TIDA-010938: How to reduce the execution time for Interrupt ISR if ISR fre. 21.667KHZ.
Part Number: TIDA-010938
Hi
  I have already change optimization setting but still the problem will be same and if you can check in your end with same example code and build in launchpad so can easily check issue and maybe you suggest fast.
for better clarification: debug mode @ 21.66khz ISR positive width observe 15us but during free run same ISR routine shows time 36usec.
