Other Parts Discussed in Thread: OPA2312, ADS8885, TPS7A20, ADS127L21
Hello E2E Experts,
Good day.
Hello E2E Experts,
Good day.
In the TIDA-01012 design, input signal COM pin is connected to 1P35_VREF, i.e. mid point of the opa2312 rails, in the circuit. It is not floating with respect to measurement circuit. Hope this answers your questions. Let us know if you have any further questions.
Thank you,
Shaury
Hello Shaury,
Good day.
Do you know that is the reasoning for having the signal be put in between the opamps 2 rails?
Is this just for setting the common mode or am I missing something?
TI-CSC
The input signal to the multimeter reference design is a differential signal like ±1V,±10V etc. If we connect the COM port to ADC GND, ADC circuit will see negative voltages. ADC VDD is 2.7V. To support negative input voltage, COM pin is connected to AVDD/2, i.e., 1.35V. This adds offset/common mode to the input signal.
Shaury
Hello Shaury,
Good day.
Yes, by connecting COM pin to VREF/2, we can avoid negative rail in the design.
Sorry, I don't understand your comment about matching the common mode range. ADS8885 ADC requires common mode of VREF/2. The common mode to the input signal is added by using a full differential amplifier, U6. By connecting input COM pin to VREF/2, we are just level shifting IN_P and IN_N(COM) signals to VREF/2 to make sure neither IN_P nor IN_N(COM) input pins go to negative values with respect to the circuit GND. The multimeter reference circuit is designed for +/- 50 V, +/-5 V, +/-500 mV, and +/-50 mV. The input signal is first attenuated to using resistors. Let's say if COM pin is connected to GND net in the schematic, the multiplexers (U8 and U4), and amplifier U5A will see negative voltages.
Below is the link of fully differential amplifier tutorial. I'm not sure if this is what you are looking for. Let us know if you have any questions.
Shaury
Hello Shaury,
Good day.
Are there any potential issues associated with copying this and creating a 2-channel device?
Will there be any concerns regarding measuring voltages from the same and different sources?
TI-CSC
There are no issues if the both channels are isolated/floating with each other. This means that we need isolated power supply for each channel. We have isolated power modules. You can check here. Let us know if you any questions.
https://www.ti.com/power-management/dcdc-power-modules/isolated-power-modules/overview.html
Shaury
Hello Shaury,
Good day.
Do you have any recommendations for a low noise circuit that will not affect the ADC (5V output @ 100mA).
Will Voltage ripple be an issue?
TI-CSC
TPS7A20 could be an option. Please check our Linear & low-dropout (LDO) regulators page for more details.
Also, we have a new ADCs that has better linearity. ADS127L21, for an example, has maximum INL spec 1.4ppm, i.e. much better than ADS8885. Linearity is a key consideration when designing digital multimeters. What is resolution you are targeting in this design?
https://www.ti.com/power-management/linear-regulators-ldo/overview.html
Shaury
