Other Parts Discussed in Thread: TINA-TI
Hi
I have donwloaded the tina spice model and the schematic for the LME49810, but my program can't open this file : " Unable to open C:/ ...../snam111.tsc
Pearhaps I made something wrong?
Hi
Georges,
What version of TINA are you running? If you are running TINA-TI v7 or TINA Industrial version 7, you will not be able to open TINA projects that were created using TINA-TI v9. If you are using TINA-TI v7, please download the latest version of TINA-TI v9 from TI's website. TINA-TI v9 can open all TINA v7 files.
If you are using TINA-TI v9, the file type .tsc should already be associated to it and it should open either when you click on the .tsc file or when you open TINA-TI and use the File--> Open option.
Britt
Thanks for this answer, I had Tina 7, and now with the last version, it's ok
regards
Hi
I have an another question about the LME49810 simulation: The bias circuit is not operate, any value of resistor in this circuit give the same bias courant in the power BJT. And even iI don't put any resistor (open circuit), there is no cross over distorsion in the output signal.
Any suggest?
