LP-XDS110: Debbuger
Expert 1015 points
Part Number: LP-XDS110
I want to extend my debugger cable up to 3Meters does JTAG will support upto 3Meters?
  • You will most likely run into fidelity issues at 3 meters. We recommend a max length of 6 inches before buffers are needed.
    Start by lowering the JTAG speed first and see if that works for you and consider using 4-wire JTAG. Note that our default JTAG speed is 5.5MHz
    If not, then consider adding buffers to allow for longer length.
    Bun
