LM51561-Q1: Incorrect Ground Node Assignment in PSpice Model
Part Number: LM51561-Q1
Other Parts Discussed in Thread: LM5156
I've noticed an issue with the LM51561-Q1 PSpice model available on the IC details page. The model assigns the global node 0 to the ground pin, but it should be connected to the IC's dedicated GND pin instead.
In my current simulation, I encounter convergence issues when connecting my circuit ground to the GND pin because internally, the model is assigning GND to global node 0, which causes problems.
I believe the global "Node 0" needs to be replaced with the actual "GND" pin of the IC in the model. While I could manually make these changes, it involves numerous lines, making it impractical to do so.
Could you please assist by updating the PSpice model accordingly?
Thank you for your support.LM5156-Q1_TRANS.LIB
