PSPICE-FOR-TI: Pspice installation issue
Part Number: PSPICE-FOR-TI
I was unable to install the pspice for TI application. It showing unable to access user licensing data.
  • Hi Ram,
    Would you please provide this file?
    "C:\Users\{YOUR_USER_NAME}\AppData\Roaming\Cadence\PSpiceTIInstall\cdsPspiceTIlog.txt"
    JC
  • Hello JC Zhu,
    Apologies for the delayed response.
    Please find the cdsPspiceTIlog.txt file attached
    16:13:10 14 April 2025 : parameter count = 1
    16:13:10 14 April 2025 : -wrapper
    16:13:10 14 April 2025 : Module Name: TIPSpice.exe
    16:13:10 14 April 2025 : Server OS = False
    16:13:10 14 April 2025 : Operating system version : 10.0.0.0
    16:13:10 14 April 2025 : Checking for proxy
    16:13:11 14 April 2025 : {
    "LibUpdate_DeltaZip": "">software-dl.ti.com/.../delta.zip",
    "LibUpdate_VersionTxt": "">software-dl.ti.com/.../Pspice_Lib_Version.txt",
    "LibUpdate_UpdateDelta": "">software-dl.ti.com/.../UpdateDelta.json",
    "LibUpdate_UpdateConfig": "">software-dl.ti.com/.../UpdateConfigure.json",
    "LibUpdate_LibMetadata": "">software-dl.ti.com/.../library.json",
    "LibFirstInstall_LibraryZip": "">software-dl.ti.com/.../library.zip",
    "LibFirstInstall_LatestVersion": "23.10.001",
    "Installer_DownloadXML": "">software-dl.ti.com/.../PSpiceForTIXML.xml",
    "Installer_BasePath": "">software-dl.ti.com/.../installer",
    "Installer_DownloadSetup": "">software-dl.ti.com/.../PSpice-For-TI_setup.exe",
    "Licensing_URL": "">cdsplicwc.cadence.com/.../v1",
    "SoftwareUpdate_Expiry": {
    "Timestamp": "01:15:2099 15:07:19 GMT",
    "RegularMessage": {
    "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
    "HyperLink": "license agreement",
    "PostHyperLink": "."
    "ForceMessage": {
    "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
    "PostHyperLink": ". Click Cancel to exit."
    "UTM_Keyword": {
    "TIPSpice_Install": "HQS=pspiceforti",
    "Full_Install": "HQS=pspiceforti"
    "TI_URLs_Version": [
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    16:13:11 14 April 2025 : Checking if Licensing URL is accessible
    16:13:12 14 April 2025 : Initializing
    16:13:12 14 April 2025 : Downloading URLs file from : pcb.cadence.com/.../TI_URLs.txt
    16:13:13 14 April 2025 : Response Content length = 1766
    16:13:13 14 April 2025 : C:\Users\chintapallive.c\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
    16:13:13 14 April 2025 : Reading Json URL File
    16:13:13 14 April 2025 : setting media download server URL from Json File
    16:13:13 14 April 2025 : setting default production Dll server URL
    16:13:13 14 April 2025 : Chws URL is: cdsplicwc.cadence.com/.../v2
    16:13:13 14 April 2025 : DownloadServerPath is: software-dl.ti.com/.../installer
    16:13:14 14 April 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 17.40.009
    16:13:14 14 April 2025 : Check if CDS_HOME is set
    16:13:14 14 April 2025 : Neither CDS_HOME nor HOME exists on the machine in update mode.
    16:13:14 14 April 2025 : Message: Neither CDS_HOME nor HOME exists on the machine during update.
    CDS_HOME will be set to default working directory : C:\cds_spb_home
    Click Yes to continue or No to abort the installation.
    16:13:27 14 April 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 17.40.009
    16:13:27 14 April 2025 : Manual update mode
    16:13:27 14 April 2025 : LaunchTIPSpiceDlgs()
    16:13:27 14 April 2025 : Checking for memory space
    16:13:27 14 April 2025 : Memory space available
    16:13:27 14 April 2025 : Fetching user account
    16:13:28 14 April 2025 : error_code cdsVblGetProductKey: -30
    16:13:28 14 April 2025 : Error fetching Product Key
    16:13:28 14 April 2025 : strErrorMsgDesc: Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:13:28 14 April 2025 : Product Key Retrieval failed in update mode with error : Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:13:28 14 April 2025 : Message: Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:13:33 14 April 2025 : Aborting update installation.
    16:14:06 14 April 2025 : parameter count = 1
    16:14:06 14 April 2025 : -wrapper
    16:14:06 14 April 2025 : Module Name: TIPSpice.exe
    16:14:06 14 April 2025 : Server OS = False
    16:14:06 14 April 2025 : Operating system version : 10.0.0.0
    16:14:06 14 April 2025 : Checking for proxy
    16:14:07 14 April 2025 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    16:14:07 14 April 2025 : Checking if Licensing URL is accessible
    16:14:08 14 April 2025 : Initializing
    16:14:08 14 April 2025 : Deleting file : C:\Users\chintapallive.c\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
    16:14:08 14 April 2025 : Downloading URLs file from : pcb.cadence.com/.../TI_URLs.txt
    16:14:08 14 April 2025 : Response Content length = 1766
    16:14:08 14 April 2025 : C:\Users\chintapallive.c\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
    16:14:08 14 April 2025 : Reading Json URL File
    16:14:08 14 April 2025 : setting media download server URL from Json File
    16:14:08 14 April 2025 : setting default production Dll server URL
    16:14:08 14 April 2025 : Chws URL is: cdsplicwc.cadence.com/.../v2
    16:14:08 14 April 2025 : DownloadServerPath is: software-dl.ti.com/.../installer
    16:14:10 14 April 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 17.40.009
    16:14:10 14 April 2025 : Check if CDS_HOME is set
    16:14:10 14 April 2025 : Neither CDS_HOME nor HOME exists on the machine in update mode.
    16:14:10 14 April 2025 : Message: Neither CDS_HOME nor HOME exists on the machine during update.
    16:14:33 14 April 2025 : ReleaseVersion in XML: 23.10.001 InstalledVersion on system: 17.40.009
    16:14:33 14 April 2025 : Manual update mode
    16:14:33 14 April 2025 : LaunchTIPSpiceDlgs()
    16:14:34 14 April 2025 : Checking for memory space
    16:14:34 14 April 2025 : Memory space available
    16:14:34 14 April 2025 : Fetching user account
    16:14:34 14 April 2025 : error_code cdsVblGetProductKey: -30
    16:14:34 14 April 2025 : Error fetching Product Key
    16:14:34 14 April 2025 : strErrorMsgDesc: Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:14:34 14 April 2025 : Product Key Retrieval failed in update mode with error : Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:14:34 14 April 2025 : Message: Unable to access user licensing data. For further assistance, go to http://e2e.ti.com. (-2014)
    16:33:00 14 April 2025 : Aborting update installation.
  • Hi Ram,
    would you please provide this file as well?
    "C:\Users\{YOUR_USER_NAME}\AppData\Roaming\Cadence\PSpiceTIInstall\cdsPSpiceNetworkStatus.txt"
    JC
  • Yes, Sure.
    Please find the cdsPSpiceNetworkStatus.txt file attached.
    The PSpice for TI installer accesses the internet to download and install various packages. Before starting the installer, ensure the following:
    1. Internet connection is available
    2. Security protocol TLS 1.2 is enabled
    3. Following endpoints or resource locations are accessible from the system:
    a. pcb.cadence.com/startPages
    b. software-dl.ti.com/pspice
    c. cdsplicwc.cadence.com/chws
    If proxy credentials are required to access the Internet, provide the same when requested by the installer.
    16:14:06 14 April 2025 : *****CONNECTION STATUS CHECK*****
    16:14:06 14 April 2025 : Internet Connection : Available (Passed)
    16:14:06 14 April 2025 : Security Protocol TLS 1.2: Available. If PSpice for TI installation fails, unblock TLS 1.2
    16:14:07 14 April 2025 : Proxy Test : Proxy Credentials not needed
  • Thanks. We'll look into this.
    -JC
  • Hi Ram,
    Would you please ask your IT team to unblock TLS 1.2, as suggested in the log file?
    JC
