PSPICE-FOR-TI: connection error
Part Number: PSPICE-FOR-TI
I have check the connection https://cdsplicwc.cadence.com/chws/test/connection.html  => successful connection
but still error :
please help
  • Hi Tuan,
    Sorry about this issue that you are seeing.
    Can you attach the file listed in that error message? cdsPspiceTIlog.txt?
    David
  • 3:20:16 PM Tuesday, June 25, 2024 : parameter count = 1
    3:20:16 PM Tuesday, June 25, 2024 : -wrapper
    3:20:16 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:20:16 PM Tuesday, June 25, 2024 : Server OS = False
    3:20:16 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:20:16 PM Tuesday, June 25, 2024 : Checking for proxy
    3:20:16 PM Tuesday, June 25, 2024 : {
    	"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
    	"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
    	"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
    	"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
    	"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
    	"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
    	"LibFirstInstall_LatestVersion": "23.10.001",
    	"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
    	"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
    	"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
    	"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
    	"SoftwareUpdate_Expiry": {
    		"Timestamp": "01:15:2099 15:07:19 GMT",
    		"RegularMessage": {
    			"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
    			"HyperLink": "license agreement",
    			"PostHyperLink": "."
    		"ForceMessage": {
    			"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
    			"PostHyperLink": ".  Click Cancel to exit."
    	"UTM_Keyword": {
    		"TIPSpice_Install": "HQS=pspiceforti",
    		"Full_Install": "HQS=pspiceforti"
    	"TI_URLs_Version": [
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:20:16 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:20:18 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:20:18 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:20:18 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    URL: https://cdsplicwc.cadence.com/chws/test/connection.html
    Error Description: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    View log file for details at C:\Users\nh_tu\AppData\Roaming\Cadence\PspiceTIInstall\cdsPspiceTIlog.txt
    3:20:52 PM Tuesday, June 25, 2024 : parameter count = 1
    3:20:52 PM Tuesday, June 25, 2024 : -wrapper
    3:20:52 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:20:52 PM Tuesday, June 25, 2024 : Server OS = False
    3:20:52 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:20:52 PM Tuesday, June 25, 2024 : Checking for proxy
    3:20:52 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:20:52 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:20:53 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:20:53 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:20:53 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:21:21 PM Tuesday, June 25, 2024 : parameter count = 1
    3:21:21 PM Tuesday, June 25, 2024 : -wrapper
    3:21:21 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:21:21 PM Tuesday, June 25, 2024 : Server OS = False
    3:21:21 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:21:21 PM Tuesday, June 25, 2024 : Checking for proxy
    3:21:22 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:21:22 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:21:22 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:21:22 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:21:23 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:22:21 PM Tuesday, June 25, 2024 : parameter count = 1
    3:22:21 PM Tuesday, June 25, 2024 : -wrapper
    3:22:21 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:22:21 PM Tuesday, June 25, 2024 : Server OS = False
    3:22:21 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:22:21 PM Tuesday, June 25, 2024 : Checking for proxy
    3:22:21 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:22:21 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:22:22 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:22:22 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:22:22 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:27:00 PM Tuesday, June 25, 2024 : parameter count = 1
    3:27:00 PM Tuesday, June 25, 2024 : -wrapper
    3:27:01 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:27:01 PM Tuesday, June 25, 2024 : Server OS = False
    3:27:01 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:27:01 PM Tuesday, June 25, 2024 : Checking for proxy
    3:27:01 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:27:01 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:27:02 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:27:02 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:27:02 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:28:14 PM Tuesday, June 25, 2024 : parameter count = 1
    3:28:14 PM Tuesday, June 25, 2024 : -wrapper
    3:28:14 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:28:14 PM Tuesday, June 25, 2024 : Server OS = False
    3:28:14 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:28:14 PM Tuesday, June 25, 2024 : Checking for proxy
    3:28:14 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:28:14 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:28:15 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:28:15 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:28:15 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:31:15 PM Tuesday, June 25, 2024 : parameter count = 1
    3:31:15 PM Tuesday, June 25, 2024 : -wrapper
    3:31:15 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:31:15 PM Tuesday, June 25, 2024 : Server OS = False
    3:31:15 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:31:15 PM Tuesday, June 25, 2024 : Checking for proxy
    3:31:15 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:31:15 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:31:16 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:31:16 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:31:16 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    3:33:25 PM Tuesday, June 25, 2024 : parameter count = 1
    3:33:25 PM Tuesday, June 25, 2024 : -wrapper
    3:33:25 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    3:33:25 PM Tuesday, June 25, 2024 : Server OS = False
    3:33:25 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    3:33:25 PM Tuesday, June 25, 2024 : Checking for proxy
    3:33:25 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    3:33:25 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    3:33:26 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    3:33:26 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    3:33:26 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    6:37:19 PM Tuesday, June 25, 2024 : parameter count = 1
    6:37:19 PM Tuesday, June 25, 2024 : -wrapper
    6:37:19 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    6:37:19 PM Tuesday, June 25, 2024 : Server OS = False
    6:37:19 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    6:37:19 PM Tuesday, June 25, 2024 : Checking for proxy
    6:37:19 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    6:37:19 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    6:37:20 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    6:37:20 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    6:37:20 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    6:38:00 PM Tuesday, June 25, 2024 : parameter count = 1
    6:38:00 PM Tuesday, June 25, 2024 : -wrapper
    6:38:00 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    6:38:00 PM Tuesday, June 25, 2024 : Server OS = False
    6:38:00 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    6:38:00 PM Tuesday, June 25, 2024 : Checking for proxy
    6:38:01 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    6:38:01 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    6:38:01 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    6:38:01 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    6:38:01 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    6:48:29 PM Tuesday, June 25, 2024 : parameter count = 1
    6:48:29 PM Tuesday, June 25, 2024 : -wrapper
    6:48:30 PM Tuesday, June 25, 2024 : Module Name: TIPSpice.exe
    6:48:30 PM Tuesday, June 25, 2024 : Server OS = False
    6:48:30 PM Tuesday, June 25, 2024 : Operating system version : 10.0.0.0
    6:48:30 PM Tuesday, June 25, 2024 : Checking for proxy
    6:48:30 PM Tuesday, June 25, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    6:48:30 PM Tuesday, June 25, 2024 : Checking if Licensing URL is accessible
    6:48:31 PM Tuesday, June 25, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    6:48:31 PM Tuesday, June 25, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    6:48:31 PM Tuesday, June 25, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    8:02:38 AM Wednesday, June 26, 2024 : parameter count = 1
    8:02:38 AM Wednesday, June 26, 2024 : -wrapper
    8:02:38 AM Wednesday, June 26, 2024 : Module Name: TIPSpice.exe
    8:02:38 AM Wednesday, June 26, 2024 : Server OS = False
    8:02:38 AM Wednesday, June 26, 2024 : Operating system version : 10.0.0.0
    8:02:38 AM Wednesday, June 26, 2024 : Checking for proxy
    8:02:39 AM Wednesday, June 26, 2024 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    8:02:39 AM Wednesday, June 26, 2024 : Checking if Licensing URL is accessible
    8:02:40 AM Wednesday, June 26, 2024 : Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    8:02:40 AM Wednesday, June 26, 2024 : Inner Exception : The remote certificate is invalid according to the validation procedure.
    8:02:40 AM Wednesday, June 26, 2024 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    This is cdsPspiceTIlog.txt in my computer.
    Tks
    Nhtuan
  • Thanks Nhtuan,
    I'll submit this to Cadence. I suspect they'll want to setup a call with you, but let's see what they make out of this first.
    David
  • Hi Nhtuan,
    Looks like we need to gather license info.
    Here are the instructions from Cadence on how to do that: How do I set the CDS_LIC_QA_TesT variable? (cadence.com)
    If you can't set system variable, then try setting environment variable for your account.
    Post the results here and I'll get them to Cadence for further debug.
    David
