PSPICE-FOR-TI: Direct file download not via installer
Part Number: PSPICE-FOR-TI
My companies IT has blocked me from the installer tool from dowloading the .dll and .cab files necessary for setup. Just wondering if there is a zip file version of the files you guys can send me privately. I have an access key and everything.
Sincerely,
David Yang
  • Hi David,
    I'll check, but if there's a problem with this, then you'll have other problems as well as the program needs to reference several sites, and needs to validate the license at least once/month.
    Here are the other sites:
    https://cdsplicwc.cadence.com/
    https://software-dl.ti.com/
    https://downloads.ti.com/
    I'd recommend pushing your IT to whitelist these sites.
    Alternatively, if this is not a core need for your job and you have a computer at home, you could install on that using your personal email to setup a TI account.
    David
  • Hi David,
    Apologies. I had my IT whitelitst the account through my VM system but turns out that was not the problem. I was able to get it to work on my main account - it still crashes on the VM but I do not have the time to debug it right now. You can go ahead and close the ticket as I was able to do the work I needed to on PSPICE.
    David Yang
