Iam using IBIS model of SN74CBTLV16212 for simulation. I want to do simulation for A1 to B1 port.
Usually when using hyperlynx,
In the Pins list, when you select a pin connected to a series bus switch, all the other pins in the series bus switch are also highlighted.
But this is not possible with your IBIS model.
Also please share with me the s parameter model for this IC if possible.
Thank you.
Bhavya
