Part Number: ADS1293EVM
ADS1293EVM WIN 10 can't install driver
When you get "no board found" error message in windows 10 when try to run the software. you need to install the driver manually.
Before installing the driver manually - you need to update the windows 10 that you are going to install unsigned driver - otherwise the windows 10 will refuse to install it.
You can find here the right way to tell win 10 that you are going to install unsigned driver...
Good luck
