Part Number: OPT101
Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
how can add opt101 to tina library.
Hi Aftab,
1. Download the Unencrypted File, unzip so that you can grab the .mod file (.mod file in this case is a regular text file and you can modify the extension from .mod to .txt or .lib, just open it with notepad or any text editor)
2. On TINA-TI go to Tools -> New Macro Wizard
3. Create the symbol or .TSM file from Step #2
4. Once you have the symbol or .TSM file, then instantiate the .TSM by going into Insert -> Macro
Herman
Hi Aftab,
You have to observe the error message. If the error message complains about general syntax or format, then follow the message and make the fix before creating the symbol again. However, if the message has something to do with "component" cannot be recognized by TINA, then it's not possible to import it to Tina.
Herman
