Part Number: TIDA-01386
Other Parts Discussed in Thread: TUSS4440, , PGA460, TUSS4470, IWRL6432
Hi, Kindly find brief description of a problem statement for which I have been developing a 2x AA battery powered device (should last atleast 6 month). My measurement/distance sensing interval would be around 15 mins to 30 mins time interval. At present I have developed a system using cheap HC SR04 interfaced using MSP430 based ultra low power MCU. I am not able to achieve the desired coverage range since the beam/sensing angel of HC SR04 is about 15 degree only. In order achieve good range either I may need to double up the HC SR04 sensor (FAN based orientation) or use costly Ultrasonic sensors such as MB1001/MB1010 which cost USD 25 for each.
I would like to know if there are any other options of low power sensors which can used in order to improve my coverage range and provide me with much better and reliable readings.
Kindly suggest, Thanks.
Piyush
