Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
The TPS25944A PSPICE model iMon output does not appear to work. No matter what resistor is attached the output appears to be in uV instead of uA. My understanding is the pin should output 52uA per amp of current being monitored. The output appears to be 52uV per amp instead (thinking there may be an error in the PSPICE model). Anyone else have trouble with this? The waveform appears to track current as expected and has a constant voltage for a wide range of resistors. Guessing the PSPICE model has voltage output instead of current output. TI please take a look at the model.
