TPS62441-Q1: Webbench gets stuck loading when trying to change part value.
Part Number: TPS62441-Q1
I am trying to look at the phase and gain margins for this part using the values I have selected for a design using this part. When I switch the mode to comp setting 1 and SSC enabled, and FPWM whenever I try to change a component value (for example changing the resistor in series with PGOOD from 100k to 1M), webbench brings up a loading bar at the top and never loads the new part.
Any help would be appreciated.
Thank You,
