How to measure Vload_detect as per MSP430 flowchart in TIDA-010030
regards
regards
Vload_detect is a constant value for a specific system. It is to determine if the PACK+ voltage is normal with pre-discharge FET on for a while. For examples, with pre-discharge FET on and load on PACK side is within the recommended range, PACK+ voltage should rise based on RC charge curve. After a while (you need to determine how long is reasonable for your system), PACK+ voltage should rise to close to BAT+ (the exact PACK+ voltage depends on your pre-discharge resistance, load conditions, but you should know that for your system)
Ryan Tan
