WEBENCH® Tools: Ultra Librarian and LMZ31710_RVQ_42.bxl(LMZ31520_RLG_72.bxl) problem
Other Parts Discussed in Thread: LMZ31520, LMZ31710, LMZ35003
The same issue occurs with the LMZ35005 in the Altium exporting process. Could you have a look on that?
This is the error log for your reference:
ERROR - Pattern "RKG41", entity (1-Pad) references a non-existant padstack (). Pattern will be skipped.
ERROR - Pattern "RKG41", entity (12-Pad) references a non-existant padstack (). Pattern will be skipped.
ERROR - Pattern "RKG41", entity (22-Pad) references a non-existant padstack (). Pattern will be skipped.
ERROR - Pattern "RKG41", entity (34-Pad) references a non-existant padstack (). Pattern will be skipped.
Message - Pattern "RKG41", entity (320-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (322-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (325-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (327-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (330-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (332-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (335-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (337-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (340-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (342-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (345-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (347-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (350-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (352-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (355-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (357-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (360-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (362-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (365-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (367-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (370-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (372-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (375-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (377-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (380-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (382-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (385-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (387-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (390-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (392-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (395-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (397-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (400-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (402-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (405-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (407-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (410-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (412-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (415-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (417-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (420-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (422-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (425-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (427-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (430-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (432-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (435-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (437-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (440-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (442-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (445-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (447-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (450-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (452-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (455-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (457-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (460-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (462-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (465-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (467-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (470-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (472-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (475-Line) is a LINE with matching start and end points.
Message - Pattern "RKG41", entity (477-Line) is a LINE with matching start and end points.
Message - Component LMZ35003_RKG_41 refrences a footprint (RKG41) not in the library.
  • Hi Hai Lai,
    Thank you for informing us on the BLX issue.
    I have reviewed the BXLs and found that the LMZ35003 BXL file is corrupted but the LMZ31710  and the LMZ31520 are ok.
    We will correct the LMZ35003 BXL issue and will re-post it on the server.  Since, I was looking at the issue, I went ahead and generated the Altium library files for both parts.
    See attached zipped file:  LMZ3xxxx.zip
