Dear support team,
as discussed with your colleague, we have faced an issue while installing PSpice for TI at our lab-workstation. The installer was not able to download the license-file and the installation terminated. We have repeated the installation several times using an accout with admin privileges.
Installing the same tool chain at my personal company-laptop worked with no problems at all.
Attached please find the installation-log.
Thanks for your help and kind regards
Dietmar
10:21:33 Freitag, 21. März 2025 : parameter count = 1
10:21:33 Freitag, 21. März 2025 : -wrapper
10:21:33 Freitag, 21. März 2025 : Module Name: TIPSpice.exe
10:21:33 Freitag, 21. März 2025 : Server OS = False
10:21:33 Freitag, 21. März 2025 : Operating system version : 10.0.0.0
10:21:33 Freitag, 21. März 2025 : Checking for proxy
10:21:33 Freitag, 21. März 2025 : {
"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
"LibFirstInstall_LatestVersion": "23.10.001",
"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
"SoftwareUpdate_Expiry": {
"Timestamp": "01:15:2099 15:07:19 GMT",
"RegularMessage": {
"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
"HyperLink": "license agreement",
"PostHyperLink": "."
"ForceMessage": {
"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
"PostHyperLink": ". Click Cancel to exit."
"UTM_Keyword": {
"TIPSpice_Install": "HQS=pspiceforti",
"Full_Install": "HQS=pspiceforti"
"TI_URLs_Version": [
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
10:21:33 Freitag, 21. März 2025 : Checking if Licensing URL is accessible
10:21:34 Freitag, 21. März 2025 : Initializing
10:21:34 Freitag, 21. März 2025 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
10:21:34 Freitag, 21. März 2025 : Response Content length = 1766
10:21:34 Freitag, 21. März 2025 : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
10:21:34 Freitag, 21. März 2025 : Reading Json URL File
10:21:34 Freitag, 21. März 2025 : setting media download server URL from Json File
10:21:34 Freitag, 21. März 2025 : setting default production Dll server URL
10:21:34 Freitag, 21. März 2025 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v2
10:21:34 Freitag, 21. März 2025 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
10:21:34 Freitag, 21. März 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system:
10:21:34 Freitag, 21. März 2025 : LaunchTIPSpiceDlgs()
10:21:34 Freitag, 21. März 2025 : Checking for compnts.dat
10:22:01 Freitag, 21. März 2025 : error_code cdsVblAuthenticateUser: VblSuccess
10:22:01 Freitag, 21. März 2025 : error_code cdsVblRegisterInstallation: VblSuccess
10:22:01 Freitag, 21. März 2025 : error_code cdsVblRequestLicense: VblSuccess
10:22:04 Freitag, 21. März 2025 : Set Installation and Home Directory()
10:22:04 Freitag, 21. März 2025 : Setting default Installation directory : C:\Cadence\PSpiceTI
10:22:04 Freitag, 21. März 2025 : Reading CDS_HOME environment variable
10:22:04 Freitag, 21. März 2025 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
10:22:04 Freitag, 21. März 2025 : First time installation. CDS_HOME will be set to default HOME directory.
10:22:04 Freitag, 21. März 2025 : Checking if CDS_HOME directory exists and whether user has permission to create it.
10:22:04 Freitag, 21. März 2025 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home
10:22:07 Freitag, 21. März 2025 : Checking for memory space
10:22:07 Freitag, 21. März 2025 : Memory space available
10:22:07 Freitag, 21. März 2025 : Target Dir: C:\Cadence\PSpiceTI
10:22:07 Freitag, 21. März 2025 : Working Dir: C:\cds_spb_home
10:22:07 Freitag, 21. März 2025 : Silent ini file created
10:22:07 Freitag, 21. März 2025 : Skipping download of 0x0409.ini DataSize is 22480
10:22:07 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
10:22:07 Freitag, 21. März 2025 : Skipping download of data1.hdr DataSize is 6548172
10:22:07 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
10:22:07 Freitag, 21. März 2025 : Skipping download of data1.cab DataSize is 31832538
10:22:07 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
10:22:07 Freitag, 21. März 2025 : Skipping download of ISSetup.dll DataSize is 1644152
10:22:07 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
10:22:07 Freitag, 21. März 2025 : Skipping download of layout.bin DataSize is 1106
10:22:07 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
10:22:08 Freitag, 21. März 2025 : Skipping download of pspInstall.pdf DataSize is 85357
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
10:22:08 Freitag, 21. März 2025 : Skipping download of setup.bmp DataSize is 414056
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
10:22:08 Freitag, 21. März 2025 : Skipping download of setup.ini DataSize is 2604
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
10:22:08 Freitag, 21. März 2025 : Skipping download of setup.inx DataSize is 575829
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
10:22:08 Freitag, 21. März 2025 : Skipping download of data2.cab DataSize is 168572928
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
10:22:08 Freitag, 21. März 2025 : Skipping download of data11.cab DataSize is 18414103
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data11.cab
10:22:08 Freitag, 21. März 2025 : Skipping download of data3.cab DataSize is 209715200
10:22:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
10:22:09 Freitag, 21. März 2025 : Skipping download of data10.cab DataSize is 209715200
10:22:09 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data10.cab
10:22:09 Freitag, 21. März 2025 : Skipping download of data9.cab DataSize is 209715200
10:22:09 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
10:22:10 Freitag, 21. März 2025 : Skipping download of data8.cab DataSize is 209715200
10:22:10 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
10:22:10 Freitag, 21. März 2025 : Skipping download of data7.cab DataSize is 209715200
10:22:10 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
10:22:11 Freitag, 21. März 2025 : Skipping download of data6.cab DataSize is 209715200
10:22:11 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
10:22:11 Freitag, 21. März 2025 : Skipping download of data5.cab DataSize is 209715200
10:22:11 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
10:22:11 Freitag, 21. März 2025 : Skipping download of installsetup.exe DataSize is 966264
10:22:11 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
10:22:12 Freitag, 21. März 2025 : 1051200 1051200
10:22:12 Freitag, 21. März 2025 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
10:22:12 Freitag, 21. März 2025 : Skipping download of data4.cab DataSize is 209715200
10:22:12 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
10:22:12 Freitag, 21. März 2025 : Allegro Installation Start pid: 15548
10:22:19 Freitag, 21. März 2025 : NumberOfComponentsToBeInstalled = 51751
10:22:19 Freitag, 21. März 2025 : Updated NumberOfComponentsToBeInstalled = 52791,69
10:22:19 Freitag, 21. März 2025 : Updated NumberOfComponentsInstalled = 518
10:27:19 Freitag, 21. März 2025 : Feature transfer complete..disabling close button
10:27:19 Freitag, 21. März 2025 : Installing: Extracting archives
10:27:19 Freitag, 21. März 2025 : Installing: Runtime packages and redistributables
10:27:19 Freitag, 21. März 2025 : Installing: Updating Admin batch actions
10:27:19 Freitag, 21. März 2025 : Installing: Executing post install script
10:27:20 Freitag, 21. März 2025 : Installing: Creating user library
10:27:37 Freitag, 21. März 2025 : Installing: Configuring documentation
10:27:43 Freitag, 21. März 2025 : Installing: Configuring file associations
10:27:44 Freitag, 21. März 2025 : Installing: Setting permissions for files and folders
10:27:44 Freitag, 21. März 2025 : Installing: Creating Registries
10:27:44 Freitag, 21. März 2025 : Installing: SQL Lite ODBC Driver
10:27:45 Freitag, 21. März 2025 : Installing: Finishing Installation
10:28:02 Freitag, 21. März 2025 : Running Library Configuration Executable
10:28:02 Freitag, 21. März 2025 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
10:29:17 Freitag, 21. März 2025 : orLibraryDownLoad.exe returned : 0
10:29:17 Freitag, 21. März 2025 : Library Installation completed successfully.
10:29:17 Freitag, 21. März 2025 : Downloading License file
10:29:18 Freitag, 21. März 2025 : error_code cdsVblDownloadLicense: -15
10:29:18 Freitag, 21. März 2025 : strErrorMsgDesc: License request is still in queue. Retry again in 60 seconds. (-2032)
10:29:18 Freitag, 21. März 2025 : Downloading License file finish
10:29:18 Freitag, 21. März 2025 : Message: License file could not be downloaded.
Do you want to try downloading again?
10:31:17 Freitag, 21. März 2025 : Removing generic credentials.
10:31:17 Freitag, 21. März 2025 : PrepareUninstallation
10:31:18 Freitag, 21. März 2025 : strLocalPath: C:\Users\$atobolar\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
10:31:18 Freitag, 21. März 2025 : strLocalConfigPath: C:\Users\$atobolar\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
10:31:18 Freitag, 21. März 2025 : strCachedLocForFV174Installer: "C:\Users\$atobolar\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
10:31:18 Freitag, 21. März 2025 : Writing bundle information
10:31:18 Freitag, 21. März 2025 : ClearRunOnceIfNotNeeded()
10:31:18 Freitag, 21. März 2025 : installSetupValue =
10:32:42 Freitag, 21. März 2025 : parameter count = 1
10:32:42 Freitag, 21. März 2025 : -wrapper
10:32:42 Freitag, 21. März 2025 : Module Name: TIPSpice.exe
10:32:42 Freitag, 21. März 2025 : Server OS = False
10:32:42 Freitag, 21. März 2025 : Operating system version : 10.0.0.0
10:32:42 Freitag, 21. März 2025 : Checking for proxy
10:32:42 Freitag, 21. März 2025 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
10:32:42 Freitag, 21. März 2025 : Checking if Licensing URL is accessible
10:32:43 Freitag, 21. März 2025 : Initializing
10:32:43 Freitag, 21. März 2025 : Deleting file : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
10:32:43 Freitag, 21. März 2025 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
10:32:43 Freitag, 21. März 2025 : Response Content length = 1766
10:32:43 Freitag, 21. März 2025 : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
10:32:43 Freitag, 21. März 2025 : Reading Json URL File
10:32:43 Freitag, 21. März 2025 : setting media download server URL from Json File
10:32:43 Freitag, 21. März 2025 : setting default production Dll server URL
10:32:43 Freitag, 21. März 2025 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v2
10:32:43 Freitag, 21. März 2025 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
10:32:43 Freitag, 21. März 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 23.10.001
10:32:43 Freitag, 21. März 2025 : Repair mode
10:32:43 Freitag, 21. März 2025 : Check if CDS_HOME is set
10:32:43 Freitag, 21. März 2025 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
10:32:43 Freitag, 21. März 2025 : LaunchTIPSpiceDlgs()
10:32:43 Freitag, 21. März 2025 : Checking for compnts.dat
10:33:48 Freitag, 21. März 2025 : error_code cdsVblAuthenticateUser: VblSuccess
10:33:49 Freitag, 21. März 2025 : error_code cdsVblRegisterInstallation: VblSuccess
10:33:49 Freitag, 21. März 2025 : error_code cdsVblRequestLicense: VblSuccess
10:33:52 Freitag, 21. März 2025 : Set Installation and Home Directory()
10:33:56 Freitag, 21. März 2025 : Checking for memory space
10:33:56 Freitag, 21. März 2025 : Memory space available
10:33:56 Freitag, 21. März 2025 : Target Dir: C:\Cadence\PSpiceTI
10:33:56 Freitag, 21. März 2025 : Working Dir: C:\cds_spb_home
10:33:56 Freitag, 21. März 2025 : Silent ini file created
10:33:56 Freitag, 21. März 2025 : Skipping download of 0x0409.ini DataSize is 22480
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
10:33:56 Freitag, 21. März 2025 : Skipping download of data1.hdr DataSize is 6548172
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
10:33:56 Freitag, 21. März 2025 : Skipping download of data1.cab DataSize is 31832538
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
10:33:56 Freitag, 21. März 2025 : Skipping download of ISSetup.dll DataSize is 1644152
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
10:33:56 Freitag, 21. März 2025 : Skipping download of layout.bin DataSize is 1106
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
10:33:56 Freitag, 21. März 2025 : Skipping download of pspInstall.pdf DataSize is 85357
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
10:33:56 Freitag, 21. März 2025 : Skipping download of setup.bmp DataSize is 414056
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
10:33:56 Freitag, 21. März 2025 : Skipping download of setup.ini DataSize is 2604
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
10:33:56 Freitag, 21. März 2025 : Skipping download of setup.inx DataSize is 575829
10:33:56 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
10:33:57 Freitag, 21. März 2025 : Skipping download of data2.cab DataSize is 168572928
10:33:57 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
10:33:57 Freitag, 21. März 2025 : Skipping download of data11.cab DataSize is 18414103
10:33:57 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data11.cab
10:33:57 Freitag, 21. März 2025 : Skipping download of data3.cab DataSize is 209715200
10:33:57 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
10:33:58 Freitag, 21. März 2025 : Skipping download of data10.cab DataSize is 209715200
10:33:58 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data10.cab
10:33:58 Freitag, 21. März 2025 : Skipping download of data9.cab DataSize is 209715200
10:33:58 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
10:33:59 Freitag, 21. März 2025 : Skipping download of data8.cab DataSize is 209715200
10:33:59 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
10:33:59 Freitag, 21. März 2025 : Skipping download of data7.cab DataSize is 209715200
10:33:59 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
10:34:00 Freitag, 21. März 2025 : Skipping download of data6.cab DataSize is 209715200
10:34:00 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
10:34:00 Freitag, 21. März 2025 : Skipping download of data5.cab DataSize is 209715200
10:34:00 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
10:34:00 Freitag, 21. März 2025 : Skipping download of installsetup.exe DataSize is 966264
10:34:00 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
10:34:01 Freitag, 21. März 2025 : 67920 67920
10:34:01 Freitag, 21. März 2025 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
10:34:01 Freitag, 21. März 2025 : Skipping download of data4.cab DataSize is 209715200
10:34:01 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
10:34:01 Freitag, 21. März 2025 : Allegro Installation Start pid: 13344
10:34:08 Freitag, 21. März 2025 : NumberOfComponentsToBeInstalled = 51751
10:34:08 Freitag, 21. März 2025 : Updated NumberOfComponentsToBeInstalled = 52791,69
10:34:08 Freitag, 21. März 2025 : Updated NumberOfComponentsInstalled = 518
10:39:04 Freitag, 21. März 2025 : Feature transfer complete..disabling close button
10:39:04 Freitag, 21. März 2025 : Installing: Extracting archives
10:39:04 Freitag, 21. März 2025 : Installing: Runtime packages and redistributables
10:39:04 Freitag, 21. März 2025 : Installing: Updating Admin batch actions
10:39:04 Freitag, 21. März 2025 : Installing: Executing post install script
10:39:05 Freitag, 21. März 2025 : Installing: Creating user library
10:39:21 Freitag, 21. März 2025 : Installing: Configuring documentation
10:39:25 Freitag, 21. März 2025 : Installing: Configuring file associations
10:39:25 Freitag, 21. März 2025 : Installing: Setting permissions for files and folders
10:39:26 Freitag, 21. März 2025 : Installing: Creating Registries
10:39:26 Freitag, 21. März 2025 : Installing: SQL Lite ODBC Driver
10:39:26 Freitag, 21. März 2025 : Installing: Finishing Installation
10:39:45 Freitag, 21. März 2025 : Running Library Configuration Executable
10:39:45 Freitag, 21. März 2025 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
10:40:59 Freitag, 21. März 2025 : orLibraryDownLoad.exe returned : 0
10:40:59 Freitag, 21. März 2025 : Library Installation completed successfully.
10:40:59 Freitag, 21. März 2025 : Downloading License file
10:40:59 Freitag, 21. März 2025 : error_code cdsVblDownloadLicense: -15
10:40:59 Freitag, 21. März 2025 : strErrorMsgDesc: License request is still in queue. Retry again in 60 seconds. (-2032)
10:40:59 Freitag, 21. März 2025 : Downloading License file finish
10:40:59 Freitag, 21. März 2025 : Message: License file could not be downloaded.
10:45:27 Freitag, 21. März 2025 : Trying Downloading License file again
10:45:27 Freitag, 21. März 2025 : Downloading License file
10:45:28 Freitag, 21. März 2025 : error_code cdsVblDownloadLicense: -15
10:45:28 Freitag, 21. März 2025 : strErrorMsgDesc: License request is still in queue. Retry again in 60 seconds. (-2032)
10:45:28 Freitag, 21. März 2025 : Downloading License file finish
10:45:28 Freitag, 21. März 2025 : Removing generic credentials.
10:45:28 Freitag, 21. März 2025 : PrepareUninstallation
10:45:28 Freitag, 21. März 2025 : strLocalPath: C:\Users\$atobolar\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
10:45:28 Freitag, 21. März 2025 : strCachedLocForFV174Installer: "C:\Users\$atobolar\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
10:45:28 Freitag, 21. März 2025 : Writing bundle information
10:45:28 Freitag, 21. März 2025 : ClearRunOnceIfNotNeeded()
10:45:28 Freitag, 21. März 2025 : installSetupValue =
10:49:34 Freitag, 21. März 2025 : parameter count = 1
10:49:34 Freitag, 21. März 2025 : -wrapper
10:49:34 Freitag, 21. März 2025 : Module Name: TIPSpice.exe
10:49:34 Freitag, 21. März 2025 : Server OS = False
10:49:34 Freitag, 21. März 2025 : Operating system version : 10.0.0.0
10:49:34 Freitag, 21. März 2025 : Checking for proxy
10:49:34 Freitag, 21. März 2025 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
10:49:34 Freitag, 21. März 2025 : Checking if Licensing URL is accessible
10:49:35 Freitag, 21. März 2025 : Initializing
10:49:35 Freitag, 21. März 2025 : Deleting file : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
10:49:35 Freitag, 21. März 2025 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
10:49:35 Freitag, 21. März 2025 : Response Content length = 1766
10:49:35 Freitag, 21. März 2025 : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
10:49:35 Freitag, 21. März 2025 : Reading Json URL File
10:49:35 Freitag, 21. März 2025 : setting media download server URL from Json File
10:49:35 Freitag, 21. März 2025 : setting default production Dll server URL
10:49:35 Freitag, 21. März 2025 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v2
10:49:35 Freitag, 21. März 2025 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
10:49:35 Freitag, 21. März 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 23.10.001
10:49:35 Freitag, 21. März 2025 : Repair mode
10:49:35 Freitag, 21. März 2025 : Check if CDS_HOME is set
10:49:35 Freitag, 21. März 2025 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
10:49:35 Freitag, 21. März 2025 : LaunchTIPSpiceDlgs()
10:49:35 Freitag, 21. März 2025 : Checking for compnts.dat
10:49:35 Freitag, 21. März 2025 : Product is installed and compnts.dat does not exist
10:49:36 Freitag, 21. März 2025 : Message: The installed product could not be determined, and the system needs to be cleaned up. Click OK to clean up the system and proceed with installation or click Cancel to exit installation.
10:50:05 Freitag, 21. März 2025 : Cleaning installation
10:50:05 Freitag, 21. März 2025 : strPerUserStartMenuFolder: C:\Users\$atobolar\AppData\Roaming\Microsoft\Windows\Start Menu
10:50:05 Freitag, 21. März 2025 : strShortcutFolder1: C:\Users\$atobolar\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PSpice for TI
10:50:05 Freitag, 21. März 2025 : Shortcuts removed
10:50:05 Freitag, 21. März 2025 : Exception Occured while deleting Temp folder: Der Zugriff auf den Pfad "Uninstall.exe.config" wurde verweigert.
10:50:05 Freitag, 21. März 2025 : Clearing Registry settings
10:50:05 Freitag, 21. März 2025 : Cleared Registry settings
10:51:33 Freitag, 21. März 2025 : parameter count = 1
10:51:33 Freitag, 21. März 2025 : -wrapper
10:51:33 Freitag, 21. März 2025 : Module Name: TIPSpice.exe
10:51:33 Freitag, 21. März 2025 : Server OS = False
10:51:33 Freitag, 21. März 2025 : Operating system version : 10.0.0.0
10:51:33 Freitag, 21. März 2025 : Checking for proxy
10:51:33 Freitag, 21. März 2025 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
10:51:33 Freitag, 21. März 2025 : Checking if Licensing URL is accessible
10:51:34 Freitag, 21. März 2025 : Initializing
10:51:34 Freitag, 21. März 2025 : Deleting file : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
10:51:34 Freitag, 21. März 2025 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
10:51:34 Freitag, 21. März 2025 : Response Content length = 1766
10:51:34 Freitag, 21. März 2025 : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
10:51:34 Freitag, 21. März 2025 : Reading Json URL File
10:51:34 Freitag, 21. März 2025 : setting media download server URL from Json File
10:51:34 Freitag, 21. März 2025 : setting default production Dll server URL
10:51:34 Freitag, 21. März 2025 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v2
10:51:34 Freitag, 21. März 2025 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
10:51:34 Freitag, 21. März 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system:
10:51:34 Freitag, 21. März 2025 : LaunchTIPSpiceDlgs()
10:51:34 Freitag, 21. März 2025 : Checking for compnts.dat
10:52:18 Freitag, 21. März 2025 : error_code cdsVblAuthenticateUser: VblSuccess
10:52:18 Freitag, 21. März 2025 : error_code cdsVblRegisterInstallation: VblSuccess
10:52:19 Freitag, 21. März 2025 : error_code cdsVblRequestLicense: VblSuccess
10:52:21 Freitag, 21. März 2025 : Set Installation and Home Directory()
10:52:21 Freitag, 21. März 2025 : Setting default Installation directory : C:\Cadence\PSpiceTI
10:52:21 Freitag, 21. März 2025 : Reading CDS_HOME environment variable
10:52:21 Freitag, 21. März 2025 : CDS_HOME is present and set to C:\cds_spb_home. No need to set CDS_HOME
10:52:23 Freitag, 21. März 2025 : Checking for memory space
10:52:23 Freitag, 21. März 2025 : Memory space available
10:52:23 Freitag, 21. März 2025 : Target Dir: C:\Cadence\PSpiceTI
10:52:23 Freitag, 21. März 2025 : Working Dir: C:\cds_spb_home
10:52:23 Freitag, 21. März 2025 : Silent ini file created
10:52:25 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini Status is OK
10:52:25 Freitag, 21. März 2025 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
10:52:25 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
10:52:25 Freitag, 21. März 2025 : Completing download of 0x0409.ini
10:52:25 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab Status is OK
10:52:25 Freitag, 21. März 2025 : Starting download of data1.cab Attempt no 1 DataSize is 31832538
10:52:26 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr Status is OK
10:52:26 Freitag, 21. März 2025 : Starting download of data1.hdr Attempt no 1 DataSize is 6548172
10:52:26 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
10:52:27 Freitag, 21. März 2025 : Completing download of data1.cab
10:52:27 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
10:52:27 Freitag, 21. März 2025 : Completing download of data1.hdr
10:52:27 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll Status is OK
10:52:27 Freitag, 21. März 2025 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1644152
10:52:27 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
10:52:28 Freitag, 21. März 2025 : Completing download of ISSetup.dll
10:52:28 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab Status is OK
10:52:28 Freitag, 21. März 2025 : Starting download of data2.cab Attempt no 1 DataSize is 168572928
10:52:30 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin Status is OK
10:52:30 Freitag, 21. März 2025 : Starting download of layout.bin Attempt no 1 DataSize is 1106
10:52:30 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
10:52:30 Freitag, 21. März 2025 : Completing download of layout.bin
10:52:31 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
10:52:31 Freitag, 21. März 2025 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
10:52:31 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
10:52:31 Freitag, 21. März 2025 : Completing download of pspInstall.pdf
10:52:33 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp Status is OK
10:52:33 Freitag, 21. März 2025 : Starting download of setup.bmp Attempt no 1 DataSize is 414056
10:52:33 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
10:52:33 Freitag, 21. März 2025 : Completing download of setup.bmp
10:52:34 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini Status is OK
10:52:34 Freitag, 21. März 2025 : Starting download of setup.ini Attempt no 1 DataSize is 2604
10:52:34 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
10:52:34 Freitag, 21. März 2025 : Completing download of setup.ini
10:52:34 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
10:52:35 Freitag, 21. März 2025 : Completing download of data2.cab
10:52:36 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab Status is OK
10:52:36 Freitag, 21. März 2025 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
10:52:36 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx Status is OK
10:52:36 Freitag, 21. März 2025 : Starting download of setup.inx Attempt no 1 DataSize is 575829
10:52:36 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
10:52:36 Freitag, 21. März 2025 : Completing download of setup.inx
10:52:37 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data11.cab Status is OK
10:52:37 Freitag, 21. März 2025 : Starting download of data11.cab Attempt no 1 DataSize is 18414103
10:52:38 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data11.cab
10:52:38 Freitag, 21. März 2025 : Completing download of data11.cab
10:52:40 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data10.cab Status is OK
10:52:40 Freitag, 21. März 2025 : Starting download of data10.cab Attempt no 1 DataSize is 209715200
10:52:44 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
10:52:45 Freitag, 21. März 2025 : Completing download of data3.cab
10:52:47 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab Status is OK
10:52:47 Freitag, 21. März 2025 : Starting download of data9.cab Attempt no 1 DataSize is 209715200
10:52:48 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data10.cab
10:52:49 Freitag, 21. März 2025 : Completing download of data10.cab
10:52:50 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab Status is OK
10:52:50 Freitag, 21. März 2025 : Starting download of data8.cab Attempt no 1 DataSize is 209715200
10:52:55 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
10:52:56 Freitag, 21. März 2025 : Completing download of data9.cab
10:52:57 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab Status is OK
10:52:57 Freitag, 21. März 2025 : Starting download of data7.cab Attempt no 1 DataSize is 209715200
10:52:58 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
10:52:59 Freitag, 21. März 2025 : Completing download of data8.cab
10:53:00 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab Status is OK
10:53:00 Freitag, 21. März 2025 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
10:53:04 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
10:53:05 Freitag, 21. März 2025 : Completing download of data7.cab
10:53:06 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab Status is OK
10:53:06 Freitag, 21. März 2025 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
10:53:08 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
10:53:09 Freitag, 21. März 2025 : Completing download of data6.cab
10:53:10 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab Status is OK
10:53:10 Freitag, 21. März 2025 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
10:53:14 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
10:53:15 Freitag, 21. März 2025 : Completing download of data5.cab
10:53:17 Freitag, 21. März 2025 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe Status is OK
10:53:17 Freitag, 21. März 2025 : Starting download of installsetup.exe Attempt no 1 DataSize is 966264
10:53:18 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
10:53:18 Freitag, 21. März 2025 : Completing download of installsetup.exe
10:53:19 Freitag, 21. März 2025 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
10:53:20 Freitag, 21. März 2025 : 524598 524598
10:53:20 Freitag, 21. März 2025 : Completing download of data4.cab
10:53:20 Freitag, 21. März 2025 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
10:53:21 Freitag, 21. März 2025 : Allegro Installation Start pid: 16076
10:53:28 Freitag, 21. März 2025 : NumberOfComponentsToBeInstalled = 51751
10:53:28 Freitag, 21. März 2025 : Updated NumberOfComponentsToBeInstalled = 52791,69
10:53:28 Freitag, 21. März 2025 : Updated NumberOfComponentsInstalled = 518
10:57:54 Freitag, 21. März 2025 : Feature transfer complete..disabling close button
10:57:54 Freitag, 21. März 2025 : Installing: Extracting archives
10:57:54 Freitag, 21. März 2025 : Installing: Runtime packages and redistributables
10:57:54 Freitag, 21. März 2025 : Installing: Updating Admin batch actions
10:57:55 Freitag, 21. März 2025 : Installing: Executing post install script
10:57:55 Freitag, 21. März 2025 : Installing: Creating user library
10:58:11 Freitag, 21. März 2025 : Installing: Configuring documentation
10:58:13 Freitag, 21. März 2025 : Installing: Configuring file associations
10:58:14 Freitag, 21. März 2025 : Installing: Setting permissions for files and folders
10:58:14 Freitag, 21. März 2025 : Installing: Creating Registries
10:58:14 Freitag, 21. März 2025 : Installing: SQL Lite ODBC Driver
10:58:15 Freitag, 21. März 2025 : Installing: Finishing Installation
10:58:31 Freitag, 21. März 2025 : Running Library Configuration Executable
10:58:31 Freitag, 21. März 2025 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
10:59:43 Freitag, 21. März 2025 : orLibraryDownLoad.exe returned : 0
10:59:43 Freitag, 21. März 2025 : Library Installation completed successfully.
10:59:43 Freitag, 21. März 2025 : Downloading License file
10:59:43 Freitag, 21. März 2025 : error_code cdsVblDownloadLicense: -15
10:59:43 Freitag, 21. März 2025 : strErrorMsgDesc: License request is still in queue. Retry again in 60 seconds. (-2032)
10:59:43 Freitag, 21. März 2025 : Downloading License file finish
10:59:43 Freitag, 21. März 2025 : Message: License file could not be downloaded.
11:00:00 Freitag, 21. März 2025 : Removing generic credentials.
11:00:00 Freitag, 21. März 2025 : PrepareUninstallation
11:00:00 Freitag, 21. März 2025 : strLocalPath: C:\Users\$atobolar\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
11:00:00 Freitag, 21. März 2025 : strCachedLocForFV174Installer: "C:\Users\$atobolar\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
11:00:00 Freitag, 21. März 2025 : Writing bundle information
11:00:00 Freitag, 21. März 2025 : ClearRunOnceIfNotNeeded()
11:00:00 Freitag, 21. März 2025 : installSetupValue =
11:03:45 Freitag, 21. März 2025 : parameter count = 0
11:03:45 Freitag, 21. März 2025 : Module Name: TIPSpice.exe
11:03:45 Freitag, 21. März 2025 : Server OS = False
11:03:45 Freitag, 21. März 2025 : Operating system version : 10.0.0.0
11:03:45 Freitag, 21. März 2025 : Checking for proxy
11:03:45 Freitag, 21. März 2025 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
11:03:45 Freitag, 21. März 2025 : Checking if Licensing URL is accessible
11:03:46 Freitag, 21. März 2025 : Initializing
11:03:46 Freitag, 21. März 2025 : Deleting file : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
11:03:46 Freitag, 21. März 2025 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:03:46 Freitag, 21. März 2025 : Response Content length = 1766
11:03:46 Freitag, 21. März 2025 : C:\Users\$atobolar\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
11:03:46 Freitag, 21. März 2025 : Reading Json URL File
11:03:46 Freitag, 21. März 2025 : setting media download server URL from Json File
11:03:46 Freitag, 21. März 2025 : setting default production Dll server URL
11:03:46 Freitag, 21. März 2025 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v2
11:03:46 Freitag, 21. März 2025 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
11:03:47 Freitag, 21. März 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 23.10.001
11:03:47 Freitag, 21. März 2025 : Repair mode
11:03:47 Freitag, 21. März 2025 : Check if CDS_HOME is set
11:03:47 Freitag, 21. März 2025 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
11:03:47 Freitag, 21. März 2025 : LaunchTIPSpiceDlgs()
11:03:47 Freitag, 21. März 2025 : Checking for compnts.dat
11:03:58 Freitag, 21. März 2025 : error_code cdsVblAuthenticateUser: VblSuccess
11:03:58 Freitag, 21. März 2025 : error_code cdsVblRegisterInstallation: VblSuccess
11:03:59 Freitag, 21. März 2025 : error_code cdsVblRequestLicense: VblSuccess
11:04:01 Freitag, 21. März 2025 : Set Installation and Home Directory()
