PSPICE-FOR-TI: cannot install
Part Number: PSPICE-FOR-TI
"LibUpdate_DeltaZip": "">software-dl.ti.com/.../delta.zip",
"LibUpdate_VersionTxt": "">software-dl.ti.com/.../Pspice_Lib_Version.txt",
"LibUpdate_UpdateDelta": "">software-dl.ti.com/.../UpdateDelta.json",
"LibUpdate_UpdateConfig": "">software-dl.ti.com/.../UpdateConfigure.json",
"LibUpdate_LibMetadata": "">software-dl.ti.com/.../library.json",
"LibFirstInstall_LibraryZip": "">software-dl.ti.com/.../library.zip",
"LibFirstInstall_LatestVersion": "23.10.001",
"Installer_DownloadXML": "">software-dl.ti.com/.../PSpiceForTIXML.xml",
"Installer_BasePath": "">software-dl.ti.com/.../installer",
"Installer_DownloadSetup": "">software-dl.ti.com/.../PSpice-For-TI_setup.exe",
"Licensing_URL": "">cdsplicwc.cadence.com/.../v1",
13:53:10 July 15, 2025: Checking if Licensing URL is accessible
13:53:11 July 15, 2025: Error Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
13:53:11 July 15, 2025: Inner Exception: The remote certificate is invalid according to the validation procedure.
13:53:11 July 15, 2025: Message: Unable to access the URL required for installation. Check if the URL is accessible and then try again.
URL: https://cdsplicwc.cadence.com/chws/test/connection.html
Error Description: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
View log file for details at
  • Hi Cade,
    What happens if you click that URL?
    JC
  • Licensing_URL
    Not Found
    The requested resource was not found on this server.
  • Even if I use my mobile phone to visit the web, the same result will be obtained
  • it should show "Successful connection". Please generate some debug information as follows:
    1. Create a new environment variable "CDS_LIC_QA_TesT". Set it to something like "C:\Cadence\PSpiceTI\LicLog.txt".
    2. Run PSpice for TI installer, wait for the error message, then check if the file "C:\Cadence\PSpiceTI\LicLog.txt" is created.
    3. share the file LicLog.txt
    4. Delete the environment variable "CDS_LIC_QA_TesT".
    JC
  • I tried but nothing created even reboot the machine
  • would you please share the files cdsPspiceTIlog.txt and cdsPSpiceNetworkStatus.txt?
  • 13:20:02 2025年7月15日 : parameter count = 1
    13:20:02 2025年7月15日 : -wrapper
    13:20:02 2025年7月15日 : Module Name: TIPSpice.exe
    13:20:02 2025年7月15日 : Server OS = False
    13:20:02 2025年7月15日 : Operating system version : 10.0.0.0
    13:20:02 2025年7月15日 : Checking for proxy
    13:20:25 2025年7月15日 : {
    "SoftwareUpdate_Expiry": {
    "Timestamp": "01:15:2099 15:07:19 GMT",
    "RegularMessage": {
    "PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
    "HyperLink": "license agreement",
    "PostHyperLink": "."
    "ForceMessage": {
    "PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
    "PostHyperLink": ". Click Cancel to exit."
    "UTM_Keyword": {
    "TIPSpice_Install": "HQS=pspiceforti",
    "Full_Install": "HQS=pspiceforti"
    "TI_URLs_Version": [
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    13:20:25 2025年7月15日 : Checking if Licensing URL is accessible
    13:20:26 2025年7月15日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    13:20:26 2025年7月15日 : Inner Exception : 根据验证过程,远程证书无效。
    13:20:27 2025年7月15日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    URL: cdsplicwc.cadence.com/.../connection.html
    Error Description: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    View log file for details at C:\Users\cade.chen\AppData\Roaming\Cadence\PspiceTIInstall\cdsPspiceTIlog.txt
    13:31:23 2025年7月15日 : parameter count = 1
    13:31:23 2025年7月15日 : -wrapper
    13:31:23 2025年7月15日 : Module Name: TIPSpice.exe
    13:31:23 2025年7月15日 : Server OS = False
    13:31:23 2025年7月15日 : Operating system version : 10.0.0.0
    13:31:23 2025年7月15日 : Checking for proxy
    13:31:24 2025年7月15日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    13:31:24 2025年7月15日 : Checking if Licensing URL is accessible
    13:31:25 2025年7月15日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    13:31:25 2025年7月15日 : Inner Exception : 根据验证过程,远程证书无效。
    13:31:25 2025年7月15日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    13:53:08 2025年7月15日 : parameter count = 1
    13:53:08 2025年7月15日 : -wrapper
    13:53:09 2025年7月15日 : Module Name: TIPSpice.exe
    13:53:09 2025年7月15日 : Server OS = False
    13:53:09 2025年7月15日 : Operating system version : 10.0.0.0
    13:53:09 2025年7月15日 : Checking for proxy
    13:53:10 2025年7月15日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    13:53:10 2025年7月15日 : Checking if Licensing URL is accessible
    13:53:11 2025年7月15日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    13:53:11 2025年7月15日 : Inner Exception : 根据验证过程,远程证书无效。
    13:53:11 2025年7月15日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:01:20 2025年7月17日 : parameter count = 1
    10:01:20 2025年7月17日 : -wrapper
    10:01:21 2025年7月17日 : Module Name: TIPSpice.exe
    10:01:21 2025年7月17日 : Server OS = False
    10:01:21 2025年7月17日 : Operating system version : 10.0.0.0
    10:01:21 2025年7月17日 : Checking for proxy
    10:01:22 2025年7月17日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    10:01:22 2025年7月17日 : Checking if Licensing URL is accessible
    10:01:23 2025年7月17日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:01:23 2025年7月17日 : Inner Exception : 根据验证过程,远程证书无效。
    10:01:24 2025年7月17日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:03:21 2025年7月17日 : parameter count = 1
    10:03:21 2025年7月17日 : -wrapper
    10:03:21 2025年7月17日 : Module Name: TIPSpice.exe
    10:03:21 2025年7月17日 : Server OS = False
    10:03:21 2025年7月17日 : Operating system version : 10.0.0.0
    10:03:21 2025年7月17日 : Checking for proxy
    10:03:24 2025年7月17日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    10:03:24 2025年7月17日 : Checking if Licensing URL is accessible
    10:03:25 2025年7月17日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:03:25 2025年7月17日 : Inner Exception : 根据验证过程,远程证书无效。
    10:03:25 2025年7月17日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:06:59 2025年7月17日 : parameter count = 1
    10:06:59 2025年7月17日 : -wrapper
    10:06:59 2025年7月17日 : Module Name: TIPSpice.exe
    10:06:59 2025年7月17日 : Server OS = False
    10:06:59 2025年7月17日 : Operating system version : 10.0.0.0
    10:06:59 2025年7月17日 : Checking for proxy
    10:07:01 2025年7月17日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    10:07:01 2025年7月17日 : Checking if Licensing URL is accessible
    10:07:01 2025年7月17日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:07:01 2025年7月17日 : Inner Exception : 根据验证过程,远程证书无效。
    10:07:02 2025年7月17日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:10:24 2025年7月17日 : parameter count = 1
    10:10:24 2025年7月17日 : -wrapper
    10:10:24 2025年7月17日 : Module Name: TIPSpice.exe
    10:10:24 2025年7月17日 : Server OS = False
    10:10:24 2025年7月17日 : Operating system version : 10.0.0.0
    10:10:24 2025年7月17日 : Checking for proxy
    10:10:25 2025年7月17日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    10:10:25 2025年7月17日 : Checking if Licensing URL is accessible
    10:10:26 2025年7月17日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:10:26 2025年7月17日 : Inner Exception : 根据验证过程,远程证书无效。
    10:10:26 2025年7月17日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:29:12 2025年7月17日 : parameter count = 1
    10:29:12 2025年7月17日 : -wrapper
    10:29:12 2025年7月17日 : Module Name: TIPSpice.exe
    10:29:12 2025年7月17日 : Server OS = False
    10:29:12 2025年7月17日 : Operating system version : 10.0.0.0
    10:29:12 2025年7月17日 : Checking for proxy
    10:29:34 2025年7月17日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    10:29:34 2025年7月17日 : Checking if Licensing URL is accessible
    10:29:35 2025年7月17日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:29:35 2025年7月17日 : Inner Exception : 根据验证过程,远程证书无效。
    10:29:35 2025年7月17日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    9:25:23 2025年7月18日 : parameter count = 1
    9:25:23 2025年7月18日 : -wrapper
    9:25:23 2025年7月18日 : Module Name: TIPSpice.exe
    9:25:23 2025年7月18日 : Server OS = False
    9:25:23 2025年7月18日 : Operating system version : 10.0.0.0
    9:25:23 2025年7月18日 : Checking for proxy
    9:25:24 2025年7月18日 : {
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
    9:25:24 2025年7月18日 : Checking if Licensing URL is accessible
    9:25:25 2025年7月18日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    9:25:25 2025年7月18日 : Inner Exception : 根据验证过程,远程证书无效。
    9:25:25 2025年7月18日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
  • 9:25:23 2025年7月18日 : parameter count = 1
    "RegularMessage": {
    "ForceMessage": {
    "UTM_Keyword": {
    "17_4_2020_S006",
    "17_4_2020_S009",
    "23_1_2024_S001"
  • Hi Cade,
    What do you have in this folder?
    C:\Users\{YOUR_WINDOWS_USER_NAME}\AppData\Roaming\Cadence\PSpiceTIInstall?
    JC
    	"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
    	"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
    	"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
    	"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
    	"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
    	"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
    	"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
    	"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
    	"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
    	"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    9:41:10 2025年7月18日 : parameter count = 1
    9:41:10 2025年7月18日 : -wrapper
    9:41:10 2025年7月18日 : Module Name: TIPSpice.exe
    9:41:10 2025年7月18日 : Server OS = False
    9:41:10 2025年7月18日 : Operating system version : 10.0.0.0
    9:41:10 2025年7月18日 : Checking for proxy
    9:41:11 2025年7月18日 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    9:41:11 2025年7月18日 : Checking if Licensing URL is accessible
    9:41:12 2025年7月18日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    9:41:12 2025年7月18日 : Inner Exception : 根据验证过程,远程证书无效。
    9:41:12 2025年7月18日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    10:00:43 2025年7月18日 : parameter count = 1
    10:00:43 2025年7月18日 : -wrapper
    10:00:43 2025年7月18日 : Module Name: TIPSpice.exe
    10:00:43 2025年7月18日 : Server OS = False
    10:00:43 2025年7月18日 : Operating system version : 10.0.0.0
    10:00:43 2025年7月18日 : Checking for proxy
    10:00:44 2025年7月18日 : {
    		"RegularMessage": {
    		"ForceMessage": {
    	"UTM_Keyword": {
    		"17_4_2020_S006",
    		"17_4_2020_S009",
    		"23_1_2024_S001"
    10:00:44 2025年7月18日 : Checking if Licensing URL is accessible
    10:00:45 2025年7月18日 : Error Message: 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:00:45 2025年7月18日 : Inner Exception : 根据验证过程,远程证书无效。
    10:00:45 2025年7月18日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    The PSpice for TI installer accesses the internet to download and install various packages. Before starting the installer, ensure the following:
    	1.	Internet connection is available
    	2.	Security protocol TLS 1.2 is enabled
    	3.	Following endpoints or resource locations are accessible from the system:
    		a.	https://pcb.cadence.com/startPages
    		b.	https://software-dl.ti.com/pspice
    		c.	https://cdsplicwc.cadence.com/chws
    If proxy credentials are required to access the Internet, provide the same when requested by the installer.
    10:00:43 2025年7月18日 : *****CONNECTION STATUS CHECK*****
    10:00:43 2025年7月18日 : Internet Connection : Available (Passed)
    10:00:43 2025年7月18日 : Security Protocol TLS 1.2: Available. If PSpice for TI installation fails, unblock TLS 1.2
    10:00:44 2025年7月18日 : Proxy Test : Proxy Credentials not needed
    10:00:45 2025年7月18日 : Unable to access the URL required for installation
    10:00:45 2025年7月18日 : URL : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
    10:00:45 2025年7月18日 : Error Message : 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    10:00:45 2025年7月18日 : Root Error : 根据验证过程,远程证书无效。
  • Hi Cade,
    Here's the problem:
    Please work with your IT department. Looks like the license server is blocked. You must be able to connect to the URL. In powershell, do this:
    wget https://cdsplicwc.cadence.com/chws/test/connection.html
    -JC
  • I've checked with IT, and the license server has been unblocked. Another PC running Windows 10 shows the same PowerShell behavior as yours, while my Windows 11 Pro PC displays the following:
    PS C:\Windows\system32> wget cdsplicwc.cadence.com/.../connection.html
    wget : 基础连接已经关闭: 未能为 SSL/TLS 安全通道建立信任关系。
    所在位置 行:1 字符: 1
    + wget cdsplicwc.cadence.com/.../connection.html
    + CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest],WebExce
    ption
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
  • I downloaded the latest version of wget and copied it to the system32 directory, and then ran it in cmd. The following display shows that there seems to be a problem with the certificate
    C:\Users\cade.chen> wget cdsplicwc.cadence.com/.../connection.html
    --2025-07-23 13:27:36-- cdsplicwc.cadence.com/.../connection.html
    Resolving cdsplicwc.cadence.com (cdsplicwc.cadence.com)... 64.207.220.106
    Connecting to cdsplicwc.cadence.com (cdsplicwc.cadence.com)|64.207.220.106|:443... connected.
    ERROR: cannot verify cdsplicwc.cadence.com's certificate, issued by 'CN=HydrantID Server CA O1,OU=HydrantID Trusted Certificate Service,O=IdenTrust,C=US':
    Unable to locally verify the issuer's authority.
    To connect to cdsplicwc.cadence.com insecurely, use `--no-check-certificate'.
  • Hi JC This is really a complicated job. When I found that there was a problem with the certificate, I used the powershell to debug it. Finally, I found that I needed to re export all the remote certificates in the IE browser and manually add them to the trusted directory of the system. Then I can proceed to the next step
  • Hi Cade,
    I am glad that you figured it out. Let me know if you need anything else.
    -JC
  • Thanks JC
