users\a0187457\AppData\Roaming
Please double check for the install files.
David
I uploaded the log file but I cannot find the license file.
Contents of: C:\Users\Jeff_*****\AppData\Roaming\Cadence\PSpiceTIInstall
Can you show me your %appdata%\Cadence folder?
Is there a VBL in there? That should have a license folder that contains the license.txt file.
There definitely should be a VBL folder. Something went wrong during the installation.
Do you have admin access?
Please try the following:
Uninstall PSpice for TI.
Re-boot your computer.
Install again.
After install, check to see if VBL is there.
David
I deleted the Cadence folder and reinstalled, this time as admin but same result - no VBL folder.
Nothing to uninstall - it never gets that far - it flags the error immediately.
I uploaded the log file but it isn't showing up here.
Hi Jeff,
Would you be avalable for a call in the morning this week?
David
Hi Jeff,
Did you IT get the TLS1.2 unblocked?
Is the authentication error gone and you've been able to install?
Any good news? All good news?
David
Nothing worked - upgraded all MS stuff and no joy.
Others here had no problem installing on similar pcs.
We punted because I'm getting a new pc in a few days and I'll try again.
...Jeff
Weird. Hopefully it's the machine and not you (LOL).
I'll close this and let Shikhar know that there was no success, but that you'll try installing on a new computer.
David
