Part Number: PMP9256
Dear Sir,
The output Ripple is around 160 to 140 mV with 20 MHZ band limited Scope.
Is there any suggested ripple suppression filter or any other circuit modification such that the ripple can be reduced to a level of 10mV.
Dear Sir,
A second stage LC could be added to the output to reduce the ripple level. You need to take specific care to make sure that the stability of the converter is not affected. Please refer to the following reference material
Robert
Dear Sir,
Thank you for your response..
As we are not expert in power supply design we have directly adopted the PMP9256 design and made the board.
For second stage ripple filter for this particular board is there any suggested filter design with indicated values to achieve ripple of order 10 mV.
Please suggest the values and we will work around with the available components.
thank you..
