Part Number: TPSM843B22
I was wondering if there is any output impedance data for the TPSM843B22?
Also, is the simplis model toleranced at all?
Hi Anthony,
We have some measurements, but they are in bode3 document file types. Do you have Bode Analyzer Suite? It is free to download here: Bode Analyzer Suite - control your Bode 100 | OMICRON Lab (omicron-lab.com)
The SIMPLIS models are programmed to simulate the same way every time, there are ways to test the min/max results, but this is not something that is included in the model.
Ryan
Hi Anthony,
We have data for 500 kHz, 750 kHz, 1 MHz, 1.5 MHz at no load, 5A and 20 A at different ramp settings.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/234/TPSM843B22-impedance-12-Vin_2C00_-1-Vout_2C00_-1-MHz-measurements.bode3https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/234/TPSM843B22-impedance-12-Vin_2C00_-1-Vout_2C00_-1.5-MHz-measurements.bode3https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/234/TPSM843B22-impedance-12-Vin_2C00_-1-Vout_2C00_-500-kHz-measurements.bode3https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/234/TPSM843B22-impedance-12-Vin_2C00_-1-Vout_2C00_-750-kHz-measurements.bode3
Ryan
Hi Anthony,
Here is a pdf explaining how to take the measurement: Picotest 2-port Probe Impedance Measurements - Picotest
It requires a P2102A Probe, J2113A Differential Amplifier, and Bode 100 analyzer. Also, moving one of the output capacitors to create an open pad is needed.
Ryan
Hi Anthony,
The components used were an unmodified TPSM843B22EVM, its schematic can be found on the user guide.
TPSM843B22EVM Step-Down Module Evaluation Module User's Guide
Best
Ryan
