Part Number: LMR14006
Other Parts Discussed in Thread: LMR14020, TPS560430,
Dear Sir,
I have a query to make a power supply design for my device, the requirements are as follows:
Dear Sir,
Please look for LMR14006XDDRC Design first. I am attaching you the pdf file for the same. Please look into this
hi
Thanks for your reply. I do have other query with another power supply which is as below : There are few changes i did with the package of resistor and Capacitor please look into this.
CFF is 0603 package but in actual it was 0201
Rbb is 0603 Package but in actual it was 0201.
Please check for the noise into the Pcb as there layout will changed due to bigger components..
Waiting for your early reply3034.LMR14020.pdf
Hi Andy
Please look for the 2nd design also. I am waiting from your side to confirm the design.
It's OK to use 0201 size device on Cff or feedback. Cff cap voltage rating should be >16V.
For LMR14020 design, pls change Cff cap from 270pF to 150pF, all other external components are OK.
