Other Parts Discussed in Thread: TPS43000
are there Spice files for the TSP43000? Its not listet in Tina ti..
greettings from munich
Hi Jens,
Thank you for your interest in the TPS43000 SPICE model. Unfortunately, this part is not supported by one at this time. You could try entering your specifications into the parametric search table to see if there are other parts that meet your criteria and are supported with SPICE models.
Alternately, if you need help with your design, you can also enter your specifications into WEBENCH(R) Designer. This will give you multiple circuits that meet your requirement and then you can optimize based on Efficiency requirement, size and cost of the circuit. Many parts (but not all) in WEBENCH also support SPICE simulation as well, so that you can run startup, steady state, load transients, line transients and Bode plot simulations.
You can get to WEBENCH(R) Designer from TI's home page: https://www.ti.com/
