I got the below question:
I am about to get a new computer
I want to move all the Switcher Pro files to the new computer
I can’t find the files
Can you please verify for me where they are located and how do I copy them to my new computer
Hello Eli,
A colleague of mine gave this solution to you:
Please let us know how it goes.
Enjoy SwitcherPro on your new computer.
Is there a way for SwitcherPro to save each project in its own design file? I am designing for a customer and want to send him just his specific project simulation instead of the "SwitcherProDB.vdb3" which contains all of the projects I have done for other customers.
Leo
Please confirm that the designs really are stored in
C:\Program Files (x86)\Texas Instruments\SwitcherPro Desktop\SwitcherProDB.vdb3
I have tried renaming and relocating the file and SwitcherPro starts with my designs listed every time. The file creation date still shows 10/28/2011 even after the changes. I would like some way to backup and/or move the designs.
Follow on: I created a new design and the size of the SwitcherProDB.vdb3 file did not change. Where is my design being stored?
Thank you in advance,
Andrew
Hi Andrew,
SwitcherProDB.vdb3 file under "C:\Program Files (x86)\Texas Instruments\SwitcherPro Desktop" is were SwitcherPro stores user designs. If you are using windows 7, you will need to run switcherPro as administrator so that the tool can save the designs in this file. Please follow the instrunctions below to run SwitcherPro as administrator.
1) Go to the switcherPro executable file from start-> All Programs-> Texas Instruments - > SwitcherPro Desktop -> SwitcherPro Desktop
2) Right click -> Properties -> Compatibility
3) Check mark the option “Run this program as administrator”
4) Run SwitcherPro .
Thanks & Regards,
-Abhishek
Hi Andrew,
Below is the explanation of where SwitcherPro desktop save designs on windows 7.
1) If you run SwitcherPro as administrator, your designs will be stored under “C:\Program Files (x86)\Texas Instruments\SwitcherPro Desktop” -> SwitcherProDB.vdb3.
2) If you are NOT running SwitcherPro as administrator then the designs will be stored under the user local app data folder. Path: “C:\Users\[User info]\AppData\Local\VirtualStore\Program Files (x86)\Texas Instruments\SwitcherPro Desktop”->SwitcherProDB.vdb3
Where, [User Info] is the name representing current user login.
Thanks & Regards,
--Abhishek
