Other Parts Discussed in Thread: LM51770, UCD3138
Hi TI Team,
I have following questions related to this reference design guide.
Can PMP23377 be adapted to operate as a true 4-switch bidirectional converter (e.g., with firmware updates or minor hardware changes), or is it intended as a unidirectional design?
If we need bidirectional capability:
Can LM51770 or a similar controller be adapted to manage both charge and discharge using phase current control?
If not, do you recommend UCD3138 instead for better state-machine-level bidirectional management?
Since PMP23377 operates at 1.4 kW per phase, would 3–4 interleaved phases be acceptable to reach 5 kW in discharge mode? What thermal considerations should we plan for in this power density?
Is there any public firmware or codebase available for PMP23377 or LM51770 showing power stage control, phase sync, or telemetry logic?
Lastly, any PCB layout recommendations or documents for high-current bidirectional routing (100 A+ continuous) in this topology would be appreciated.
Your Help in very valuable. Looking forward to hear from you.
