LM5148: LM5148
Part Number: LM5148
Other Parts Discussed in Thread: LM25148
Hi TI
The datasheet of LM5148 table 9.1 shown the common formula to maeuserd MOSFET'S power loss
But the spreadsheet of  "LM5148_LM25148_quickstart_calculator_A4" didnt use these parameters.
for exsample, the formula of MOS's "switching loss" mention the Tr & Tf as MOSFET's parameter.
this parameter is typical method.
how can i measure it?
When I used webench to simulate, the webench recommended the MOS and the simulation results to illustrate the loss of MOS.
I tried to fill in the MOS parameters recommended by webench into the spreadsheet.
The results of the spreadsheet do not match the results of the webench simulation.
    The MOSFET switching times are calculated internally in the quickstart file. It's effectively the rise/fall time of the SW voltage and current, which is related to the Qgd and gm of the high-side MOSFET, respectively.
    Tim
  • Hi Tim
    My question is how to solve the problem that the formula does not match the result of the spreadsheet?
    For example, the result of the spreadsheet shown the curve of power loss.
    But the results obtained by the formula in the datasheet are not consistent.
    The datasheet recommends the formula Tr/Tf for calculation, but the spreadsheet does not. As you mentioned, the spreadsheet uses Qgd and GM for calculations, however, the results are different.
    It seems that the spreadsheet calculation results in MOS cannot be used.
  • Hi Yu-cheng,
    The quickstart uses the expressions in the datasheet. Please send your quickstart file for review.
    Tim
