PMP30693: PMP30693: Pick&Place file ?
Part Number: PMP30693
Could you provide a pick and place file for this design please ? I have found Gerber, NC Drill files but my assembler is asking for a dedicated Pick&Place file (X, Y and rotation for each Designator). I know you designed it with Altium, so could you simply generate this file ?
Thank you in advance.
  • Hi Mathieu,
    I generated a Pick and Place file. See attachement.
    Florian
    Altium Designer Pick and Place Locations
    C:\fmueller\Projects\PMP30693 Landis Supercap Charger BuckBoost Milen\PMP30693_RevB\PMP30693_RevB Project\Project Outputs\Pick Place Output\Pick Place for PMP30693_RevB.txt
    File Design Information:
    Date:       16/09/25
    Time:       11:18
    Revision:   Not in VersionControl
    Variant:    No variations
    Units used: mil
    Designator Comment              Layer    Footprint           Center-X(mil) Center-Y(mil) Rotation Description
    TP8        TP-025-SMT           TopLayer TP_25MIL-SMT        1481.167      1196.974      90       "Test Point, O.025""
    TP7        TP-025-SMT           TopLayer TP_25MIL-SMT        1416.815      1196.875      90       "Test Point, O.025""
    C26        DNP                  TopLayer 0603                1350.000      303.125       270      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    TP6        5001                 TopLayer Keystone5001        2506.250      1630.136      90       "Test Point, Miniature, Black, TH"
    TP9        5000                 TopLayer Keystone5000        2718.750      990.625       90       "Test Point, Miniature, Red, TH"
    TP3        5000                 TopLayer Keystone5000        2350.000      1934.375      90       "Test Point, Miniature, Red, TH"
    R37        CRCW06033M01FKEA     TopLayer 0603                1563.780      548.058       180      "RES, 3.01 M, 1%, 0.1 W, 0603"
    R38        CRCW060390K9FKEA     TopLayer 0603                1403.125      306.250       90       "RES, 90.9 k, 1%, 0.1 W, 0603"
    R18        CRCW06030000Z0EA     TopLayer 0603                257.874       664.724       0        "RES, 0, 5%, 0.1 W, 0603"
    U6         TLV521DCKR           TopLayer DCK0005A_N          255.905       753.307       180      "350-nA Nanopower, Single, RRIO, CMOS Input, Operational Amplifier for Cost-Sensitive Systems, DCK0005A (SOT-SC70-5)"
    R26        CRCW08051K00FKEA     TopLayer 0805_HV             413.386       722.441       0        "RES, 1.00 k, 1%, 0.125 W, 0805"
    R30        CRCW06031M00FKEA     TopLayer 0603                262.500       846.875       360      "RES, 1.00 M, 1%, 0.1 W, 0603"
    R21        CRCW06031M00FKEA     TopLayer 0603                346.875       880.295       90       "RES, 1.00 M, 1%, 0.1 W, 0603"
    C29        C0805C105K8RACTU     TopLayer 0805_HV             1811.024      236.220       180      "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
    R5         CRCW06030000Z0EA     TopLayer 0603                2118.110      1717.520      180      "RES, 0, 5%, 0.1 W, 0603"
    U3         TLV431AIDBZR         TopLayer DBZ0003A_N          2049.213      1342.162      270      "Low Voltage Adjustable Precision Shunt Regulator, 39 ppm / degC, 15 mA, -40 to 85 degC, 3-pin SOT-23 (DBZ), Green (RoHS & no Sb/Br)"
    U2         INA181A4IDBV         TopLayer DBV0006A_N          1980.315      1663.386      270      "Bidirectional, Low- and High-Side Measurement, Multichannel, Voltage Output, Current-Sense Amplifier, DBV0006A (SOT-6)"
    U7         TLV522DGKR           TopLayer DGK0008A_N          1663.386      433.071       360      "500-nA Nanopower, Dual, RRIO, CMOS-Input Operational Amplifier for Cost-Sensitive Systems, DGK0008A (VSSOP-8)"
    U5         LM66100DCKT          TopLayer DCK0006A_N          2475.000      1131.890      0        "+/-6V, Low IQ Ideal Diode with Input Polarity Protection, DCK0006A (SOT-SC70-6)"
    U4         TPS63802DLAR         TopLayer DLA0010A            1448.819      1119.094      90       "High Current, High Efficiency Single Inductor Buck-Boost Converter, DLA0010A (VSON-HR-10)"
    U1         LM66100DCKT          TopLayer DCK0006A_N          2248.829      2031.225      0        "+/-6V, Low IQ Ideal Diode with Input Polarity Protection, DCK0006A (SOT-SC70-6)"
    TP11       5001                 TopLayer Keystone5001        1862.795      782.087       90       "Test Point, Miniature, Black, TH"
    TP10       5000                 TopLayer Keystone5000        2157.480      609.375       90       "Test Point, Miniature, Red, TH"
    TP5        5001                 TopLayer Keystone5001        2736.220      1781.496      90       "Test Point, Miniature, Black, TH"
    TP4        5001                 TopLayer Keystone5001        108.268       1564.961      90       "Test Point, Miniature, Black, TH"
    TP1        5000                 TopLayer Keystone5000        2736.220      2165.354      90       "Test Point, Miniature, Red, TH"
    TP2        5000                 TopLayer Keystone5000        100.884       2122.333      90       "Test Point, Miniature, Red, TH"
    R9         CRCW0603499RFKEA     TopLayer 0603                1724.836      1600.825      360      "RES, 499, 1%, 0.1 W, 0603"
    R4         CRCW0603499RFKEA     TopLayer 0603                1718.561      1684.724      360      "RES, 499, 1%, 0.1 W, 0603"
    R11        CRCW0603100RFKEA     TopLayer 0603                2049.213      1447.298      180      "RES, 100, 1%, 0.1 W, 0603"
    R12        CRCW060312K4FKEA     TopLayer 0603                2156.496      1341.536      90       "RES, 12.4 k, 1%, 0.1 W, 0603"
    R10        CRCW08052K00FKEA     TopLayer 0805_HV             2273.622      1487.500      180      "RES, 2.00 k, 1%, 0.125 W, 0805"
    R1         CRCW08050000Z0EA     TopLayer 0805_HV             2285.433      1564.961      360      "RES, 0, 5%, 0.125 W, 0805"
    R45        CRCW06030000Z0EA     TopLayer 0603                2047.244      521.654       360      "RES, 0, 5%, 0.1 W, 0603"
    R44        CRCW0805100RJNEA     TopLayer 0805_HV             1899.606      334.646       180      "RES, 100, 5%, 0.125 W, 0805"
    R43        CRCW0603100KFKEA     TopLayer 0603                2047.244      462.598       0        "RES, 100 k, 1%, 0.1 W, 0603"
    R42        CRCW060310K0FKEA     TopLayer 0603                1899.606      413.386       180      "RES, 10.0 k, 1%, 0.1 W, 0603"
    R39        CRCW06030000Z0EA     TopLayer 0603                1466.535      344.488       270      "RES, 0, 5%, 0.1 W, 0603"
    R36        CRCW0603100KFKEA     TopLayer 0603                1437.008      442.913       360      "RES, 100 k, 1%, 0.1 W, 0603"
    R35        CRCW060343K2FKEA     TopLayer 0603                1299.213      393.701       90       "RES, 43.2 k, 1%, 0.1 W, 0603"
    R34        CRCW0603100KFKEA     TopLayer 0603                1458.661      698.819       180      "RES, 100 k, 1%, 0.1 W, 0603"
    R33        CRCW060310K0FKEA     TopLayer 0603                1330.708      826.772       0        "RES, 10.0 k, 1%, 0.1 W, 0603"
    R32        DNP                  TopLayer 0603                1387.500      895.669       360      "RES, xxx ohm, x%, xW, [PackageReference]"
    R31        CRCW06030000Z0EA     TopLayer 0603                1437.008      501.969       360      "RES, 0, 5%, 0.1 W, 0603"
    R29        CRCW0603187KFKEA     TopLayer 0603                1529.527      858.268       90       "RES, 187 k, 1%, 0.1 W, 0603"
    R28        CRCW060382K5FKEA     TopLayer 0603                1498.031      954.725       360      "RES, 82.5 k, 1%, 0.1 W, 0603"
    R27        CRCW06030000Z0EA     TopLayer 0603                2475.000      1220.473      180      "RES, 0, 5%, 0.1 W, 0603"
    R25        DNP                  TopLayer 0603                1330.708      954.725       360      "RES, xxx ohm, x%, xW, [PackageReference]"
    R24        CRCW0603100KFKEA     TopLayer 0603                1675.000      840.625       360      "RES, 100 k, 1%, 0.1 W, 0603"
    R23        CRCW0603301KFKEA     TopLayer 0603                1299.213      521.653       90       "RES, 301 k, 1%, 0.1 W, 0603"
    R22        CRCW06030000Z0EA     TopLayer 0603                2571.875      1192.913      90       "RES, 0, 5%, 0.1 W, 0603"
    R20        CRCW0603100KFKEA     TopLayer 0603                1625.984      1013.780      360      "RES, 100 k, 1%, 0.1 W, 0603"
    R19        CRCW06030000Z0EA     TopLayer 0603                1330.708      1023.622      0        "RES, 0, 5%, 0.1 W, 0603"
    R41        DNP                  TopLayer 0805_HV             1889.764      580.709       180      "RES, xxx ohm, x%, xW, [PackageReference]"
    R17        CRCW0603392KFKEA     TopLayer 0603                1626.701      954.725       360      "RES, 392 k, 1%, 0.1 W, 0603"
    R40        CRCW08050000Z0EA     TopLayer 0805_HV             1889.764      659.449       180      "RES, 0, 5%, 0.125 W, 0805"
    R16        CRCW120630R1FKEA     TopLayer 1206                1151.575      1574.803      90       "RES, 30.1, 1%, 0.25 W, 1206"
    R15        CRCW120630R1FKEA     TopLayer 1206                1053.150      1574.803      90       "RES, 30.1, 1%, 0.25 W, 1206"
    R14        CRCW120630R1FKEA     TopLayer 1206                954.724       1574.803      90       "RES, 30.1, 1%, 0.25 W, 1206"
    R13        "Used in BOM report" TopLayer 2512                826.771       1555.118      90       "RES, xxx ohm, x%, xW, [PackageReference]"
    R6         "Used in BOM report" TopLayer 0805_HV             1606.299      1643.701      90       "RES, xxx ohm, x%, xW, [PackageReference]"
    R8         "Used in BOM report" TopLayer 0805_HV             1525.591      1641.004      90       "RES, xxx ohm, x%, xW, [PackageReference]"
    R7         ERJ-8BWFR068V        TopLayer 1206                1437.008      1616.142      90       "RES, 0.068, 1%, 0.5 W, 1206"
    R3         CRCW06030000Z0EA     TopLayer 0603                2256.250      2112.500      180      "RES, 0, 5%, 0.1 W, 0603"
    R2         CRCW06030000Z0EA     TopLayer 0603                2347.246      2078.814      90       "RES, 0, 5%, 0.1 W, 0603"
    Q2         MMBT2222A            TopLayer SOT-23              1545.276      255.905       180      "Transistor, NPN, 40 V, 0.15 A, SOT-23"
    Q1         MMBT2222A            TopLayer SOT-23              1584.646      757.874       90       "Transistor, NPN, 40 V, 0.15 A, SOT-23"
    L1         XFL4015-471MEC       TopLayer XFL4015             1448.819      1306.250      0        "Inductor, Shielded, Composite, 470 nH, 3.5 A, 0.0076 ohm, SMD"
    D2         MBRA210LT3G          TopLayer SMA                 1118.750      1925.000      90       "Diode, Schottky, 10 V, 2 A, SMA"
    D1         MBRA210LT3G          TopLayer SMA                 1537.500      1924.754      90       "Diode, Schottky, 10 V, 2 A, SMA"
    C10        GRM188R71H104KA93D   TopLayer 0603                2086.614      1614.173      90       "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C9         DNP                  TopLayer 0805                2157.480      1614.173      90       "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C11        C0603C334K4RACTU     TopLayer 0603                1871.875      1654.132      270      "CAP, CERM, 0.33 �F, 16 V,+/- 10%, X7R, 0603"
    C12        C0805C155K8RACTU     TopLayer 0805_HV             1923.858      1348.425      270      "CAP, CERM, 1.5 �F, 10 V,+/- 10%, X7R, 0805"
    C19        GRM188R71H104KA93D   TopLayer 0603                157.480       727.716       90       "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C18        GRM21BR71A105KA01L   TopLayer 0805_HV             88.583        727.716       90       "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
    C25        SCCU25B256SRB        TopLayer SCC_1600x2650       738.189       367.423       270      "CAP, Electric Double Layer, 25000000 �F, 2.7 V,+30/--10%, 0.027 ohm, TH"
    C22        "Used in BOM report" TopLayer 1206                1694.882      1151.575      270      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C21        CL21B226MQQNNNE      TopLayer 0805_HV             1586.614      1143.701      270      "CAP, CERM, 22 �F, 6.3 V,+/- 20%, X7R, 0805"
    C28        GRM188R71H104KA93D   TopLayer 0603                1722.441      580.709       180      "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C27        "Used in BOM report" TopLayer 0805                1722.441      651.575       180      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C24        GRM188R71H104KA93D   TopLayer 0603                2381.250      1140.625      270      "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C23        GRM21BR71A105KA01L   TopLayer 0805_HV             2309.375      1134.375      270      "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
    C17        SCCU25B256SRB        TopLayer SCC_1600x2650       738.189       1043.307      270      "CAP, Electric Double Layer, 25000000 �F, 2.7 V,+30/--10%, 0.027 ohm, TH"
    C20        GRM21BR71A105KA01L   TopLayer 0805_HV             2671.875      1131.250      270      "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
    C16        "Used in BOM report" TopLayer 0603                1626.701      893.701       180      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C15        GRM188R71H104KA93D   TopLayer 0603                1330.709      1131.890      270      "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C14        GRM21BR70J106KE76L   TopLayer 0805_HV             1251.968      1141.732      270      "CAP, CERM, 10 �F, 6.3 V,+/- 10%, X7R, 0805"
    C13        DNP                  TopLayer 1206                1161.417      1151.575      270      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C8         GRM21BR70J106KE76L   TopLayer 0805_HV             816.929       1958.661      270      "CAP, CERM, 10 �F, 6.3 V,+/- 10%, X7R, 0805"
    C7         DNP                  TopLayer 1206                915.354       1968.504      270      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C6         EKZM160ELL102MJ20S   TopLayer Chemi-Con_1000x2000 496.875       1912.500      270      "CAP, AL, 1000 �F, 16 V, +/- 20%, TH"
    C5         DNP                  TopLayer 1206                2637.500      1959.375      270      "CAP, CERM, xxxF, xxV, [TempCo], xx%, [PackageReference]"
    C4         GRM21BR70J106KE76L   TopLayer 0805_HV             2541.856      1968.504      270      "CAP, CERM, 10 �F, 6.3 V,+/- 10%, X7R, 0805"
    C3         GRM21BR71A105KA01L   TopLayer 0805_HV             2465.625      1968.504      270      "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
    C2         GRM188R71H104KA93D   TopLayer 0603                2115.625      1956.250      270      "CAP, CERM, 0.1 �F, 50 V,+/- 10%, X7R, 0603"
    C1         GRM21BR71A105KA01L   TopLayer 0805_HV             2041.140      1956.250      270      "CAP, CERM, 1 �F, 10 V,+/- 10%, X7R, 0805"
