PSPICE-FOR-TI: Too many machines attempting to connect with the same access key.
Part Number: PSPICE-FOR-TI
Since I reinstalled my system, when I try to install Pspice for TI, I get the following message "Too many machines attempting to connect with the same access key".
My email is yuliya_zhu@jabil.com.
Can you help me remove all of the computers except CNWUXNB2898?
Thanks.
B.R.
Yuliya
  • Hi Yuliya,
    I'll be happy to put this request in. This will include keeping CNWUXNB2898 active.
    Just to be clear, we have a new version, 23.1-S001. The version on your existing computer is likely 17.4-S009 (unless you accepted the upgrade prompt).
    There should be no problem (and none of the menu's changed) having 2 versions on different computers. I just wanted to give you a head's-up.
    Also, the newer version includes ~1000 included pspice models for simple devices such as diodes, BJT, MOSFETs. And you can import 1 external model without limiting active markers. Finally, there are now 4 active markers when importing more than 1 model.
    David
  • Hi Yuliya,
    Your old installs (except CNWUXNB2898) have been disabled. You should be able to install a fresh version of PSpice for TI on your new computer.
    David
