PSPICE-FOR-TI: Valid license not found.
Part Number: PSPICE-FOR-TI
I am unable to launch PSpice for TI after installing/updating today.
I get the common ERROR(ORCOMMN-12005): Unable to launch PSpice TI. A valid license was not found at <None> license server. Update the license server configuration to include OrCAD PSpice TI licenses.
So far, I have tried rebooting, uninstalls, installing/running as admin. I can also verify that the license file has been created (%appdata%\Cadence\VBL\TI_PSpice_231\license\license.txt) and looks legitimate.
One thing I'll mention is that this install was made on top of an installation of TI_PSpice_174.
Any suggestions?
The license file and log (created using CDS_LIC_QA_TesT environment variable) are provided below.
Callum
07/30/2025 16:45:23 (414770-32536): License Mode: bundleName is set to TI_PSpice_231
07/30/2025 16:45:23 (414770-32536): Initialization started (23.02-a004)...
07/30/2025 16:45:23 (414770-32536): FLEXnet version 11.16.4.0 build 252457
07/30/2025 16:45:23 (414770-32536): Process ID 10812
07/30/2025 16:45:23 (414770-32536): Creating a new job ...
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Get License File called with bundle TI_PSpice_231
07/30/2025 16:45:23 (pid-10812-32536): (vbl) VBL version: (23.02-s004)
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Licensing errors/warnings set in product_key flow
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Setting LastErrCode: 0
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Getting LastErrCode: 0
07/30/2025 16:45:23 (pid-10812-32536): (vbl) License configuration data found corrupted while retrieving value for LicFilePath
07/30/2025 16:45:23 (pid-10812-32536): (vbl) cdsVbliGetLicenseFile returned 0
07/30/2025 16:45:23 (414770-32536):   Configuration of license path is 'C:\Users\cfoster\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
07/30/2025 16:45:23 (414770-32536):   Configuration of recheck interval minimum is 290.
07/30/2025 16:45:23 (414770-32536):   Configuration of 2000000000 maximum retry calls.
07/30/2025 16:45:23 (414770-32536):   Configuration of sleep time value of 0.
07/30/2025 16:45:23 (414770-32536):   Configuration of display specification is '0:0'.
07/30/2025 16:45:23 (414770-32536):   Licenses will be checked out using cfoster@OECA-PC-ZB2(0:0).
07/30/2025 16:45:23 (414770-32536):   (System spec would have been cfoster@OECA-PC-ZB2(OECA-PC-ZB2) )
07/30/2025 16:45:23 (414770-32536): Job creation completed with status 0 (time 0).
07/30/2025 16:45:23 (414770-32536): Initialization completed with status 0 (time 0).
07/30/2025 16:45:23 (414770-32536): License mode: Validate Trigger Interval is set to: 86401 sec
07/30/2025 16:45:23 (414770-32536): License Mode: Starting ValidateLicenseThread
07/30/2025 16:45:23 (414770-17548): License Mode: ValidateLicenseThread started
07/30/2025 16:45:23 (414770-17548): License mode: calling cdsVblValidateLicense from thread...
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Licensing errors/warnings set in product_key flow
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Action code is 1
07/30/2025 16:45:23 (pid-10812-17548): (vbl) cdsVbliValidateLicense attempt 0/3
07/30/2025 16:45:23 (pid-10812-32536): (mfp) MFP version: (22.01-d007)
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Get hw addresses called with upOnly=True
07/30/2025 16:45:23 (pid-10812-17548): (vbl) License configuration data found corrupted while retrieving value for user_configuration
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Error: Failed to read storage entry. Entry key is: user_configuration
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Setting LastErrCode: -2054
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Setting LastErrCode: -2071
07/30/2025 16:45:23 (pid-10812-17548): (vbl) cdsVbliValidateLicense returned -2071
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
07/30/2025 16:45:23 (pid-10812-17548): (vbl) Getting WarningErrorCode: 0
07/30/2025 16:45:23 (pid-10812-32536): (mfp) HW addresses:
07/30/2025 16:45:23 (pid-10812-17548): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=fff83798ae addlen=6 type=53 status=2 len=448 index=23 flags=1c1 connType=1 tunType=0 name={F83798AE-F468-4E43-975F-A177DD3B668C}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Skipping as not up
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=155d603868 addlen=6 type=6 status=1 len=448 index=25 flags=1c0 connType=1 tunType=0 name={DDBF3683-A217-4429-BE5D-67F5D3EA0002}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Friendly name: vEthernet (Default Switch)
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=e073e75d49bf addlen=6 type=6 status=1 len=448 index=20 flags=1c5 connType=1 tunType=0 name={CDF387FB-1DEE-431D-8D2F-15814209AA8F}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Friendly name: Ethernet 2
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=0 addlen=0 type=53 status=2 len=448 index=10 flags=1c5 connType=1 tunType=0 name={6A0C620B-0193-4DDD-A2CE-FDE0027CD843}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=98597a64e70f addlen=6 type=71 status=2 len=448 index=14 flags=1c5 connType=1 tunType=0 name={9C959494-FE7B-440B-93F8-607B78B3943F}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=9a597a64e70e addlen=6 type=71 status=2 len=448 index=15 flags=1c1 connType=1 tunType=0 name={9D9D7439-ABC5-4B73-8963-392BAF9DEDA1}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=98597a64e70e addlen=6 type=71 status=2 len=448 index=9 flags=1c5 connType=1 tunType=0 name={65726755-F395-4B95-A958-18BB40BC3BB0}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=98597a64e712 addlen=6 type=6 status=2 len=448 index=19 flags=1c5 connType=1 tunType=0 name={CB08D35C-51F0-44D2-BBCB-7B35AD64D105}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={9C40245A-B150-11ED-88EF-806E6F6E6963}
07/30/2025 16:45:23 (pid-10812-32536): (mfp) Skipping as lookup
07/30/2025 16:45:23 (pid-10812-32536): (mfp) HW addresses end
07/30/2025 16:45:23 (pid-10812-32536): (mfp) No primary adapter was found, setting as first non-skipped one
07/30/2025 16:45:23 (414770-32536): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
07/30/2025 16:45:23 (414770-32536): FeatureExists started ....
07/30/2025 16:45:23 (414770-32536): Check-out started ....
07/30/2025 16:45:23 (414770-32536): Testing only for the validity of feature PSpice_TI 23.100...
07/30/2025 16:45:23 (414770-32536):  License Mode: First checkout status:
07/30/2025 16:45:23 (414770-32536):  License Mode checkout status with status:(-10)
07/30/2025 16:45:23 (414770-32536):  License Mode: FlexNetErr Code:
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: -10
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Action code is 6
07/30/2025 16:45:23 (pid-10812-32536): (vbl) cdsVbliValidateLicense attempt 0/3
07/30/2025 16:45:23 (pid-10812-32536): (vbl) License configuration data found corrupted while retrieving value for user_configuration
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Error: Failed to read storage entry. Entry key is: user_configuration
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Setting LastErrCode: -2054
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Setting LastErrCode: -2071
07/30/2025 16:45:23 (pid-10812-32536): (vbl) cdsVbliValidateLicense returned -2071
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
07/30/2025 16:45:23 (414770-32536):  License Mode: cdsVblValidateLicense status:
07/30/2025 16:45:23 (414770-32536):  License Mode checkout status with status:(-1)
07/30/2025 16:45:23 (414770-32536):  License Mode: Vbl Returned Last vblerror code
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Getting LastErrCode: -2071
07/30/2025 16:45:23 (pid-10812-32536): (vbl) cdsVblGetLastError returned internal error code: -2071
07/30/2025 16:45:23 (414770-32536):  License Mode checkout status with status:(-2071)
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Last set CHWS error code -20 does not match with last set error code -2071
07/30/2025 16:45:23 (pid-10812-32536): (vbl) Getting LastChwsErrCode: -20
07/30/2025 16:45:23 (pid-10812-32536): (vbl) cdsVblIsValidChwsError returned 0 and the last set Chws error code is: -20
07/30/2025 16:45:23 (414770-32536): Validity test completed with status -10.
07/30/2025 16:45:23 (414770-32536): Check-out completed with status -10 (time 0).
07/30/2025 16:45:23 (414770-32536): FeatureExists of PSpice_TI completed with status -10 (time 0).
07/30/2025 16:45:23 (414770-32536): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
07/30/2025 16:45:23 (414770-32536): Testing only for the validity of feature PSpice_TI_Plus 23.100...
07/30/2025 16:45:23 (414770-32536): Validity test completed with status -5.
07/30/2025 16:45:23 (414770-32536): Check-out completed with status -5 (time 0).
07/30/2025 16:45:23 (414770-32536): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
07/30/2025 16:45:23 (414770-32536): License mode: signaling thread to stop
07/30/2025 16:45:23 (414770-32536): License mode: waiting for thread to stop
07/30/2025 16:45:23 (414770-17548): License mode: Thread woke up, passed: 0 sec, sleep left: 86442 sec
07/30/2025 16:45:23 (414770-17548): License mode: Exiting thread gracefully due to Signal by lmExit...
07/30/2025 16:45:23 (414770-17548): License mode: ValidateLicenseThread is stopping...
07/30/2025 16:45:23 (414770-32536): License mode: thread stopping took 0 sec
07/30/2025 16:45:23 (414770-32536): Exit started ....
07/30/2025 16:45:23 (414770-32536): Exit completed with status 0 (time 0).
# This email has been sent by an  automated
# process. Please do  not reply to this email.
#     COSLITE INFORMATION
# PLEASE NOTE:  Your license file may contain COSLITE product depending on
# your entitlement. This license will allow some digital tools to access
# support.cadence.com content (via CadenceHelp) without requiring login.
# This is a zero cost license and will be active as long as the primary tool
# license is active. More information is available at
# https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009Mns6UAC
# For any further questions, please use the feedback option in the
# https://support.cadence.com site and someone from the product team will get
# back to you.
#     TERMS AND CONDITIONS
# THESE TERMS ALONG WITH YOUR CADENCE LICENSE AGREEMENT SHALL GOVERN YOUR
# USE OF THE PRODUCTS.  "CADENCE LICENSE AGREEMENT" REFERS TO THE CADENCE
# CONTRACT FOR THE APPLICABLE PRODUCTS, INCLUDING CADENCE TERMS AND CONDITIONS,
# THAT IS (I) SIGNED BY YOU OR (II) ACCEPTED BY YOU IN ACCORDANCE WITH
# THOSE CADENCE TERMS AND CONDITIONS.
# IF THESE PRODUCTS ARE PROVIDED PURSUANT TO A PAID LICENSE, THEN THE
# TERMS IN THIS EMAIL ALONG WITH THE CADENCE LICENSE AGREEMENT SHALL
# GOVERN YOUR USE OF THE PRODUCTS.
# IF THESE PRODUCTS ARE PROVIDED FOR USE FREE OF CHARGE AND THERE IS NO APPLICABLE
# CADENCE LICENSE AGREEMENT, THEN THE TERMS AND CONDITIONS IN THIS EMAIL,
# ALONG WITH THE TERMS AND CONDITIONS FOUND AT
# http://www.cadence.com/termsandconditions/templicense ARE THE SOLE AND
# EXCLUSIVE AGREEMENT FOR USE OF THESE PRODUCTS.
# BY USING THE LICENSE FILE AND ANY PRODUCTS INCLUDED THEREIN
# YOU (I) REAFFIRM YOUR ACCEPTANCE OF THE CADENCE LICENSE AGREEMENT AND
# (II) CONFIRM THAT ANY TERMS AND CONDITIONS IN YOUR PURCHASE ORDER,
# YOUR WEBSITE/PORTAL, AND YOUR OTHER DOCUMENTATION DO NOT APPLY.
# Please read this email carefully prior to downloading or using the
# products. You must protect the product(s) from unauthorized
# reproduction, publication, use or distribution.  If any product or
# portion thereof is copied to or used on a computer connected to a
# network, you must ensure that the product may not be used or copied
# by unlicensed persons.
# To help ensure that you are only using authorized copies of the
# product(s), Cadence may utilize monitoring technologies to obtain and
# transmit non-proprietary data on unauthorized modifications to the
# product(s).  No such data will be collected or transmitted unless
# unauthorized modifications to a product or unauthorized hosting of the
# license server or product(s) are suspected.
# By downloading the product(s), you confirm that you have the authority
# to act on behalf of your employer.  By downloading or using the
# product(s) you hereby agree to the use of such technology and
# transmission of such non-proprietary data by Cadence.
# If these Products have been approved by Cadence for Use on a
# secure cloud service platform, the definition of Designated Equipment
# shall mean such approved secure cloud service platform, which shall
# include any and all security measures which are at least as stringent
# as the security measures that Licensee itself uses to store its own
# confidential or proprietary information, but in any event shall include
# all reasonable security measures sufficient to ensure compliance
# with the Terms.
# IF YOU DO NOT AGREE TO THESE TERMS AND CONDITIONS, YOU MUST
# IMMEDIATELY DELETE THIS  CORRESPONDENCE AND YOU MAY NOT USE THE
# LICENSE FILE OR ANY PRODUCTS INCLUDED THEREIN
#     CADENCE CUSTOMER SUPPORT
# If you have questions regarding this license file, please contact
# Cadence customer support. The support information is available under
# https://support.cadence.com/apex/CadenceSupportScreen
# You may use your Cadence Online Support account to access the
# Cadence Electronic Software Download(ESD) Servers by going to
# http://downloads.cadence.com Software Releases are available for
# download for customers world-wide.
# THIS LICENSE FILE HAS BEEN GENERATED FOR HOSTID 98597a64e70e e073e75d49bf 98597a64e70f 98597a64e712 00155d73b3ec 9a597a64e70e
#          CUSTOMER DETAILS
#          Customer Name:TI_PSPICE
#           Server  Name:OECA-PC-ZB2
#       Server  Location:AU
#                Host Id:98597a64e70e e073e75d49bf 98597a64e70f 98597a64e712 00155d73b3ec 9a597a64e70e
#           Contact Name:Callum Foster
#             Contact Id:cfoster@orbitalcorp.com.au
#                   Date:Tue Jul 29 18:55:17 PDT 2025
#  Lic.File Generated By:Callum Foster
#               Comments:
#     INSTRUCTIONS
#  1. Please   replace  "Cadence_SERVER"  with  hostname  of your machine
#     in line   "SERVER Cadence_SERVER  <hostid> 5280".
#  2. Please replace the relative path(  eg. ./cdslmd   ) to absolute path
#     in the DAEMON line(s).
#  3. Cadence now ships a complete license file for each server, so combining
#     license files with a VENDOR_STRING value other than DEMO is no longer
#     permitted.  Please contact your field administrator if you believe that
#     product licenses are missing from this file.
#  4. Some  e-mail utilities ( commonly on PC or  Macintosh  systems ) may
#     modify the text of an e-mailed license file,   changes such as  word
#     or line wrapping or  subdivision into  multiple sections,  when they
#     receive or forward this file.  The resulting keys will be unreadable
#     by the software security.To avoid this, these changes must be undone
#     or the e-mail utility options disabled.
########################### LICENSE KEYS START HERE ######################
SERVER OECA-PC-ZB2 98597a64e70e e073e75d49bf 98597a64e70f 98597a64e712 00155d73b3ec 9a597a64e70e 5280
DAEMON cdslmd ./cdslmd
FEATURE s_PSpice_TI cdslmd 23.1 29-jul-2025 uncounted \
	3F2ACD5D158B3C8DBEE6 VENDOR_STRING=UHD:PERM \
	HOSTID="98597a64e70e e073e75d49bf 98597a64e70f 98597a64e712 \
	00155d73b3ec 9a597a64e70e" vendor_info=29-jul-2025 \
	ISSUER=CDNSf97c04c136af0c07014a5d3d1ff347af ISSUED=29-jul-2025 \
	SN=2025-07-29T18:54:44.092 TS_OK SIGN2="0FFE 9354 E6FA FB30 \
	AA11 ADD2 4C37 45B0 237E 77EC 098F C96C EFF9 8750 E60B 1BD6 \
	85FE C3FE 5F58 F1C6 834F 8B50 C526 61C5 C17E 2A0F 11D8 213E \
	81B0 4497"
########################## LICENSE KEYS END HERE ######################
##     PRODUCT TO FEATURE MAPPING
########################### for  [REGULAR] products #################
# Product Id  : PA4000,  [Version: 23.1]
# Product Name: PSpice-TI Simulator
# Licensed Rights:
#   Start Date: 29-jul-2025 Exp Date: 29-jul-2025   Product Qty: 1 Type: Floating
#   Product Comments:
#   Feature: PSpice_TI                      [Version: 23.1] [Feature Qty Per Product: 1]
