TIDA-00440: Insulation Resistance Monitoring System
Part Number: TIDA-00440
Other Parts Discussed in Thread: TIDA-01513
Hello, I am looking for some Insulation resistance monitoring/ leakage current measurement system in EVs/HEVs. I have found this TI TIDA-00440 reference design, which has similar application in transformers, motor drives but not for Automotive (EVs/HEVs). so can this same reference design work in automotive? or there is any better automotive grade system for the same purpose. if yes, please share.
  • Hello Vivek,
                             Thank you for looking into our TI designs. Insulation monitoring / leakage current measurement are stipulated by the relevant standards. TIDA-00440 is based on IEEE 43-2000. You may need to find the relevant standard for Automotive. The concept used in TIDA-00440 may work - but would recommend you to check for the limits and test levels specified in the automotive standard. Do let us know if there are any queries related to TIDA-00440.
    regards
    Navaneeth
  • Thank you Navneeth for your support.
    Eventually I found this another TI reference design TIDA -01513 which is  Automotive High-Voltage and Isolation Leakage Measurements Reference Design. This is sufficing the requirement but in its design guide there are some errors specially in test result section  which you can find in the attachment. For different cases the result is same("delta values is same in all the plots") probably some human mistake. Please if I can get some more depth and correct data about TIDA-01513, it will be really helpful.
    Vivek Kumar
  • Vivek, I will let the author of TIDA-01513 to respond you back.
    regards
    Navaneeth
  • Vivek, our apologies on the delayed response to you regarding your interest and subsequent question on the TIDA-01513 design. It appears the initial forward to the design owner didn't transmit in our system. The design owner has been contacted and we will provide you with some answer in the coming few business days. Again, sorry for any inconvenience that this error may have caused.
    Best Regards
    John Fullilove
    Texas Instruments
    TI Designs
  • Hello Vivek,
    Greetings,
    Thanks a lot for letting us know about the entries for Delta Voltage. This was missed out during internal reviews.
    Behavior of the system can be clearly seen in all pictures. I hope this had helped you in understanding more about this design. Measurement voltages can also be seen in pictures. Design guide will be updated accordingly.
    Let me know if you are looking for more details.
    Rama Kambham
