Other Parts Discussed in Thread: TPS54425, TINA-TI, TPS74401, TPS54429
I am trying to simulate the power supply using Tina-Ti. Again, the combination is TPS54425 with TPS74401 causing some problem for me.(Previous post : https://e2e.ti.com/support/development_tools/webench_design_center/f/234/t/418044). TPS54429 output is connected to VIN and BIAS of TPS74401. Also, PGOOD of TPS54425 is applied as TPS74401 ENABLE. When simulating, PGOOD is not going HIGH, it is always low. When this connection is removed from TPS74401, PGOOD is working fine.
I am using the new model of TPS74401 shared in the previously mentioned post ("7612.TPS74401_TRANS.lib")
Thank you very much.
regards,
Sneha
