Other Parts Discussed in Thread: UCD3138A
Hardware:PMP23340UCD(UCD3138A)
Firmware:TI supplied routines——UCDIBCFirmware
The problems:The following error occurs after the reset is turned on to turn on the power supply.
Excessive output current and abnormal temperature display (-300°C?),Board rattles, then stops working.
There should be no problem with the program as the burn-in has worked fine many times before.
So can you give me some advice on how to fix or troubleshoot the problem?
