WEBENCH Error on Import with Orcad Schematic
Other Parts Discussed in Thread: TPS56121
I have created two supplies using a TPS56121 regulator.  One is 3p3V and the other is 5p0V.  The 3p3V one imports correctly from the EDF to a DSN file in orcad.  The 5p0V supply will not import.  I have attached the zips I received from the Web Bench tools and the log file of the imports.  Does any one have an idea what I am doing wrong?  Why did the same supply with the 3p3V output function correctly and the 5p0V one fails.  I also tried to kill the Web Bench and restart it but no matter what i try I always get the same edf file back.
TPS56121D_Supply_Web_Bench_Outputs.ZIP
