Part Number: TIDA-010216
Other Parts Discussed in Thread: TPS54308, BQ76972, UCC27524
Hi Utku,
See below:
1. Yes, more MOSFETs helps a lot on the thermal. If using the same MOSFET (2mR ohms Rds_on) with TIDA-010216, 200A generates 80W which is too large. Suggest to add more MOSFETs based on your cooling conditions and system requirements.
2. We only tested 750344754 in our board. I don't see it quite complicated to design the transformer, maybe you can find some other transformer manufactures to help you with a new transformer design, you can find TPS54308 calculation tools through below: https://www.ti.com/tool/download/SLUC685.
Ryan Tan
Hi Utku,
AFE doesn't have this feature integrated, but you could use host to control AFE through DEFTOFF/CFETOFF pins to achieve this. More details you can refer to 7.7.4 of BQ76972 TRM https://www.ti.com/lit/ds/symlink/bq76972.pdf?ts=1719130822796&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FBQ76972 .
BRs
Kian
UCC27524AD gate driver supports PWM signals through Vinx pins. So it must be able to switch the Mosfet groups in CHG and DSG channels using PWM. That must be limiting the current flowing through V- line. Can you be more specific on how AFE does not support current adjustment? We are not using BQ76972 yet, we consider to use MOSFET part in one of our commercial products. But we may switch to BQ76972 if there is a way to control current.
Thank you.
