Hi
I want to estimate the Phase and Gain Margins of the simple application circuit mentioned in TPS5450 datasheet. I use the method described in the below link
However, if I inject the sine wave as mentioned on the website, I cant run the AC analysis. I always get an error "Operating point not found". I tried different .PRM files from your library, but no success. I also add a shunt resistor in parallel to VG1, but still fails.
Can you please help take a look if any change need to be made and if that change wont change the loop characteristics I am trying to measure.
Attached are the .TSC file and .TSM files (for TPS5450 and BC540)
