Other Parts Discussed in Thread: LM5035C, LM5035
I have imported your Pspice model for LM5035C, using import wizard of Altium 13. I have asigned all the simulation models to the components and I have changed the components that create problems in Altium. After that the simulation doesn't work.
It gives the same error all time no matter I change the parameters of the simulator.
[Error] LM5035 XSpice doAnalyses: Timestep too small 17:45:01 11/03/2014 17
The model is:
.SUBCKT LM5035C RAMP UVLO OVP COMP RT CS SS DLY RES HB HS HO LO VCC SR2 SR1 REF VIN
VVCC VCC4 VCC5 0
Rram3_discharge 0 RAM2 1k
Rres6 RES9 RES11 500
Cresdum1 RES 0 3p IC=0
Rcomp1 REF COMPX 5k
Ccs6 ILIM 0 100p IC=0
Rdr5 DRVHISIG DR5 500
Cvcc4 VCC6 0 3p IC=0
Ecs4 CS7 0 VALUE { if(V(RAMPINT)>3.5 | V(CLK)>2.5 | V(PWMout)>2.5,5,0) }
Cotr7 OTR10 0 3p IC=0
Rovdummy 0 OVP 10Meg
Guvihys1 UVLO 0 VALUE { if(V(NSB)>2.5, 0, 23E-6) }
Rram2 RAM2 RAM3 500
Eosc1 OSC1 0 VALUE { if(V(OSC2)>cos(2*3.14*35E-9/(2/(6.25E9*I(VRT))+110E-9)),5,0) }
Cres6 RES9 0 3p IC=0
Xuvr1 UVR2 VREFLOW VREFuv uvr1 rsff5k PARAMS:
Rcs3 CS5 CS7 500
Cotr8 OTR11 0 3p IC=5
Tleb LEB1 0 LEB2 0 Z0=1 TD=50n
Cuvi1 SD 0 3p IC=0
Ess1 SSRESET 0 VALUE { if(V(DRIVERSoff)>2.5 | V(CLtimerout)>2.5 | V(SD)>2.5,5,0) }
Edff4 DFF7 0 VALUE { if(V(CLK)>2.5,V(DFF5),0) }
V1 V5V 0 5
Rdlydummy DLY 0 10E6
Ruvb3 UVB2 UVB3 500
Rdr7 SR1SIG DR7 500
Rotr1 OTR1 OUTPUTTIMERRESET 500
Cosc1 CLK 0 5p IC=5
Rcs4 CS6 CS8 500
Cres5 RES8 0 3p IC=0
Cdlo1 ENHOLO 0 3p IC=0
Edff3 DFF6 0 VALUE { if(V(CLK)>2.5,V(DFF4),0) }
Rcomp2 COMP2 0 200
V1V RAMPINT RAMP 1
Cuvc3 UVC2 0 3p IC=0
Xdff1 DFF2 DFF3 DFF4 DFF5 rsff5k PARAMS:
Rosc1 CLK OSC1 500
Evref2 VREF2 0 VALUE { if(V(VCCuv)>2.5 | V(VCClow)>2.5 | V(SD)>2.5,0,V(VREF1)) }
Euvc1 UVC3 0 VALUE { if(V(VCC)>7.4,5,0) }
Rleb1 LEB1 0 1
Cotr1 OUTPUTTIMERRESET 0 3p IC=0
Cuvb1 UVB2 0 3p IC=0
Css7 SS2 0 300p IC=0
Euvi2 UVI2 0 VALUE { if(V(UVLO)>1.25,5,0) }
Cvref1 VREF3 0 3p IC=0
Rcomp3 COMP3 0 200
Cvcc2 VCC4 0 3p IC=0
Rdr6 DRVLOSIG DR6 500
Cdr11 SR1 0 3p IC=0
Gss2 SS 0 VALUE { if(V(VCCuv)<=2.5 & V(VREFuv)<=2.5,if(V(nSB)<=2.5,110E-6,0),0) }
Cvcc5 VCC7 0 3p IC=0
Ruvc3 UVC2 UVC3 500
Cmon1 MON2 0 10p IC=0
Cmon2 MON1 0 20p IC=0
Cmon3 MON3 0 3p IC=0
Eosc2 OSC3 0 VALUE { if(V(VREFuv)<=2.5,sin(2*3.141592*TIME/(2/(6.25E9*I(VRT))+110E-9)),0) }
Rosc2 OSC2 OSC3 500
Cosc2 OSC2 0 3p IC=0
Eleb2 LEB2 0 LEB3 0 1
Cuvr1 UVR2 0 3p IC=0
Ccs3 CS5 0 3p IC=0
Eotr1 OTR1 0 VALUE { if(V(DRIVERSOFF)>2.5 | V(SSRESTART)>2.5,5,0) }
Cvcc3 VCC5 0 3p IC=0
Cdl1 DRVLATCH 0 400p IC=0
Cuvc4 VCCLOW 0 3p IC=0
Edrv5 DRVHISIG 0 VALUE { if(V(ENholo)<=2.5,0,if(V(DRVHI)>2.5 & V(DELAYDRVHI)>2.5 & V(VCClow)<=2.5 & V(UVb)>2.5,5,0)) }
Cuvb2 UVB4 0 3p IC=0
Rdlo2 PENSR1SR2 ENSR1SR2 500
Euvr1 UVR3 0 VALUE { if(V(REF)>4,5,0) }
Ruvi2 NSB UVI2 500
Eov1 OV1 0 VALUE { if(V(OVP)>1.25,5,0) }
Ccs4 CS6 0 3p IC=0
VDLY VDLY1 DLY 0
Xres_sub1 RES5 RES6 RESLATCH res4 rsff5k PARAMS:
Euvi1 UVI1 0 VALUE { if(V(UVLO)>0.35,0,5) }
Rmon2 MON3 MON4 500
Cdr8 DR8 0 3p IC=0
Xdff2 DFF6 DFF7 SELECTHILO DFF1 rsff5k PARAMS:
Ggateloss VIN 0 VALUE { I(VVCC) }
Ecomp1 COMP4 0 VALUE { V(SS) }
Xuvb1 UVB2 UVB4 uvb1 UVb rsff5k PARAMS:
Rdl1 DRVLATCH DL1 2
Rvcc4 VCC7 VCC 1
Eleb1 CS8 0 VALUE { if(V(LEB1)>2.5 & V(LEB4)>2.5,5,0) }
Ruvr1 UVR2 UVR3 500
Rov1 OVPSIG OV1 500
Eotr2 OTR6 0 VALUE { if(V(DRVHI)>2.5 | V(DRIVERSOFF)>2.5,5,0) }
Rpwm3 PWMOUT PWM5 50
Evcc1 VCC1 0 TABLE { V(VIN) } ( (0,0)(4.5,0)(4.6,0.7)(12,7.6) )
Edrv7 SR1SIG 0 VALUE { if(V(ENsr1sr2)<=2.5,0,if(V(DRVHI)>2.5 | V(DELAYDRVHI)>2.5,0,if(V(VCClow)<=2.5,5,0))) }
Cuvi2 NSB 0 3p IC=0
Eres_sub1 RES5 0 VALUE { if(V(CLK)>2.5,V(RES7),0) }
Eres_sub2 RES6 0 VALUE { if(V(CLK)>2.5,V(ILIMLATCH),0) }
Rotr4 OTR5 OTR6 500
Emon1 MON4 0 VALUE { if(V(RAMPint)>3.5,5,0) }
Rleb2 LEB3 LEB4 500
Evdly1 VDLY1 0 TABLE { V(REF,0) } ( (0,0) (2.5,2.5) )
Cuvr2 VREFLOW 0 3p IC=0
Rss7 SS1 SS 32
Cdd1 DELAYDRVHI 0 40p IC=0
Cdlo2 ENSR1SR2 0 3p IC=0
Rvccint1 VCC6 VCCINT 100m
Euvc2 UVC5 0 VALUE { if(V(VCC)<6.2,5,0) }
Cvref2 REF 0 3p IC=0
Givcc1 VCC7 0 TABLE { V(VCC) } ( (0,0) (7.5,0.004) )
Cdr10 LO 0 3p IC=0
Cleb1 LEB3 0 3p IC=0
Cov1 OVPSIG 0 3p IC=0
Rdrvhi1 DRVHI PDRVHI 500
Cotr4 OTR5 0 10p IC=0
Rres1 RES1 RES 32
Rmon1 MON2 MON3 200
Xcs1 CS5 CS6 cs4 CSBLANK rsff5k PARAMS:
Ruvc4 VCCLOW UVC5 500
Cdrvhi1 DRVHI 0 10p IC=0
Xotr2 OTR10 OTR11 CLTIMEROUT otr9 rsff5k PARAMS:
Epwm1 PWM5 0 VALUE { if((V(RAMPINT)>V(COMPX)) | V(maxONlatch)>2.5 | V(ILIMlatch)>2.5 | V(DRIVERSoff)>2.5 | V(SSreset)>2.5,5,0) }
Ruvb2 UVB4 UVB5 500
Eosc3 NCLK 0 VALUE { {5-V(CLK)} }
Eleb3 LEB4 0 VALUE { if(V(DRVLOSIG)>2.5 | V(DRVHISIG)>2.5,5,0) }
Tresd1 DCLK 0 RESD2 0 Z0=1 TD=80n
Qcomp2 COMPX COMP COMP3 NOMNPN
Rdr8 SR2SIG DR8 500
Rvcc3 0 VCC4 5k
Euvr2 UVR5 0 VALUE { if(V(REF)<3,5,0) }
Eres1 RES3 0 VALUE { if(V(CLTIMEROUT)>2.5,5,0) }
Xpwm1 PWMOUT PWM2 PWMOUT2 pwm1 rsff5k PARAMS:
Evref1 VREF1 0 TABLE { V(VCC) } ( (0,0) (6,5) )
Ecs2 CS9 0 VALUE { if(V(CLK)>0.1,0,if(V(CS1)>0.25 & V(PWMOUT2)>2.5,5,0)) }
Cdl2 MAXONLATCH 0 500p IC=0
Rdrvoff1 PDRIVERSOFF DRIVERSOFF 500
Rram1 RAM1 RAMP 10
Edff1 DFF2 0 VALUE { if(V(NCLK)>2.5,V(DFF1),0) }
RdumRT RT 0 10E6
Ruvr2 VREFLOW UVR5 500
Rvindummy1 VIN 0 1.28Meg
Rresd1 DCLK 0 1
Rdrvlo1 DRVLO PDRVLO 500
Rcs5 CS CS1 2k
Edrv8 SR2SIG 0 VALUE { if(V(ENsr1sr2)<=2.5,0,if(V(DRVLO)>2.5 | V(DELAYDRVLO)>2.5,0,if(V(VCClow)<=2.5,5,0))) }
Cdrvoff1 DRIVERSOFF 0 3p IC=0
Xotr1 OTR5 CLTIMEROUT SSRESTART otr4 rsff5k PARAMS:
Epwm2 PWM4 0 VALUE { if(V(CLK)>4.5, 5, 0) }
Eram1 RAM3 0 VALUE { if(V(SSRESET)>2.5 | V(CLK)>2.5 | V(maxONlatch)>2.5,5,0) }
Eres2 RES10 0 VALUE { if(V(DCLK)>2.5,5,0) }
Eotr3 OTR12 0 VALUE { if(V(RES)<0.1 & V(SS)<0.1,5,0) }
Cdd2 DELAYDRVLO 0 40p IC=0
Cdr9 HO HS 3p IC=0
Rvcc1 VCC2 VCC3 1
Cdrvlo1 DRVLO 0 10p IC=0
Ccs5 CS1 0 6p IC=0
Eresd1 RESD2 0 CLK 0 1
Rvref3 0 REF 5k
Edlo1 PENHOLO 0 VALUE { if(V(DRVlatch)>2.5 & V(DRIVERSoff)<=2.5,5,0)}
Edrv6 DRVLOSIG 0 VALUE { if(V(ENholo)<=2.5,0,if(V(DRVLO)>2.5 & V(DELAYDRVLO)>2.5 & V(VCClow)<=2.5,5,0)) }
Rotr7 OTR10 OTR12 500
Rpwm2 PWM2 PWM4 500
Rvcc2 0 VCC3 2k
Xres1 RES8 RES9 ILIMLATCH RES7 rsff5k PARAMS:
Ruvi1 SD UVI1 500
Cres1 RES2 0 300p IC=0
VRT VRT1 RT 0
Cvccint1 0 VCCINT 10p IC=0
Cdr7 DR7 0 3p IC=0
Rres5 RES8 RES10 500
Eotr4 OTR13 0 VALUE { if(V(DRIVERSOFF)>2.5 | V(RES)>2.5,5,0) }
Gres1 0 RES VALUE { if(V(RESLATCH)>2.5, 22E-6, -12E-6) }
Edff2 DFF3 0 VALUE { if(V(NCLK)>2.5,V(SELECTHILO),0) }
Rres2 RES2 RES3 500
Rresdum1 0 RES 1G
Rdl2 MAXONLATCH MON1 5
Evrt1 VRT1 0 TABLE { V(REF,0) } ( (0,0) (2,2) )
Govhys1 0 OVP VALUE { if(V(OVPSIG)>2.5,23E-6,0) }
Cvcc1 VCC3 0 3p IC=0
Qcomp1 COMP COMP COMP2 NOMNPN
Rotr8 OTR11 OTR13 500
Css5 SS 0 3p IC=0
Cpwm1 PWMOUT 0 400p IC=0
Rcs6 CS9 ILIM 500
Rdlo1 PENHOLO ENHOLO 500
Eres3 RES11 0 VALUE { if(V(ILIM)>4.5,5,0) }
Rvref1 VREF2 VREF3 1
Xuvc1 UVC2 VCCLOW VCCuv uvc1 rsff5k PARAMS:
Cram1 RAM2 0 3p IC=0
Ruvidummy 0 UVLO 10Meg
Rss8 SS2 SSRESET 500
Cpwm2 PWM2 0 3p IC=0
Evcc2 VCC2 0 VALUE { IF(V(SD)>2.5,0,V(VCC1)) }
Cdr6 DR6 0 3p IC=0
Ccomp1 COMP 0 1p IC=0
Rcs7 CS CS2 32
Ccs7 CS2 0 10p IC=0
Rvccint2 VCCINT VCC 10m
Cdr12 SR2 0 3p IC=0
Cdr5 DR5 0 3p IC=0
Rvref2 0 VREF3 5k
Cdl3 DL1 0 10p IC=0
Gvref1 0 REF TABLE { V(VREF3, REF) } ( (0,0)(0.15,0.02) )
Dvcc1 vcctemp VIN DNOM
Dvcc2 VCC vcctemp DNOM
Dvref1 REF VCC DNOM
*SWITCHs
Sdiode_vcc1 VCC5 VCC6 VCC5 VCC6 SWCLAMP
Spwmdiode1 PWM5 PWMOUT PWM5 PWMOUT SWCLAMP
Scompdiode1 COMPX COMP4 COMPX COMP4 SWCLAMP
Smondiode1 MON4 MON3 MON4 MON3 SWCLAMP
Suvi1 0 UVLO 0 UVLO SWCLAMP
Sresdiode1 RES V5V RES V5V SWCLAMP
Sresdiode2 0 RES 0 RES SWCLAMP
Scsdiode1 CS9 ILIM CS9 ILIM SWCLAMP
Scsdiode2 ILIM V5V ILIM V5V SWCLAMP
Sssdiode1 SS V5V SS V5V SWCLAMP
Sssdiode2 0 SS 0 SS SWCLAMP
Sdd1 DELAYDRVHI V5V DELAYDRVHI V5V SWCLAMP
Sdd2 0 DELAYDRVHI 0 DELAYDRVHI SWCLAMP
Sdd3 DELAYDRVLO V5V DELAYDRVLO V5V SWCLAMP
Sdd4 0 DELAYDRVLO 0 DELAYDRVLO SWCLAMP
Sres1 RES1 0 RES2 0 S5K
Sdl1 V5V DL1 DRVLO 0 S5K
Sss1 SS1 0 SS2 0 S5K
Sram1 RAM1 0 RAM2 0 S5K
Scs1 CS2 0 CSBLANK 0 S5K
Smon1 V5V MON1 MON2 0 S5K
Smon2 MON1 0 CLK 0 S5K
Sdriver1 HB HO DR5 0 SdriverT
Sdriver2 HO HS DR5 0 SdriverB
Sdriver3 VCC LO DR6 0 SdriverT
Sdriver4 LO 0 DR6 0 SdriverB
Sdriver6 SR1 0 DR7 0 SdriverSRB
Sdriver8 SR2 0 DR8 0 SdriverSRB
Rgiga1 VCC5 VCC6 1G
Rgiga2 PWM5 PWMOUT 1G
Rgiga3 COMPX COMP4 1G
Rgiga4 MON4 MON3 1G
Rgiga5 0 UVLO 1G
Rgiga6 RES V5V 1G
Rgiga7 0 RES 1G
Rgiga8 CS9 ILIM 1G
Rgiga9 ILIM V5V 1G
Rgiga10 SS V5V 1G
Rgiga11 0 SS 1G
Rgiga12 DELAYDRVHI V5V 1G
Rgiga13 0 DELAYDRVHI 1G
Rgiga14 DELAYDRVLO V5V 1G
Rgiga15 0 DELAYDRVLO 1G
Rgiga16 RES2 0 1G
Rgiga17 DRVLO 0 1G
Rgiga18 SS2 0 1G
Rgiga19 RAM2 0 1G
Rgiga20 CSBLANK 0 1G
Rgiga21 MON2 0 1G
Rgiga22 CLK 0 1G
Rgiga23 DR5 0 1G
Rgiga24 DR5 0 1G
Rgiga25 DR6 0 1G
Rgiga26 DR6 0 1G
Rgiga27 DR7 0 1G
Rgiga28 DR8 0 1G
Rgiga29 OUTPUTTIMERRESET 0 1G
Rgiga30 DR7 0 1G
Rgiga331 DR8 0 1G
*35C
Gvcc1 0 VCC4 TABLE { V(VCC3, VCC4) } ( (0,0)(0.3,0.058) )
Euvb1 UVB3 0 VALUE { if((V(HB)-V(HS))>3.8,5,0) }
Euvb2 UVB5 0 VALUE { if((V(HB)-V(HS))<3.3,5,0) }
Gss1 0 SS VALUE { if(V(VCCuv)<=2.5 & V(VREFuv)<=2.5, if(V(nSB)<=2.5 | V(SSrestart)>2.5 | V(SSreset)>2.5, 1.2E-6, 110E-6),0) }
Edriversoff PDRIVERSOFF 0 VALUE { if(V(VREFuv)>2.5 | V(VREFlow)>2.5 | V(ovpsig)>2.5 | V(VCClow)>2.5 | V(SD)>2.5 | V(nSB)<=2.5,5,0) }
Edrvhi1 PDRVHI 0 VALUE { if(V(selectHILO)>2.5 & V(PWMout2)>2.5 & V(SSreset)<=2.5,5,0) }
Edrvlo1 PDRVLO 0 VALUE { if(V(selectHILO)<=2.5 & V(PWMout2)>2.5 & V(SSreset)<=2.5,5,0) }
Edlo2 PENSR1SR2 0 VALUE { if(V(DRVlatch)>2.5 & V(nSB)>2.5,5,0) }
Gdd1 0 DELAYDRVHI VALUE { if(V(DRVHI)>2.5,I(VDLY)*13.333,-I(VDLY)*57.143) }
Gdd2 0 DELAYDRVLO VALUE { if(V(DRVLO)>2.5,I(VDLY)*13.333,-I(VDLY)*57.143) }
Sdl2 DL1 0 OUTPUTTIMERRESET 0 S5K
Sdriver5 REF SR1 DR7 0 SdriverSRT
Sdriver7 REF SR2 DR8 0 SdriverSRT
*subckt
.MODEL Dnom D IS=100n RS=30m CJO=10p VJ=0.5 EG=0.6
.MODEL S5K VSWITCH RON=1 ROFF=100E6 VON=1V VOFF=0.0V
.MODEL SWCLAMP VSWITCH RON=0.001 ROFF=100E6 VON=10m VOFF=0
.MODEL SdriverT VSWITCH RON=8 ROFF=0.5E6 VON=2.6V VOFF=2.4V
.MODEL SdriverB VSWITCH RON=0.5E6 ROFF=5 VON=2.6V VOFF=2.4V
.MODEL SdriverSRT VSWITCH RON=20 ROFF=0.5E6 VON=2.6V VOFF=2.4V
.MODEL SdriverSRB VSWITCH RON=0.5E6 ROFF=20 VON=2.6V VOFF=2.4V
.MODEL NOMNPN NPN RB=350 RC=600 RE=20
.ENDS LM5035C
* RSFF
.SUBCKT RSFF5K R S Q NQ
Eff1 PSTATE 0 VALUE { if(V(R)>2.5 & V(S)<=2.5,0,if(V(R)<=2.5 & V(S)>2.5,5,2.5)) }
Rff1 STATE PSTATE 500
Cff1 STATE 0 9p IC=0
Eff2 PQ 0 VALUE {if(V(STATE)>=4.5,5,if(V(STATE)<=0.5,0,if(V(FFMEM)>2.5,5,0))) }
Rff2 Q PQ 500
Cff2 Q 0 12p IC=0
Eff3 PNQ 0 VALUE {if(V(STATE)>=4.5,0,if(V(STATE)<=0.5,5,if(V(FFMEM)>2.5,0,5))) }
Rff3 NQ PNQ 500
Cff3 NQ 0 12p IC=0
Sff4 V5V FFMEM Q 0 SFF
Rff4 Q 0 1G
Sff5 FFMEM 0 NQ 0 SFF
Rff5 NQ 0 1G
Cff6 FFMEM 0 3p IC=0
Vff7 V5V 0 5
.MODEL SFF VSWITCH RON=500 ROFF=100MEG VON=4.5V VOFF=0.5V
.ENDS RSFF5K
