Iam looking for CAD/bxl files for
Hello Murali,
I will request CAD/bxls and will let you know when they are complete. Turn around is usually within a week.
Janet
Murali,
Attached are the parts you requested:
I will submit a request to generate the TPS22920L_YZP_8.bxl but for now I am attaching the TPS22920_YZP_8.bxl which you may be able to use. I will let you know when TPS22920L_YZP_8.bxl is available.
All bxls should be available on ti.com within the next week.
Janet
Murali,
Here is the TPS22920_YZP_8.bxl until the vendor can deliver the TPS22920L_YZP_8.bxl.
Janet
Murali,
Attached is the TPS22920L_YZP_8.bxl that you requested.
Janet
Hi Janet,
Thank you for the files. Thermal pad in TPS22967 seems to be larger than the recommended with just 1mil spacing with pins. Also in future, will I or someone be able to access the files from the webench cad file search or this forum links is the place to go?
Murali
Murali,
I will ask vendor to check thermal pad size and pin spacing. Can you send the size you are seeing and the size intended on datasheet? I am in the process of building new library to publish on ti.com so yes, you will be able to access from webench cad file search soon.
Janet
Murali,
The vendor corrected the TPS22967_DSG_8.bxl and I have attached below.
It should appear in the next library build on ti.com within the next couple of weeks.
Janet
