I have a PCB with this hooked up this LED driver to GPIO instead of a serial port. Can this board still DIM its lights in the 64 intensity levels describe in the data sheet.
Hello Daniel,
Yes, the registers can be programmed without blanking the LEDs. Some example projects set the blank pin high during device programming, which is probably what you are referring to.
Casey
