After one-time usage, PSPICE doesn't start anymore because of error LMC-022071. For what reason?
05/13/2024 15:32:47 (438550-35952): License Mode: bundleName is set to TI_PSpice_231
05/13/2024 15:32:47 (438550-35952): Initialization started (23.02-a004)...
05/13/2024 15:32:47 (438550-35952): FLEXnet version 11.16.4.0 build 252457
05/13/2024 15:32:47 (438550-35952): Process ID 35960
05/13/2024 15:32:47 (438550-35952): Creating a new job ...
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Get License File called with bundle TI_PSpice_231
05/13/2024 15:32:47 (pid-35960-35952): (vbl) VBL version: (23.02-s004)
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Licensing errors/warnings set in product_key flow
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Setting LastErrCode: 0
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Getting LastErrCode: 0
05/13/2024 15:32:47 (pid-35960-35952): (vbl) License file path stored in the registry is C:\Users\a_thkopp\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt
05/13/2024 15:32:47 (pid-35960-35952): (vbl) cdsVbliGetLicenseFile returned 0
05/13/2024 15:32:47 (438550-35952): Configuration of license path is 'C:\Users\a_thkopp\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
05/13/2024 15:32:47 (438550-35952): Configuration of recheck interval minimum is 290.
05/13/2024 15:32:47 (438550-35952): Configuration of 2000000000 maximum retry calls.
05/13/2024 15:32:47 (438550-35952): Configuration of sleep time value of 0.
05/13/2024 15:32:47 (438550-35952): Configuration of display specification is '0:0'.
05/13/2024 15:32:47 (438550-35952): Licenses will be checked out using a_thkopp@SCCN32138(0:0).
05/13/2024 15:32:47 (438550-35952): (System spec would have been a_thkopp@SCCN32138(SCCN32138) )
05/13/2024 15:32:47 (438550-35952): Job creation completed with status 0 (time 0).
05/13/2024 15:32:47 (438550-35952): Initialization completed with status 0 (time 0).
05/13/2024 15:32:47 (438550-35952): License mode: Validate Trigger Interval is set to: 86401 sec
05/13/2024 15:32:47 (438550-35952): License Mode: Starting ValidateLicenseThread
05/13/2024 15:32:47 (438550-11596): License Mode: ValidateLicenseThread started
05/13/2024 15:32:47 (438550-11596): License mode: calling cdsVblValidateLicense from thread...
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Licensing errors/warnings set in product_key flow
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Action code is 1
05/13/2024 15:32:47 (pid-35960-11596): (vbl) cdsVbliValidateLicense attempt 0/3
05/13/2024 15:32:47 (pid-35960-35952): (mfp) MFP version: (22.01-d007)
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Get hw addresses called with upOnly=True
05/13/2024 15:32:47 (pid-35960-11596): (vbl) User has entitlement types: Commercial
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Setting LastErrCode: 0
05/13/2024 15:32:47 (pid-35960-35952): (mfp) HW addresses:
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=3ce1a146ff68 addlen=6 type=6 status=2 len=448 index=7 flags=1c5 connType=1 tunType=0 name={36C35AA4-BD7E-48A6-A9F9-3FC31D6E1529}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Skipping as not up
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=50b626484f addlen=6 type=6 status=2 len=448 index=24 flags=1c1 connType=1 tunType=0 name={EDDA9626-92BE-4E1D-8F46-8D6B35F93517}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=606d3cde3bda addlen=6 type=6 status=1 len=448 index=3 flags=1c5 connType=1 tunType=0 name={17FD5EEA-E203-4DF4-A776-FECDB813CCD4}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Friendly name: Ethernet
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Setting as primary
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=ff305e677e addlen=6 type=53 status=2 len=448 index=6 flags=1c5 connType=1 tunType=0 name={305E677E-815B-4204-9BD9-AE6BD795B145}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=2c3358ffd2aa addlen=6 type=71 status=2 len=448 index=21 flags=1c5 connType=1 tunType=0 name={B2909AF7-9CF3-4A68-AD10-6E04E11C3B3D}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=2c3358ffd2ab addlen=6 type=71 status=2 len=448 index=12 flags=1c5 connType=1 tunType=0 name={5EEA3D78-7E2A-4742-8CFE-7F05A4F74B1C}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=2e3358ffd2aa addlen=6 type=71 status=2 len=448 index=9 flags=1c1 connType=1 tunType=0 name={4BBDD594-D13A-4284-8A44-2744B37DE3B3}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=2c3358ffd2ae addlen=6 type=6 status=2 len=448 index=22 flags=1c5 connType=1 tunType=0 name={C7F57943-52A8-4A02-AC23-80AE992B2A5F}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={8DC45C89-1F29-11EE-9A02-806E6F6E6963}
05/13/2024 15:32:47 (pid-35960-35952): (mfp) Skipping as lookup
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
05/13/2024 15:32:47 (pid-35960-35952): (mfp) HW addresses end
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Setting LastErrCode: -2071
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
05/13/2024 15:32:47 (438550-35952): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Setting LastErrCode: -2054
05/13/2024 15:32:47 (438550-35952): FeatureExists started ....
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
05/13/2024 15:32:47 (438550-35952): Check-out started ....
05/13/2024 15:32:47 (438550-35952): Testing only for the validity of feature PSpice_TI 23.100...
05/13/2024 15:32:47 (pid-35960-11596): (vbl) cdsVbliValidateLicense returned -2071
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
05/13/2024 15:32:47 (pid-35960-11596): (vbl) Getting WarningErrorCode: 0
05/13/2024 15:32:47 (pid-35960-11596): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
05/13/2024 15:32:47 (438550-11596): License mode: Sleeping for 86442 sec
05/13/2024 15:32:47 (438550-35952): License Mode: First checkout status:
05/13/2024 15:32:47 (438550-35952): License Mode checkout status with status:(0)
05/13/2024 15:32:47 (438550-35952): License Mode: FlexNetErr Code:
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 0
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Action code is 0
05/13/2024 15:32:47 (pid-35960-35952): (vbl) cdsVbliValidateLicense attempt 0/3
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Setting LastErrCode: -2071
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Setting LastErrCode: -2054
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
05/13/2024 15:32:47 (pid-35960-35952): (vbl) cdsVbliValidateLicense returned -2071
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
05/13/2024 15:32:47 (438550-35952): License Mode: cdsVblValidateLicense status:
05/13/2024 15:32:47 (438550-35952): License Mode checkout status with status:(-1)
05/13/2024 15:32:47 (438550-35952): License Mode: Vbl Returned Last vblerror code
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Getting LastErrCode: -2071
05/13/2024 15:32:47 (pid-35960-35952): (vbl) cdsVblGetLastError returned internal error code: -2071
05/13/2024 15:32:47 (438550-35952): License Mode checkout status with status:(-2071)
05/13/2024 15:32:47 (438550-35952): Validity test completed with status 0.
05/13/2024 15:32:47 (438550-35952): Check-out completed with status 0 (time 0).
05/13/2024 15:32:47 (438550-35952): FeatureExists of PSpice_TI completed with status 0 (time 0).
05/13/2024 15:32:47 (438550-35952): Added PSpice_TI,23.100000 entry with status 0 to feature exists cache
05/13/2024 15:32:47 (438550-35952): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
05/13/2024 15:32:47 (438550-35952): Testing only for the validity of feature PSpice_TI_Plus 23.100...
05/13/2024 15:32:47 (438550-35952): Validity test completed with status -5.
05/13/2024 15:32:47 (438550-35952): Check-out completed with status -5 (time 0).
05/13/2024 15:32:47 (438550-35952): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
05/13/2024 15:32:47 (438550-35952): Api started: api=CheckOut;feature=PSpice_TI;version=23.10000;count=1,wait=SS_NOWAIT;lic_type=0
05/13/2024 15:32:47 (438550-35952): Checking out 1 license(s) for PSpice_TI 23.100...
05/13/2024 15:32:47 (438550-35952): (Checked out from file 'C:\Users\a_thkopp\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt',
line '23.1 29-jul-2024 0 2FB8C8E6B0DECDE8F351 ')
05/13/2024 15:32:47 (438550-35952): Trial was set to false
05/13/2024 15:32:47 (438550-35952): Validation License failure
05/13/2024 15:32:47 (438550-35952): Giving up License checkedout
05/13/2024 15:32:47 (438550-35952): License Mode: VblError
05/13/2024 15:32:47 (438550-35952): License Mode: Mapped to SftShrDev Error
05/13/2024 15:32:47 (438550-35952): License Mode checkout status with status:(-956)
05/13/2024 15:32:47 (438550-35952): Giving up license due to errors
05/13/2024 15:32:47 (438550-35952): Check-out completed with status -956 (time 0).
05/13/2024 15:32:47 (pid-35960-35952): (vbl) Licensing errors/warnings product_key flow: 1
05/13/2024 15:32:51 (438550-35952): License mode: signaling thread to stop
05/13/2024 15:32:51 (438550-35952): License mode: waiting for thread to stop
05/13/2024 15:32:51 (438550-11596): License mode: Thread woke up, passed: 4 sec, sleep left: 86438 sec
05/13/2024 15:32:51 (438550-11596): License mode: Exiting thread gracefully due to Signal by lmExit...
05/13/2024 15:32:51 (438550-11596): License mode: ValidateLicenseThread is stopping...
05/13/2024 15:32:51 (438550-35952): License mode: thread stopping took 0 sec
05/13/2024 15:32:51 (438550-35952): Exit started ....
05/13/2024 15:32:51 (438550-35952): Exit completed with status 0 (time 0).
