TINA/Spice: Don't find any way to create and insert a CT(current transformer) in schematic prepared in TINA?
Other Parts Discussed in Thread: TINA-TI
Tool/software: TINA-TI or Spice Models
I have a power distribution unit (PDU) used in servers . It has current rating of 32 A.  I want to measure this current and convert into proportional voltage using CT (current transformer). The current of 32 A passing through live cable of PDU . This wire is passed through 1 CT . Its turns ratio is 1:2500. I will connect a burden resistor of 7.5 ohm accros CT and measure voltage across burden resistor . But in TINA 's simulation model ,I don't find any way  to add CT in the schematic and check the simulation results of output voltage waveform. So how to do it?
