SwitcherPro old versions
Other Parts Discussed in Thread: TPS40210, TPS40222, TINA-TI
Is there a place to download old desktop versions of SwitcherPro. Specifically I'm looking for a 3.7.xxxx version.
Jeff
  • Hi Jeff,
    TI does not provide old versions of SwitcherPro Desktop for download. Why are you interested in SwitcherPro 3.7.x? Are you interested in creating a design that uses the TPS40210, TPS40222, TPS55332, or TPS54362? These devices were removed because SwitcherPro was not capable of producing consistently good designs with these parts. So, even if you find
    SwitcherPro 3.7.x out on the Internet, I would recommend against using it with one of these devices.
    It is unlikely that any of these parts will be added back into SwitcherPro in the near future. However, TI does provide macro-models for the
    TPS40210 and TPS40222. You can download these here: http://www.ti.com/spicerack. These models run on our free TINA-TI simulator, which is available here: http://www.ti.com/tina-ti. You should be able to use the equations in the datasheet to tweak the TINA-TI reference designs to produce/test a design with simulation.
    Michael
    Michael Krasnicki
    Analog eLab
    Texas Instruments
