SwitcherPro Does Not Work Under Vista 64-bit OS
Hello!  I am trying to use the SwitcherPro tool using the Vista 64-bit OS.  I have followed the suggestions of other posts to ensure the SwitcherProDT executable is set to run in compatibility mode for WinXP SP2 and I have set the Privilege Level to Run as Administrator.  SwitcherPro crashes immediately after I launch the program.  Any ideas on how to get it to work on this system?
Charles
  • Hello Charles,
    The workaround you have tried are for 32-bit Vista systems. Currently, SwitcherPro is not supported on64-bit OS such as, 64-bit Vista and Windows7. We are releasing a new version of SwitcherPro v3.6 on February 19th which will be supported on 64-bit machines.
    Hetal.
